    .txt file include
    59 Posts 6 Posters 45.2k Views 6 Watching
      banbutcher
      hi,
      sorry to be dragging up old posts, but im trying to get my mirror to display the contents of a txt file and i have it partly working… i have the contents displaying on my mirror but its all showing up on one line, how can i display it with each line break as in txt file?
      thanks
        sdetweil @banbutcher
        @banbutcher you will have to replace the line feeds (\n) with html breaks (
          banbutcher
          hi again,
          im after getting my script to update my txt file with the names of downloaded movies and tv series… how would i go about reading the title of the series and just having the title and info ie:
          if title has S**E** in it then
          filename - Archer S01E01pilot 1080p x265.mkv
          desired result - Archer S01E01
          else its a movie and just add movie name
          i think this is the bit of code im to edit but i havent got it working :(
          	getDom: function(){
          		if(this.dataFile){
                                  var meldungRegExp = /Meldung (.*?) /ig;
                                  var meldung = meldungRegExp.exec(this.dataFile)[1];
                                  var zoneRegExp = /Zone (.*?) /ig;
                                  var zone = zoneRegExp.exec(this.dataFile)[1];
          			var zeitRegExp = /Zeit (.*?) /ig;
          			var zeit = zeitRegExp.exec(this.dataFile)[1];
          			wrapper.innerHTML = "Meldung: " + meldung + " Zone: " + zone + " Zeit: " + zeit;
          		} else {
          			wrapper.innerHTML = "No Data";
          		return wrapper;
          thanks
          Richie
            @banbutcher said in .txt file include:
            using the regex tester,
            https://regex101.com/
            I think this is the regex u want
            /.*[S][(0-9)]+[E][(0-9)]+/
              banbutcher
              that worked great…
              however, im a little bit stuck again… your expression works fine and return the correct result but only on the first line of the file and only if i remove the [1] from the end of line 5 of the code
              	getDom: function(){
              		if(this.dataFile){
                                      var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/ig;
                                      var split = splitRegExp.exec(this.dataFile)[1];
              			wrapper.innerHTML = split;
              		} else {
              		return wrapper;
              do i need to stick it in some kind of loop? or am i reading the contents of file wrong?
              again thanks for your help :)
                @banbutcher is dataFile an array of filenames? then yes, you’ll need a loop.
                so, you are moving part of name a, to a new array
                then part of name b to the next slot in the array
                array.push(item)
                adds item to the end of the array
                name_of_array =[] initializes name_of_array to be an empty array
                then u will need to format the array of partial names
                var x = name_of_array.join(separator)
                will turn the array into x, a string with separator between the names
                  banbutcher
                  Band.Of.Brothers.E01.1080p.5.1Ch.BluRay.ReEnc-DeeJayAhmed.srt <br>
                  Archer S01E03 Diversity Hire (1080p x265 10bit S94 Joy).mkv <br>
                  devs.s01e02.720p.hdtv.x264-river[eztv].mkv <br>
                  What.We.Do.in.the.Shadows.S02E02.Ghosts.720p.AMZN.WEBRip.DDP5.1.x264-NTb[eztv.io].mkv <br>
                  What.We.Do.in.the.Shadows.S02E01.Resurrection.720p.AMZN.WEBRip.DDP5.1.x264-NTb[eztv.io].mkv <br>
                  this is the file im reading from… im not sure if thats an array, sorry and i want them outputted same line by line just missing the trailing parts.
                    @banbutcher reading how
                      banbutcher
                      this is my main module .js
                      i think this is where im reading from :/
                      Module.register("deluge",{
                      	defaults: {
                      		updateInterval: 10 * 60 * 1000 //reads the file every 10 mins
                      	start: function(){
                      		this.sendSocketNotification("START", this.config);
                      		if(notification === "DATA"){
                      			this.dataFile = payload;
                      			this.updateDom();
                      //	getDom: function(){
                      //		var wrapper = document.createElement("div");
                      //		if(this.dataFile){
                      //			wrapper.innerHTML = this.dataFile;
                      //		} else {
                      //			wrapper.innerHTML = "No data";
                      //		return wrapper;
                      	getDom: function(){
                      		if(this.dataFile){
                                              var split = splitRegExp.exec(this.dataFile);
                      		} else {
                      		return wrapper;
                      im in way overmy head here!
                        @banbutcher reading in the node_helper, sending up to the module.
