    Can't Install: Segmentation Fault when Installing Fonts
    13 Posts 3 Posters 3.7k Views 3 Watching
      @mdub ok, not sure why the problem… can u try the updated installer…
      see here https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
      this will be in the next version release
      you will need to rename MagicMirror folder to something else
      also I might suggest to rm -rf ~/.npm to clean up the npm folder
        jg3
        I’m having the exact same problem:
        Segmentation fault.] \ extract:roboto-fontface: verb lock using /home/pi/.npm/_locks/staging-0ff2d9730ff2850b.lock for /home/pi/MagicMirror/fonts/node_modules/.stagi
        npm ERR! code ELIFECYCLE
        npm ERR! errno 139
        …and so on.
        I have a fresh new & updated RPI install into an ESXi VM, and I’m following the instructions on https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
        (plus: sudo apt-get -y install npm && sudo npm i -g npm).
        I have tried to remove and re-clone the MagicMirror dist, same effect.
        Here’s a little more from the npm log, in case it is helpful…
        28887 silly postinstall valid-url@1.0.9
        28888 info lifecycle valid-url@1.0.9~postinstall: valid-url@1.0.9
        28889 verbose unlock done using /home/pi/.npm/_locks/staging-f4a655787a5bf4d3.lock for /home/pi/MagicMirror/node_modules/.staging
        28890 silly install runPostinstallTopLevelLifecycles
        28891 silly build magicmirror@2.11.0
        28892 info linkStuff magicmirror@2.11.0
        28893 silly linkStuff magicmirror@2.11.0 has /home/pi as its parent node_modules
        28894 verbose linkBins magicmirror@2.11.0
        28895 verbose linkMans magicmirror@2.11.0
        28896 silly install magicmirror@2.11.0
        28897 info lifecycle magicmirror@2.11.0~install: magicmirror@2.11.0
        28898 verbose lifecycle magicmirror@2.11.0~install: unsafe-perm in lifecycle true
        28899 verbose lifecycle magicmirror@2.11.0~install: PATH: /usr/share/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbi
        n:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
        28900 verbose lifecycle magicmirror@2.11.0~install: CWD: /home/pi/MagicMirror
        28901 silly lifecycle magicmirror@2.11.0~install: Args: [ '-c',
        28901 silly lifecycle   'echo "Installing vendor files ...\n" && cd vendor && npm install --loglevel=error' ]
        28902 silly lifecycle magicmirror@2.11.0~install: Returned: code: 0  signal: null
        28903 silly postinstall magicmirror@2.11.0
        28904 info lifecycle magicmirror@2.11.0~postinstall: magicmirror@2.11.0
        28905 verbose lifecycle magicmirror@2.11.0~postinstall: unsafe-perm in lifecycle true
        28906 verbose lifecycle magicmirror@2.11.0~postinstall: PATH: /usr/share/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local
        /sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
        28907 verbose lifecycle magicmirror@2.11.0~postinstall: CWD: /home/pi/MagicMirror
        28908 silly lifecycle magicmirror@2.11.0~postinstall: Args: [ '-c',
        28908 silly lifecycle   'npm run install-fonts && echo "MagicMirror installation finished successfully! \n"' ]
        28909 silly lifecycle magicmirror@2.11.0~postinstall: Returned: code: 139  signal: null
        28910 info lifecycle magicmirror@2.11.0~postinstall: Failed to exec postinstall script
        28911 verbose stack Error: magicmirror@2.11.0 postinstall: `npm run install-fonts && echo "MagicMirror installation finished successfully!
        28911 verbose stack "`
        28911 verbose stack Exit status 139
        28911 verbose stack     at EventEmitter.<anonymous> (/usr/share/npm/node_modules/npm-lifecycle/index.js:283:16)
        28911 verbose stack     at EventEmitter.emit (events.js:189:13)
        28911 verbose stack     at ChildProcess.<anonymous> (/usr/share/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
        28911 verbose stack     at ChildProcess.emit (events.js:189:13)
        28911 verbose stack     at maybeClose (internal/child_process.js:970:16)
        28911 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        28912 verbose pkgid magicmirror@2.11.0
        28913 verbose cwd /home/pi/MagicMirror
        28914 verbose Linux 4.19.0-8-amd64
        28915 verbose argv "/usr/bin/node" "/usr/bin/npm" "install"
        28916 verbose node v10.15.2
        28917 verbose npm  v5.8.0
        28918 error code ELIFECYCLE
        28919 error errno 139
        28920 error magicmirror@2.11.0 postinstall: `npm run install-fonts && echo "MagicMirror installation finished successfully!
        28920 error "`
        28920 error Exit status 139
        28921 error Failed at the magicmirror@2.11.0 postinstall script.
