    Update the mirror for the first time in six months, won't start now
    9 Posts 3 Posters 1.2k Views 2 Watching
      redink
      I updated MagicMirror as well as all the modules using git pull. I then ran npm update. Now my mirror is blank. Here are some errors I am seeing. I’d appreciate any help.
      pi@raspberrypi:~/MagicMirror $ cat /home/pi/.npm/_logs/2020-04-08T15_04_37_921Z-debug.log
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.4.1
      3 info using node@v10.14.1
      5 info lifecycle magicmirror@2.11.0~prestart: magicmirror@2.11.0
      6 info lifecycle magicmirror@2.11.0~start: magicmirror@2.11.0
      7 verbose lifecycle magicmirror@2.11.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.11.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.11.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.11.0~start: Args: [ '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
      11 info lifecycle magicmirror@2.11.0~start: Failed to exec start script
      12 verbose stack Error: magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      12 verbose stack spawn ENOENT
      12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
      12 verbose stack     at ChildProcess.emit (events.js:182:13)
      12 verbose stack     at maybeClose (internal/child_process.js:962:16)
      12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
      13 verbose pkgid magicmirror@2.11.0
      14 verbose cwd /home/pi/MagicMirror
      15 verbose Linux 4.14.79-v7+
      16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      17 verbose node v10.14.1
      18 verbose npm  v6.4.1
      19 error file sh
      20 error code ELIFECYCLE
      21 error errno ENOENT
      22 error syscall spawn
      23 error magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      23 error spawn ENOENT
      24 error Failed at the magicmirror@2.11.0 start script.
      24 error This is probably not a problem with npm. There is likely additional logging output above.
      25 verbose exit [ 1, true ]
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @redink
        @redink git pull & npm install
          @redink can I ask what device u are loading on? Pi 3?
          in addition to what @Stoffbeuteluwe posted, I suggest you use my updater script from
          upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
          it should handle all the work… and give you a trial run of all that…
          only applying changes if u request them
          give it a try this works on Mac as well
          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
          no changes are made to the local repo or the working copy
          if you WANT to actually apply the changes do
          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
          if you have already done the git pull, you will need to use force to get the script update the same version
          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
          there is a log file (upgrade.log) in the MagicMirror/installers folder…
            redink
            Messed with it too much and broke something. Time for another fresh install.
            Sigh…
            Every time I update the mirror, something breaks.
            @sdetweil, I’ll be trying your install script and update script from now on. Hopefully it will be a smoother experience that usual.
            This is why I’ve never built a MagicMirror as a gift. I can barely maintain my own mirror.
              sdetweil @redink
              @redink sorry, it is a delicate thing…
              let us know how it goes
                redink
                Well, I managed to get it up and running, and the script you provided seems to be a lot less finicky that my last install process. However, one of my modules MMM-CalendarExt is currently not showing. Trying to troubleshoot this, but here’s the log in case anyone wants to help out.
                pi@raspberrypi:~/MagicMirror/modules $ cat /home/pi/.npm/_logs/2020-04-10T02_27_39_057Z-debug.log
                1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'start' ]
                2 info using npm@6.14.4
                3 info using node@v10.15.2
                8 verbose lifecycle magicmirror@2.11.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                11 silly lifecycle magicmirror@2.11.0~start: Returned: code: 1  signal: null
                12 info lifecycle magicmirror@2.11.0~start: Failed to exec start script
                13 verbose stack Error: magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                13 verbose stack Exit status 1
                13 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                13 verbose stack     at EventEmitter.emit (events.js:189:13)
                13 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                13 verbose stack     at ChildProcess.emit (events.js:189:13)
                13 verbose stack     at maybeClose (internal/child_process.js:970:16)
                13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                14 verbose pkgid magicmirror@2.11.0
                15 verbose cwd /home/pi/MagicMirror
                16 verbose Linux 4.19.97-v7+
                17 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "start"
                18 verbose node v10.15.2
                19 verbose npm  v6.14.4
                21 error errno 1
                22 error magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                22 error Exit status 1
                23 error Failed at the magicmirror@2.11.0 start script.
                23 error This is probably not a problem with npm. There is likely additional logging output above.
                24 verbose exit [ 1, true ]
                  sdetweil @redink
                  @redink that log says MagicMirror can’t start
                    redink
                    Never mind, it’s too late, and my brain isn’t working.
                    I had the module commented out :(
                    Still, I am seeing those errors in my logs.
                      sdetweil @redink
                      @redink it does not erase the prior logs
                      To do that pm2 flush
                      Then start again
