    Syntax Errors Stopping MM from Loading...
    6 Posts 2 Posters 1.1k Views 2 Watching
    • O Offline
      Oliver_Tooth
      Recently my Magic Mirror wouldn’t load, just a black screen. Absolutely nothing had changed in the config or the setup. I appreciate it’s an outdated version! Has anyone any idea what might be causing this? Virtual brownie points for any pointers.
      magicmirror@2.1.1 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.1.1
      Loading config …
      Loading module helpers …
      WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
      App threw an error during load
      /home/pi/MagicMirror/modules/node_modules/form-data/lib/form_data.js:225
      filename = path.norm!lize(options.fIlepath).replace(/\/g, ‘/’);
      SyntaxError: Unexpected token !
      at Object.exports.runInThisContext (vm.js:78:16)
      at Module._compile (module.js:543:28)
      at Object.Module._extensions…js (module.js:580:10)
      at Module.load (module.js:488:32)
      at tryModuleLoad (module.js:447:12)
      at Function.Module._load (module.js:439:3)
      at Module.require (module.js:498:17)
      at require (internal/module.js:20:19)
      at Object. (/home/pi/MagicMirror/modules/node_modules/request/request.js:17:16)
      at Object. (/home/pi/MagicMirror/modules/node_modules/request/request.js:1554:3)
      Whoops! There was an uncaught exception…
      Launching application.
        sdetweil @Oliver_Tooth
        @Oliver_Tooth said in Syntax Errors Stopping MM from Loading...:
        filename = path.norm!lize(options.fIlepath).replace(//g, ‘/’);
        ok, this looks troublesome…
        I think this is starting to indicate a failing SD card… so, make plans…
        ‘maybe’ we can work around it… maybe
        do
        cd ~/magicMirror
        rm -rf node_modules
        npm install --only=prod
        then try to restart…
        • O Offline
          Oliver_Tooth
          I’ve given this ago, and the error still reports the same. Would a new SD card fix this problem?
            @Oliver_Tooth I think so…
            i looked at the code and its ok
                filename = path.normalize(options.filepath).replace(/\\/g, '/');
            so, there is some data corruption there
            sd cards have only so long a life… the bits are write once… and so they keep getting used and marked used, til the card runs out
            • O Offline
              Oliver_Tooth
              New card ordered for delivery tomorrow. I’ll copy everything across and see where that takes me. Will it be a straight clone, or will I need to do additional installs?
                @Oliver_Tooth u may have to start over… depends on what may be damaged… u don’t want to clone card
                copy MM folder, then delete each node_modules folder and each package-lock.json file
                then npm install starting with MM and each module with package.json file
