    covid bell curve line graph tracker
    89 Posts 6 Posters 72.7k Views 8 Watching
      sdetweil @almostgithub
      @almostgithub >change the color of the dates, and the countries names to white??
      sorry, don’t understand… they are white already (not bright white)
      I currently don’t provide access to those settings…
      this is all controlled by the charting library I am using…
      I would have to add settings to enable access
        @almostgithub Ok I’ve added some.
        git pull in the module folder,
        here are the things u can set… will get to the doc in the morning
            legendTextColor:'white',
            chartTitleColor: 'white',
            chart_title: '',
            xAxisLabel:"by date",
            xAxisLabelColor:'white',
            xAxisTickLabelColor:'white',
            yAxisLabel:"Count",
            yAxisLabelColor:'white',
            yAxisTickLabelColor:'white',
          almostgithub @sdetweil
          @sdetweil oh wow! Thanks so much, thats awesome!! They are grey on my mirror and makes it hard to read the legend and dates.
          edit: after a git pull and npm install, it seems to be stuck on MyCovid19 Loading data for chart “cumulative_deaths”
          edit: Saw this in the issues tab, will ask there
            new update, data source changed … after git pull, need to run npm install again to update the library used to read the data (csv instead of xlsx)
            • H Offline
              humdinger44 @sdetweil
              @sdetweil can you drop an example of the config for two graphs displayed at once?
              Edit: nevermind, I was overthinking it.
                grrr… data source not yet updated today… waiting, sent them a note…
                I switched to the csv file (available earlier)…
                now xlsx is right, csv, json and xml files not updated… and in the xlsx, they changed the column headings…
                  @sdetweil after sending email, they have updated the csv file now…
                  also, uploaded new version with lots of text formatting control, see the now long readme
                  also added ability to change the start date for the chart, see startDate in the readme
                    now supports states charts too
                    git pull,
                    in config states:[] vs countries:[]
                    alt text
                    • rafaelcotaR Offline
                      rafaelcota
                      Looks great! I’m looking forward in using this module, but I just don’t get the chart dimensions to work, the size is always the same, big, and it doesn’t matter which region I use.
                      This is my config
                                                  disabled: false,
                                                  module:"MyCovid19",
                                                  position:"top_left",
                                                  config:{
                                                          countries:["Mexico"],
                                                          line_colors:['red','white','green','yellow','blue'],
                                                          chart_type:"cumulative_cases",
                                                          chart_title:"Cumulative Cases",
                                                          ranges:{min:0,max:10000,stepSize:1000},
                                                          startDate: "03/01/2020",
                                                          backgroundColor: "transparent",
                                                          width: 300,
                                                          height: 500,
                                                          debug:false,
                      And this is the result, I’ll try to attach a screen capture, let’s see if I can!
                      alt text
                        @rafaelcota hm… I usually have this
                        			module:"MyCovid19",
                        			disabled:false,
                        			config:{
                        				states:["Michigan", 'Texas','Illinois', 'Florida','California','Louisiana','Washington','New York',],
                        				// line colors can be any definition of color either a name ,or a hex string
                        				// one per country above, used in order,
                        				line_colors:['red','white','green','yellow','#34ebde','#34eb00','purple','orange'],
                        				chart_type:"deaths",  // or "cumulative deaths"
                        				chart_title:"daily new deaths by state", // however u want to label
                        				// the vertical steps on the chart.. how tall u want it to be and how mant increments
                        				ranges:{min:0,max:000,stepSize:10},
                        				// size of the chart in pixels
                        			    width: 400,
                        			    height: 800,
                        			    // only used if we need to debug something
                        			    //debug:true,
                        			    startDate:'03/10/2020',
                        			    debug:true,
                        			//    startLabel:['2/1/2020','3/1/2020']
                        			    //backgroundColor: 'white',
                        400x 400 (w x h)
                        alt text
                        but changed to 400 x 800 (w x h)
                        alt text
                        rafaelcotaR 1 Reply Last reply Reply Quote 1
                          I added the calendar and changed to 300 x 800
                          alt text
                            rafaelcota @sdetweil
                            @sdetweil I know, that’s how it supposed to work, but not in my mirror… It’s driving me crazy… I’ve tried almost everything…
                              sdetweil @rafaelcota
                              @rafaelcota when was the last time you did a git pull?
                              I just used your definition and changed height to 800 and it came out right… (wrong image before)
                              alt text
                                @sdetweil I’ve just downloaded today, just a few minutes before I tried.
                                This is what I’m seeing right now with the following config (tried with states now):
                                                            disabled: false,
                                                            module:"MyCovid19",
                                                            position:"top_center",
                                                            config:{
        states:['Kentucky','Colorado','Arizona'],
        chart_type:"cumulative_cases",  // or "cumulative deaths"
        chart_title:"Cumulative Cases", // however u want to label
        ranges:{min:0,max:8000,stepSize:10000},
        width: 200,
        height: 300,
        debug: true,
                                alt text
                                  I don’t use any special classes
                                            var c = document.createElement("div");   // < container for chart
                                            c.style.width = self.config.width + "px";
                                            c.style.height = self.config.height + "px";
                                            self.wrapper.appendChild(c);
                                            canvas = document.createElement("canvas");   // < --- chart itself
                                            canvas.id = "myChart" +self.ourID ;
                                            canvas.style.width = (self.config.width -10) + "px";
                                            canvas.style.height = self.config.height + "px";
                                            canvas.style.backgroundColor=self.config.backgroundColor;
                                            c.appendChild(canvas);
                                    @rafaelcota i don’t see it, but maybe there is a weird character between width and 400
                                    so, take the space out, for both height and width
                                    width:400,
                                    height:800,
                                    how big is your screen?
                                      @rafaelcota great work!!..
                                      for grins, edits the MyCovid19.js
                                      line 168ish
                                                if (!self.config.stacked)
                                                  c.style.display = 'inline-block';
                                      comment out those two lines…
                                      the prior module which I cloned had the ability to generate multiple charts at once,
                                      but how that got set in your instance I have no idea…
                                      rafaelcotaR 1 Reply Last reply Reply Quote 0
                                        This is what I’ve done so far:
                                        I’ve deleted the spaces in height and width and numbers;
                                        I’ve disabled ALL other modules, so this one runs alone;
                                        I’ve commented out those two lines in MyCovid19.js
                                        And all still the same…
                                        It just gets the dimensions from wherever it gets them… so weird…
                                        S rafaelcotaR 2 Replies Last reply Reply Quote 0
                                          @rafaelcota but now it shouldn’t have inline-block applied, in the elements view
                                            rafaelcota @rafaelcota
                                            @rafaelcota BTW, my resolution is 1920 x 1080 in an RPI 4
                                            • 2 / 5
