    Update the mirror for the first time in six months, won't start now
    9 Posts 3 Posters 1.0k Views 2 Watching
      @redink can I ask what device u are loading on? Pi 3?
      in addition to what @Stoffbeuteluwe posted, I suggest you use my updater script from
      upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
      it should handle all the work… and give you a trial run of all that…
      only applying changes if u request them
      give it a try this works on Mac as well
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      no changes are made to the local repo or the working copy
      if you WANT to actually apply the changes do
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      if you have already done the git pull, you will need to use force to get the script update the same version
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
      there is a log file (upgrade.log) in the MagicMirror/installers folder…
        redink
        Messed with it too much and broke something. Time for another fresh install.
        Sigh…
        Every time I update the mirror, something breaks.
        @sdetweil, I’ll be trying your install script and update script from now on. Hopefully it will be a smoother experience that usual.
        This is why I’ve never built a MagicMirror as a gift. I can barely maintain my own mirror.
          sdetweil @redink
          @redink sorry, it is a delicate thing…
          let us know how it goes
            redink
            Well, I managed to get it up and running, and the script you provided seems to be a lot less finicky that my last install process. However, one of my modules MMM-CalendarExt is currently not showing. Trying to troubleshoot this, but here’s the log in case anyone wants to help out.
            pi@raspberrypi:~/MagicMirror/modules $ cat /home/pi/.npm/_logs/2020-04-10T02_27_39_057Z-debug.log
            1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'start' ]
            2 info using npm@6.14.4
            3 info using node@v10.15.2
            5 info lifecycle magicmirror@2.11.0~prestart: magicmirror@2.11.0
            6 info lifecycle magicmirror@2.11.0~start: magicmirror@2.11.0
            7 verbose lifecycle magicmirror@2.11.0~start: unsafe-perm in lifecycle true
            8 verbose lifecycle magicmirror@2.11.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
            9 verbose lifecycle magicmirror@2.11.0~start: CWD: /home/pi/MagicMirror
            10 silly lifecycle magicmirror@2.11.0~start: Args: [ '-c',
            10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
            11 silly lifecycle magicmirror@2.11.0~start: Returned: code: 1  signal: null
            12 info lifecycle magicmirror@2.11.0~start: Failed to exec start script
            13 verbose stack Error: magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            13 verbose stack Exit status 1
            13 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
            13 verbose stack     at EventEmitter.emit (events.js:189:13)
            13 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
            13 verbose stack     at ChildProcess.emit (events.js:189:13)
            13 verbose stack     at maybeClose (internal/child_process.js:970:16)
            13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
            14 verbose pkgid magicmirror@2.11.0
            15 verbose cwd /home/pi/MagicMirror
            16 verbose Linux 4.19.97-v7+
            17 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "start"
            18 verbose node v10.15.2
            19 verbose npm  v6.14.4
            20 error code ELIFECYCLE
            21 error errno 1
            22 error magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            22 error Exit status 1
            23 error Failed at the magicmirror@2.11.0 start script.
            23 error This is probably not a problem with npm. There is likely additional logging output above.
            24 verbose exit [ 1, true ]
              sdetweil @redink
              @redink that log says MagicMirror can’t start
                redink
                Never mind, it’s too late, and my brain isn’t working.
                I had the module commented out :(
                Still, I am seeing those errors in my logs.
                  sdetweil @redink
                  @redink it does not erase the prior logs
                  To do that pm2 flush
                  Then start again