                          banbutcher
                          Node_helper :)
                          const NodeHelper = require("node_helper");
                          const fs= require("fs");
                          //here comes the part of the nodehelper after the 3 dots as posted above
                          		if(notification === "START"){
                          			this.config = payload;
                          			this.readData();
                              			setInterval(() => {
                                  			this.readData();
                              			}, this.config.updateInterval);
                          	readData: function(){
                          		//to read a file to do the following
                          		fs.readFile("new-tv-list.txt", "utf8", (err, data) => {
                          			if (err) throw err;
                          			this.sendSocketNotification("DATA", data);
                            @banbutcher I won’t have time to look at this tonight
                              banbutcher @sdetweil
                              not a problem at all, i really appreciate your help so far in this topic and every other question ive had across the board! :thumbs_up_light_skin_tone:
                                @banbutcher ok, the fs.readFile() returns ALL the content of the file. I still would remove the utf8.
                                but you want a list of names, not a stream of characters…
                                so you need to split the stream into an array.
                                a list of text ‘lines’ has a character after each, called a line feed, we don’t want those
                                but the last filename MAY or MAY NOT be followed by a line feed. (depends on how the file was created)
                                anyhow we can fix that
                                I would change the readData function in node_helper like this
                                		fs.readFile("new-tv-list.txt", (err, data) => {
                                                        var output_data = null
                                                        // if there was no error
                                			if (!err){
                                                          // convert byte stream to array of names
                                                          output_data=data.toString().concat("\n").split('\n')
                                                        // always send something back to module, so it can display messages
                                                        // might be null if there was an error
                                			this.sendSocketNotification("DATA", output_data);
                                then to fix the module side
                                build an html table structure
                                		if(this.dataFile){
                                                        var output_list= [];
                                                        // setup regex, no i  no g (only once, and case sensitive)
                                                        var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/;
                                                        // loop thru the list of filenames
                                                        for(filename of this.dataFile) {
                                                            // if the name is not zero length (split could have returned for just linefeed
                                                            if(filename.length >0) {
                                                               // get the filename prefix
                                                               var split = splitRegExp.exec(filename);
                                                               // save name to the output list, as a table entry
                                                               // remove space after the ->< , the forum hides everything after unless a space
                                                               // table has a row,
                                                               output_list.push("< tr>< td>")
                                                               // with data
                                                               output_list.push(split)
                                                               // end of data and row
                                                               output_list.push("< /td>< /tr>")
                                                        // insert the table into the wrapper
                                			wrapper.innerHTML = "< table>" + output_list.join('')+ "< /table>";
                                		} else {
                                  @banbutcher
                                  you can also you divs instead of a table, and then set a css style
                                  ‘display’:‘inline-flex’
                                  ‘flex-direction’:‘vertical’
                                  and u can also use code to create the tree instead of text (don’t use the output_list anymore)
                                  (and u can use this with divs too, don’t need as many elements)
                                  var table=document.createElement("table")
                                  wrapper.appendChild(table)
                                                        var tr=document.createElement("tr")
                                                        table.appendChild(tr)
                                                        var td=document.createElement("td")
                                                        tr.appendChild(td)
                                                        td.innerText=split
                                  return wrapper;
                                    banbutcher
                                    Awesome i will try and get it working tonight!
                                    Thanks,
                                    Richie
                                      banbutcher
                                      wow… works like a charm! lists all tv shows perfectly! :)
                                      is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
                                      and possibly limit output to 10 lines?
                                      Thanks,
                                      Richie
                                        @banbutcher >is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
                                        sure
                                        // should make this a config variable by adding to module defaults
                                        // then would be this.config.counter
                                        // get display limit, 10 if not specified in defaults
                                        var counter=this.config.counter || 10
                                                       // and the view limit has not been reached
                                                       if(filename.length >0 && counter>0) {
                                                              tr.appendChild(td)
                                                              if(split)
        td.innerText=split
                                                              else
        td.innerText='name not matched '+ filename
                                                              counter--;
                                        return wrapper;
                                        or using the text form
                                        		if(this.dataFile){
        if(filename.length >0 && counter >0) {
        // table has a row,
        // with data
        if(split)
        else
        output_list.push('name not matched '+ filename)
        counter--;
                                        		} else {
                                          banbutcher
                                          the counter part worked great, but then when i tried to add it if loop for the name check, im getting “no data” maybe i messed up copying across?
                                          			var counter=this.config.counter || 11
        // table has a row,
        output_list.push("<tr><td>")
                                          			       // with data
                                          			       if(split )
                                          			       else
                                          			          output_list.push('name not found:'+ filename)
        output_list.push("</td></tr>")
                                          			       counter--;
                                          			wrapper.innerHTML = "<table>" + output_list.join('')+ "</table>";
                                          		 } else {
                                            sorry, don’t understand the words…
                                            this is the test if the regex worked
        if(split)
                                            			       else
                                            • 3 / 3
