    IR Touch Frame calibration
    17 Posts 8 Posters 15.1k Views 9 Watching
      cyberphox
      Xinput calibrator should help
      peemoellerP 1 Reply Last reply
      • peemoellerP
        peemoeller @cyberphox
        @cyberphox thanks! Are you able to point me on how to make the adjustments? I have xinput installed but not sure where to go from here.
        Thanks for your help!
          cyberphox
          run the calibration from the menu…touch the points and that’s it!
          • peemoellerP
            @cyberphox Hi there, ok! I now managed to get my IR Touch Overlay set to portrait! also just finished running the xinput touch calibrator program under ‘Preferences’ (it had me touch the 4 red crosses). It shows:
            < Calibrating standard Xorg driver “Multi touch overlay device” current calibration values: min_x=0, max_x=65535 and min_y=0, max_y=65535
            If these values are estimating wrong, either supply it manually with the - -precalib option, or run the ‘get_precalib.sh’ script to automatically get it (through HAL). >
            My issue, I find the curser doesn’t reach the the edges of my monitor. Example I can’t simply click on the Raspberry Icon in the corner. The curser is diaginally 2 inches away? I have a 42 inch IR Touch Overlay using a 32 inch LCD monitor.
            Where can I set or adjust this? Any thoughts?
            Fun!
            K 1 Reply Last reply
            • K
              klimbo @peemoeller
              @peemoeller said in IR Touch Frame calibration:
              Fun!
              i ask the same question my bro
                Bruno
                @klimbo said in IR Touch Frame calibration:
                So, has anyone found a solution for this?
                I have a 32 inches mirror (and 32 inches touch frame) in a 18 inches screen. Since the touchframe is bigger than the screen i couldn’t find a way to calibrate it to just work on the 18 inches screen area (as I do when I calibrate it on Windows).
                Does anyone have any thoughts on how to do this?
                Thanks.
                  Bruno
                  Here is a few more information.
                  The picture below shows my mirror (with the 18’’ screen) and the 32’’ touch frame above it.
                  (This is just a test mirror, that’s why the touch frame doesn’t match the mirror frame. And just ignore the painted part… it’s just some information i can’t share)
                  Before calibrating it, the 18’’ screen is “mapped” to the whole 32’’ touch frame. That’s expected.
                  ![alt text](0_1583708443439_IMG_20200308_194221.jpg image url)
                  What I need to do is calibrate it so the only part of the touch frame that will recognize the touch is the area of the 18’’ screen.
                  I run the command
                  DISPLAY=:0.0 xinput_calibrator
                  Then I calibrate the screen, like the picture below (clicking the four points)
                  The output of the command is:
                  Calibrating standard Xorg driver "Touch Device FC315WH00DL-CT-B2-20P"
                          If these values are estimated wrong, either supply it manually with the --precalib option, or run the 'get_precalib.sh' script to automatically get it (through HAL).
                  --> Making the calibration permanent
                    copy the snippet below into '/etc/X11/xorg.conf.d/99-calibration.conf'
                  Section "InputClass"
                          Identifier      "calibration"
                          MatchProduct    "Touch Device FC315WH00DL-CT-B2-20P"
                          Option  "MinX"  "8770"
                          Option  "MaxX"  "46111"
                          Option  "MinY"  "5539"
                          Option  "MaxY"  "40880"
                  EndSection
                  But nothing changes… when I touch the screen again, the same thing is happening: the 18’’ screen is “mapped” for the whole 32’’ touchframe, not just the area of the 18’’ screen.
                  I tried saving the code above both on /etc/X11/xorg.conf.d/99-calibration.conf and modifying the values of Min/Max X/Y (like changing from 46111 to 2000) but absolutely nothing changes… I think the touchframe is not using these values for anything.
                  When I use the same touchframe on windows and use the calibration tool, it map my 21’’ PC monitor correctly for the 32’’ touch frame.
                  I’ve been struggling with this for a few days and I see that a lot of people is having/had the same problem. Does anyone know a solution for this?
                  Thanks.
                    Bruno
                    Ok, after a lot of hours searching and testing i finally figured it out.
                    Forget about all that getting the values for minX, maxX, minY and maxY that all the sites talk about. Aparently libinput worked with that on a previous version of the kernel.
