    covid bell curve line graph tracker
    89 Posts 6 Posters 73.8k Views 8 Watching
      another fix for refresh (starting after midnight , but no data available yet left a blank display)…
      also fixed to add two more charts
      new cases and new deaths by day
      new cases for the US ‘may’ show effect of distancing… need more days
      (or maybe not, one day drop)
      todays data, 2020-03-26, is still not yet posted…(as of 8:40 am central time us)
      2020-03-26 data has arrived, 08:56 us central time, (and update worked!)
      alt text
      A 1 Reply Last reply Reply Quote 1
        almostgithub @sdetweil
        @sdetweil kind of a simple question, but i cannot for the life of me figure out how to change the color of the dates, and the countries names to white?? I looked everywhere and tried my custom css file to no avail…
          sdetweil @almostgithub
          @almostgithub >change the color of the dates, and the countries names to white??
          sorry, don’t understand… they are white already (not bright white)
          I currently don’t provide access to those settings…
          this is all controlled by the charting library I am using…
          I would have to add settings to enable access
            @almostgithub Ok I’ve added some.
            git pull in the module folder,
            here are the things u can set… will get to the doc in the morning
                legendTextColor:'white',
                chartTitleColor: 'white',
                chart_title: '',
                xAxisLabel:"by date",
                xAxisLabelColor:'white',
                xAxisTickLabelColor:'white',
                yAxisLabel:"Count",
                yAxisLabelColor:'white',
                yAxisTickLabelColor:'white',
              @sdetweil oh wow! Thanks so much, thats awesome!! They are grey on my mirror and makes it hard to read the legend and dates.
              edit: after a git pull and npm install, it seems to be stuck on MyCovid19 Loading data for chart “cumulative_deaths”
              edit: Saw this in the issues tab, will ask there
                new update, data source changed … after git pull, need to run npm install again to update the library used to read the data (csv instead of xlsx)
                • H Offline
                  humdinger44 @sdetweil
                  @sdetweil can you drop an example of the config for two graphs displayed at once?
                  Edit: nevermind, I was overthinking it.
                    grrr… data source not yet updated today… waiting, sent them a note…
                    I switched to the csv file (available earlier)…
                    now xlsx is right, csv, json and xml files not updated… and in the xlsx, they changed the column headings…
                      @sdetweil after sending email, they have updated the csv file now…
                      also, uploaded new version with lots of text formatting control, see the now long readme
                      also added ability to change the start date for the chart, see startDate in the readme
                        now supports states charts too
                        git pull,
                        in config states:[] vs countries:[]
                        alt text
                        • rafaelcotaR Offline
                          rafaelcota
                          Looks great! I’m looking forward in using this module, but I just don’t get the chart dimensions to work, the size is always the same, big, and it doesn’t matter which region I use.
                          This is my config
                                                      disabled: false,
                                                      module:"MyCovid19",
                                                      position:"top_left",
                                                      config:{
                                                              countries:["Mexico"],
                                                              line_colors:['red','white','green','yellow','blue'],
                                                              chart_type:"cumulative_cases",
                                                              chart_title:"Cumulative Cases",
                                                              ranges:{min:0,max:10000,stepSize:1000},
                                                              startDate: "03/01/2020",
                                                              backgroundColor: "transparent",
                                                              width: 300,
                                                              height: 500,
                                                              debug:false,
                          And this is the result, I’ll try to attach a screen capture, let’s see if I can!
                          alt text
                            @rafaelcota hm… I usually have this
                            			module:"MyCovid19",
                            			disabled:false,
                            			config:{
                            				states:["Michigan", 'Texas','Illinois', 'Florida','California','Louisiana','Washington','New York',],
                            				// line colors can be any definition of color either a name ,or a hex string
                            				// one per country above, used in order,
                            				line_colors:['red','white','green','yellow','#34ebde','#34eb00','purple','orange'],
                            				chart_type:"deaths",  // or "cumulative deaths"
                            				chart_title:"daily new deaths by state", // however u want to label
                            				// the vertical steps on the chart.. how tall u want it to be and how mant increments
                            				ranges:{min:0,max:000,stepSize:10},
                            				// size of the chart in pixels
                            			    width: 400,
                            			    height: 800,
                            			    // only used if we need to debug something
                            			    //debug:true,
                            			    startDate:'03/10/2020',
                            			    debug:true,
                            			//    startLabel:['2/1/2020','3/1/2020']
                            			    //backgroundColor: 'white',
                            400x 400 (w x h)
                            alt text
                            but changed to 400 x 800 (w x h)
                            alt text
                            rafaelcotaR 1 Reply Last reply Reply Quote 1
                              I added the calendar and changed to 300 x 800
                              alt text
                                rafaelcota @sdetweil
                                @sdetweil I know, that’s how it supposed to work, but not in my mirror… It’s driving me crazy… I’ve tried almost everything…
                                  sdetweil @rafaelcota
                                  @rafaelcota when was the last time you did a git pull?
                                  I just used your definition and changed height to 800 and it came out right… (wrong image before)
                                  alt text
                                    @sdetweil I’ve just downloaded today, just a few minutes before I tried.
                                    This is what I’m seeing right now with the following config (tried with states now):
        disabled: false,
        module:"MyCovid19",
        position:"top_center",
        config:{
        states:['Kentucky','Colorado','Arizona'],
        chart_type:"cumulative_cases",  // or "cumulative deaths"
        chart_title:"Cumulative Cases", // however u want to label
        ranges:{min:0,max:8000,stepSize:10000},
        width: 200,
        height: 300,
        debug: true,
                                    alt text
                                      I don’t use any special classes
                                                var c = document.createElement("div");   // < container for chart
                                                c.style.width = self.config.width + "px";
                                                c.style.height = self.config.height + "px";
                                                self.wrapper.appendChild(c);
                                                canvas = document.createElement("canvas");   // < --- chart itself
                                                canvas.id = "myChart" +self.ourID ;
                                                canvas.style.width = (self.config.width -10) + "px";
                                                canvas.style.height = self.config.height + "px";
                                                canvas.style.backgroundColor=self.config.backgroundColor;
                                                c.appendChild(canvas);
                                        @rafaelcota i don’t see it, but maybe there is a weird character between width and 400
                                        so, take the space out, for both height and width
                                        width:400,
                                        height:800,
                                        how big is your screen?
                                          @rafaelcota great work!!..
                                          for grins, edits the MyCovid19.js
                                          line 168ish
                                                    if (!self.config.stacked)
                                                      c.style.display = 'inline-block';
                                          comment out those two lines…
                                          the prior module which I cloned had the ability to generate multiple charts at once,
                                          but how that got set in your instance I have no idea…
                                          rafaelcotaR 1 Reply Last reply Reply Quote 0
                                            This is what I’ve done so far:
                                            I’ve deleted the spaces in height and width and numbers;
                                            I’ve disabled ALL other modules, so this one runs alone;
                                            I’ve commented out those two lines in MyCovid19.js
                                            And all still the same…
                                            It just gets the dimensions from wherever it gets them… so weird…
                                            S rafaelcotaR 2 Replies Last reply Reply Quote 0
                                            • 2 / 5
