Wit.ai Parsing error
6 Posts 3 Posters 929 Views 2 Watching
    Mahieedaboss
    So,
    I have looked on Google and various repos but my problem still stands,
    Wit.ai failed parsing app.json
    I edited this because another person said to but there is still the problem. I pasted app.json into JSONLint and it was valid. Please help
    on raspberry pi3 btw
    M 1 Reply Last reply Apr 13, 2020, 3:55 PM Reply Quote 0
      Mahieedaboss @Mahieedaboss
      @Mahieedaboss
      Maybe I should have explained a bit more:
      I was following the yt vid by HackerShack and got to the bit where he creates an app using wit.ai. In this, he presses New app+ and then types a name, description and as his bkup file, inserts wit_training_data.zip
      this can be found at
      https://github.com/HackerShackOfficial/AI-Smart-Mirror/tree/master/models
      I pressed +create app and then the error popped up “failed parsing app.json”
      I troubleshooted and found this:
      https://github.com/wit-ai/wit/issues/1538
      I try to change
      “zip-command”: “zip smart-mirror.zip smart-mirror/app.json smart-mirror/entities/.json smart-mirror/actions.json smart-mirror/stories.json smart-mirror/expressions.json”,
      to
      but i still get the error notification. any suggestion?
      Like many others, this change did not work.
      I copied the saved contents off app.json into
      https://jsonlint.com/
      and the json was valid
      what do i do??
        Mahieedaboss
        Right,Update
        I solved this issue
        1.Extract files from “smart-mirror”
        2.edit app.json:
        “version” : 20160513,
        “zip-command” : “zip smart-mirror.zip smart-mirror/app.json smart-mirror/entities/*.json smart-mirror/actions.json smart-mirror/stories.json smart-mirror/expressions.json”,
        “data” : {
        “name” : “smart-mirror”,
        “description” : “smart mirror assistant”,
        “lang” : “en”
        BECOMES
        “data” : {
        “lang” : “en”,
        “timezone”: “Europe/London”
        1. Compress the newly updated “smart-mirror” file
        2. Do the whole wit.ai thing but insert this new zip
        I’m pretty sure this should work
        New problem
        Failed parsing entities/
        I guess we have to edit some more but what exactly??
        S 1 Reply Last reply Apr 13, 2020, 10:01 PM Reply Quote 0
        • S Away
          sdetweil @Mahieedaboss
          @Mahieedaboss is the entities folder in the new zip file?
            Mahieedaboss
            yes it is
            • T Offline
              thepythonscript
              hey, so I did what you said to do and got the error parsing app.json could you leave a direct link to the compressed file, it would help a lot Thanks!