                    What you have to do is change the values of the parameter “libinput Calibration Matrix”
                    Steps:
                    1. find your devices name (or id) with the command
                    "xinput"
                    If it fails with a message “Unable to connect to X server” just use before.
                    export DISPLAY=:0.0
                    Write down your devices name and id
                    1. Reset your devices calibration matrix:
                    xinput set-prop "YOUR_DEVICES_NAME" "libinput Calibration Matrix" 1 0 0 0 1 0 0 0 1
                    (Obs: this “virgin” matrix above is for the screen WITHOUT ANY ROTATION. Just plain landscape mode, aka, “display_rotate=0” on /boot/config.txt
                    I’ll talk about rotation below)
                    1. Start xinput_calibrator on verbose mode:
                    xinput_calibrator -v
                    Click the points on the screen and you should se something like this on the output:
                    DEBUG: Adding click 0 (X=181, Y=132)
                    DEBUG: Adding click 1 (X=862, Y=129)
                    DEBUG: Adding click 2 (X=186, Y=661)
                    DEBUG: Adding click 3 (X=868, Y=665)
                    We’ll need only the click0 and click3 X and Y
                    1. Get your screen current resolution:
                    xrandr | grep current
                    You’ll see something like:
                    Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
                    1. Calculate the values for A, B, C and F:
                      a = (screen_width * 6 / 8 ) / (click_3_X - click_0_X)
                      c = ((screen_width / 8 ) - (a * click_0_X)) / screen_width
                      e = (screen_height * 6 / 8 ) / (click_3_Y - click_0_Y)
                      f = ((screen_height / 8 ) - (e * click_0_Y)) / screen_height
                    On my case I made excel formulas, but was something like:
                    a = (1920 * 6 / 8 ) / (868 - 181) = 2,09606
                    c = ((1920 / 8 ) - (2,09606 * 181)) / 1920 = -0,07260
                    e = (1080 * 6 / 8 ) * (665 - 132) = 1,51970
                    f = ((1080 / 8 ) - (1,51970 * 132)) / 1080 = -0.06074
                    (I have no idea why they use those letters or where the hell these formulas came from… if you wanna know, more I got it from here: https://wiki.archlinux.org/index.php/Calibrating_Touchscreen )
                    1. Then set the new Calibration Matrix using the values above with the command:
                    xinput set-prop "YOUR_DEVICES_NAME" "libinput Calibration Matrix" a 0 c 0 e f 0 0 1
                    There you go. Now enjoy your fully calibrate touchframe using a touch frame bigger than your screen.
                    1. To make it permanent:
                      Create the file: /etc/X11/xorg.conf.d/99-calibration.conf and paste this:
                            MatchProduct "YOUR_DEVICES_NAME"
                            Option "TransformationMatrix" "a 0.0 c 0.0 e f 0.0 0.0 1.0"
                    EndSection
                    (of course change your devices name and the values for a, c, e and f)
                    About rotating the screen
                    Well, I think I can’t help you guys much with this, since I don’t even know what I did to make it work. When you rotate the screen (display_rotate=X on /boot/config.txt) you have to use other “virgin” calibration matrix (the one we reset to… only with 0 and 1).
                    If you wanna know more: maybe this site will help https://wayland.freedesktop.org/libinput/doc/1.11.3/absolute_axes.html
                    I am using display_rotate=1
                    So the “new matrix” is:
                    0.0 1.0 0.0 -1.0 0.0 1.0 0.0 0.0 1.0
                    (I had to put ‘.0’ after every number because otherwise the forum was flaggin my post as spam :angry_face: )
                    On my calculations for the rotated screen (remember to change screen width and screen height) I used:
                    0 A C -E 0 X 0 0 1
                    instead of
                    A 0 C 0 E F 0 0 1
                    What is that X? Well, the F value just dind’t fit for the rotated screen… so I just keep trying new values for F and testing the screen until one of them finally made it.
                    Well, I hope it helps somebody.
                    See ya.
                      Bruno
                      Actually, the first link should be: https://wiki.archlinux.org/index.php/Talk:Calibrating_Touchscreen
                      I couldnt edit my post anymore because the forum is still thinking this is spam…
                        mrSnatz
                        Thank you for your instructions. Unfortunately, this does not work for me. I have a 42 “frame over a 32” monitor.
                        The monitor is only a part of the touch frame area.
                        According to your instructions, no error message appears, but the ratio does not fit in the calibration. Do you have a tip for me here?
