    covid bell curve line graph tracker
    89 Posts 6 Posters 72.7k Views 8 Watching
      now supports states charts too
      git pull,
      in config states:[] vs countries:[]
      alt text
      • rafaelcotaR Offline
        rafaelcota
        Looks great! I’m looking forward in using this module, but I just don’t get the chart dimensions to work, the size is always the same, big, and it doesn’t matter which region I use.
        This is my config
                                    disabled: false,
                                    module:"MyCovid19",
                                    position:"top_left",
                                    config:{
                                            countries:["Mexico"],
                                            line_colors:['red','white','green','yellow','blue'],
                                            chart_type:"cumulative_cases",
                                            chart_title:"Cumulative Cases",
                                            ranges:{min:0,max:10000,stepSize:1000},
                                            startDate: "03/01/2020",
                                            backgroundColor: "transparent",
                                            width: 300,
                                            height: 500,
                                            debug:false,
        And this is the result, I’ll try to attach a screen capture, let’s see if I can!
        alt text
          @rafaelcota hm… I usually have this
          			module:"MyCovid19",
          			disabled:false,
          			config:{
          				states:["Michigan", 'Texas','Illinois', 'Florida','California','Louisiana','Washington','New York',],
          				// line colors can be any definition of color either a name ,or a hex string
          				// one per country above, used in order,
          				line_colors:['red','white','green','yellow','#34ebde','#34eb00','purple','orange'],
          				chart_type:"deaths",  // or "cumulative deaths"
          				chart_title:"daily new deaths by state", // however u want to label
          				// the vertical steps on the chart.. how tall u want it to be and how mant increments
          				ranges:{min:0,max:000,stepSize:10},
          				// size of the chart in pixels
          			    width: 400,
          			    height: 800,
          			    // only used if we need to debug something
          			    //debug:true,
          			    startDate:'03/10/2020',
          			    debug:true,
          			//    startLabel:['2/1/2020','3/1/2020']
          			    //backgroundColor: 'white',
          400x 400 (w x h)
          alt text
          but changed to 400 x 800 (w x h)
          alt text
          rafaelcotaR 1 Reply Last reply Reply Quote 1
            I added the calendar and changed to 300 x 800
            alt text
              rafaelcota @sdetweil
              @sdetweil I know, that’s how it supposed to work, but not in my mirror… It’s driving me crazy… I’ve tried almost everything…
                sdetweil @rafaelcota
                @rafaelcota when was the last time you did a git pull?
                I just used your definition and changed height to 800 and it came out right… (wrong image before)
                alt text
                  @sdetweil I’ve just downloaded today, just a few minutes before I tried.
                  This is what I’m seeing right now with the following config (tried with states now):
                                              disabled: false,
                                              module:"MyCovid19",
                                              position:"top_center",
                                              config:{
                                                      states:['Kentucky','Colorado','Arizona'],
                                                      chart_type:"cumulative_cases",  // or "cumulative deaths"
                                                      chart_title:"Cumulative Cases", // however u want to label
                                                      ranges:{min:0,max:8000,stepSize:10000},
                                                      width: 200,
                                                      height: 300,
                                                      debug: true,
                  alt text
                    I don’t use any special classes
                              var c = document.createElement("div");   // < container for chart
                              c.style.width = self.config.width + "px";
                              c.style.height = self.config.height + "px";
                              self.wrapper.appendChild(c);
                              canvas = document.createElement("canvas");   // < --- chart itself
                              canvas.id = "myChart" +self.ourID ;
                              canvas.style.width = (self.config.width -10) + "px";
                              canvas.style.height = self.config.height + "px";
                              canvas.style.backgroundColor=self.config.backgroundColor;
                              c.appendChild(canvas);
                      @rafaelcota i don’t see it, but maybe there is a weird character between width and 400
                      so, take the space out, for both height and width
                      width:400,
                      height:800,
                      how big is your screen?
                        @rafaelcota great work!!..
                        for grins, edits the MyCovid19.js
                        line 168ish
                                  if (!self.config.stacked)
                                    c.style.display = 'inline-block';
                        comment out those two lines…
                        the prior module which I cloned had the ability to generate multiple charts at once,
                        but how that got set in your instance I have no idea…
                        rafaelcotaR 1 Reply Last reply Reply Quote 0
                          This is what I’ve done so far:
                          I’ve deleted the spaces in height and width and numbers;
                          I’ve disabled ALL other modules, so this one runs alone;
                          I’ve commented out those two lines in MyCovid19.js
                          And all still the same…
                          It just gets the dimensions from wherever it gets them… so weird…
                          S rafaelcotaR 2 Replies Last reply Reply Quote 0
                            @rafaelcota but now it shouldn’t have inline-block applied, in the elements view
                              rafaelcota @rafaelcota
                              @rafaelcota BTW, my resolution is 1920 x 1080 in an RPI 4
                                @rafaelcota and I am running this particular test on a 1920x1080 ubuntu… but my pi4 is just behind me at 3840x2160
                                  It still there…
                                  I’m sure you have better things to do than debug this with a user… I’m going to do a clean install, even if it does mean to use the brand new MM version (don’t have much installed, and have lots of time nowadays) and see what happens…
                                  alt text
                                  S A 2 Replies Last reply Reply Quote 0
                                    @rafaelcota use my installer script
                                    see here
                                      @sdetweil Thank you…
                                      Used them… worked well.
                                      Did a clean install, use my old config and same thing happened.
                                      Change my config.js with original+MyCovid19 and ALL OK!
                                      So, I changed the original config.js with my modules, one by one and ALL went OK.
                                      So, I got curious, and then went to change the original config.js to my old one, module by module so I could find which one was interfering, and ALL went OK.
                                      UNTIL, and this is really strange, when I change the address of localhost at the beginning, it went to the same problem again.
                                      If I have address: “localhost”, ALL is OK
                                      If I have address: “0.0.0.0”, then the problem appears again.
                                      Any ideas?
                                      Here’s my mirror working OK
                                      alt text
                                      S B 2 Replies Last reply Reply Quote 0
                                        @rafaelcota said in covid bell curve line graph tracker:
                                        and
                                        ipWhitelist:[],
                                          @sdetweil I don’t understand how this parameters relate with the size of a graph.
                                          I think it’s weird, at least it kept me entertained for a couple of hours in quarantine. :)
                                          I hope you and your family and friends are OK.
                                            @rafaelcota all ok here…
                                            i have no idea really on the parms affecting… all my pi systems use address:“0.0.0.0” and ipWhitelist:[]
                                            so I can open their pages on my pc at my desk. (easier to debug modules this way, run there , debug here)
                                            i can only think that something in the chart.js library is trying to get a file or something and there is a cross site scripting restriction to stop it…
                                            • 2 / 5
