Solved covid bell curve line graph tracker
@sdetweil I’ve just downloaded today, just a few minutes before I tried.
This is what I’m seeing right now with the following config (tried with states now):
{ disabled: false, module:"MyCovid19", position:"top_center", config:{ states:['Kentucky','Colorado','Arizona'], line_colors:['red','white','green','yellow','blue'], chart_type:"cumulative_cases", // or "cumulative deaths" chart_title:"Cumulative Cases", // however u want to label ranges:{min:0,max:8000,stepSize:10000}, width: 200, height: 300, debug: true, }, },
I don’t use any special classes
var c = document.createElement("div"); // < container for chart c.style.width = self.config.width + "px"; c.style.height = self.config.height + "px"; self.wrapper.appendChild(c); canvas = document.createElement("canvas"); // < --- chart itself canvas.id = "myChart" +self.ourID ; canvas.style.width = (self.config.width -10) + "px"; canvas.style.height = self.config.height + "px"; canvas.style.backgroundColor=self.config.backgroundColor; c.appendChild(canvas);
@rafaelcota i don’t see it, but maybe there is a weird character between width and 400
so, take the space out, for both height and width
width:400, height:800,
how big is your screen?
@rafaelcota great work!!..
for grins, edits the MyCovid19.js
line 168ish
if (!self.config.stacked) c.style.display = 'inline-block';
comment out those two lines…
the prior module which I cloned had the ability to generate multiple charts at once,
but how that got set in your instance I have no idea… -
This is what I’ve done so far:I’ve deleted the spaces in height and width and numbers;
I’ve disabled ALL other modules, so this one runs alone;
I’ve commented out those two lines in MyCovid19.jsAnd all still the same…
It just gets the dimensions from wherever it gets them… so weird…
@rafaelcota but now it shouldn’t have inline-block applied, in the elements view
@rafaelcota BTW, my resolution is 1920 x 1080 in an RPI 4
@rafaelcota and I am running this particular test on a 1920x1080 ubuntu… but my pi4 is just behind me at 3840x2160
It still there…
I’m sure you have better things to do than debug this with a user… I’m going to do a clean install, even if it does mean to use the brand new MM version (don’t have much installed, and have lots of time nowadays) and see what happens… -
@rafaelcota use my installer script
see here
