Cannot Access via HTTP even on MM Pi Device itself
4 Posts 2 Posters 280 Views 2 Watching
    STS
    I just installed MM on a Pi 3B that also has PiHole on it. I can access the PiHole HTTP server without issue, but even when connected directly to the Pi console (or via RDP) I am unable to access the website. I am looking to troubleshoot before putting into production, but I’m unable to do so no matter which port I try… Currently the network config section is wide open:
    address: “0.0.0.0, ::”,
    port: 88,
    ipWhitelist: [],
    Any help would be most appreciated! Thank you
    S 1 Reply Last reply Apr 11, 2020, 3:46 AM Reply Quote 0
      sdetweil @STS
      @STS address:“0.0.0.0”
      Nothing else
        STS
        Thanks @sdetweil however that doesn’t work for me. Still getting a generic Connection_refused message in Chromium on the actual Pi and no connection from my workstation.
        S 1 Reply Last reply Apr 11, 2020, 11:39 AM Reply Quote 0
          sdetweil @STS
          @STS you are getting the server startup message, right
          Starting server on port 8080 …
          you could also do temporarliy,
          node serveronly
          instead of npm start
          and it will announce the address as well…