        28921 error This is probably not a problem with npm. There is likely additional logging output above.
        28922 verbose exit [ 139, true ]
        –jg3
          jg3 @sdetweil
          @sdetweil … I tried using the installer (it looks cool!) but it failed in the same place with apparently the same error.
          I’m new to Magic Mirror and … i guess I’m glad I tried it on a VM before I ordered hardware? … any suggestions on what’s causing this would be obliged.
            sdetweil @jg3
            @jg3 can u show me the ~/install.log
            I suspect its a downlevel npm problem… 6.13.4 is the latest on buster on my pi 3 and 4
            so, u are running and arm (pi) virtual machine, on an intel box (esx)?
              jg3 @sdetweil
              @sdetweil Hi Sam, thanks for the reply.
              I’m running raspberry pi on an emulated x86 processor:
              pi@raspberry:~ $ uname -a
              Linux raspberry 4.19.0-8-amd64 #1 SMP Debian 4.19.98-1 (2020-01-26) x86_64 GNU/Linux
              Below is my ~/install.log. Because the error comes at the very, very end of the install things seem to work OK, but some MM modules will show the same error when they install. Also note that I had installed and updated npm before running the installer.
              pi@raspberry:~ $ more install.log
              install starting  - Sun Apr  5 02:03:49 EDT 2020
              installing on x86_64 processor system
              the os is Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster
              user stopped install on x86_64 hardware
              install starting  - Sun Apr  5 02:10:26 EDT 2020
              Updating packages ...
              Hit:1 http://security.debian.org buster/updates InRelease Hit:2 https://deb.nodesource.com/node_10.x buster InRelease Hit:3 http://archive.ras
              pberrypi.org/debian buster InRelease Hit:4 http://ftp.debian.org/debian buster InRelease Hit:5 http://ftp.debian.org/debian buster-updates InR
              elease Reading package lists...
              apt-get update  completed ok
              apt-get upgrade  started
              apt upgrade result =rc=0 Reading package lists...
              Building dependency tree...
              Reading state information...
              Calculating upgrade...
              Installing helper tools ...
              build-essential is already the newest version (12.6).
              git is already the newest version (1:2.20.1-2+deb10u1).
              unzip is already the newest version (6.0-23+deb10u1).
              wget is already the newest version (1.20.1-1.1).
              wget set to manually installed.
              curl is already the newest version (7.64.0-4+deb10u1).
              Minimum Node version: v10.1.0
              Installed Node version: v10.15.2
              No Node.js upgrade necessary.
              Minimum npm version: V6.0.0
              Installed npm version: V6.14.4
              No npm upgrade necessary.
              Cloning MagicMirror ...
              Cloning MagicMirror Done!
              Installing dependencies ...
              Unable to install dependencies!
              install starting  - Sun Apr  5 02:11:06 EDT 2020
              It seems like MagicMirror is already installed.
              To prevent overwriting, the installer will be aborted.
              Please rename the ~/MagicMirror folder and try again.
              If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
              install starting  - Sun Apr  5 02:11:40 EDT 2020
              pi@raspberry:~ $
                sdetweil @jg3
                @jg3 hm… i would erase the ~/.npm folder (rm -rf ~/.npm) and try install again
                  jg3 @sdetweil
                  @sdetweil Because you’d recommended that to the OP I gave that a try but it didn’t make a difference.
                  Like I said, the MM is running now but I’d be a lot more comfortable if I could get to the bottom of this and a couple of other small things.
                  Thank you kindly for the replies.
                    sdetweil @jg3
                    @jg3 k, tell me how you set that up so I can try to recreate…
                    i have virtualbox, and vmware Workstation… no esx around tho
                    I run macOS catalina, Ubuntu 19.04, and Zorin vms and install MM on all of them without problem
                    (VMs under vmware). my vmware host is either windows 10 or Ubuntu Mate 18.04 (dual boot)
                    ah, i see raspian for x86… downloading now
                      sdetweil @jg3
                      @jg3 ok, this is a bug in the installer for the roboto-fontface package
                      if u edit the ~/MagicMirror/fonts/package.json, and change
                       "dependencies": {
                          "roboto-fontface": "^0.8.0"
                      to
                       "dependencies": {
                          "roboto-fontface": "latest"
                      it will work…
                      S J 2 Replies Last reply Reply Quote 1
                        @sdetweil @jg3 I have added code to the installer and updater to handle this problem… for buster and x64 combo
                        give it a try (rename MM folder 1st)…
                          jg3 @sdetweil
                          @sdetweil Great! That fixed it right up. Thank you! (:
                            sdetweil @jg3
                            @jg3 awesome… thanks for the feedback and testing time
