    .txt file include
    59 Posts 6 Posters 46.3k Views 6 Watching
      banbutcher @sdetweil
      not a problem at all, i really appreciate your help so far in this topic and every other question ive had across the board! :thumbs_up_light_skin_tone:
        sdetweil @banbutcher
        @banbutcher ok, the fs.readFile() returns ALL the content of the file. I still would remove the utf8.
        but you want a list of names, not a stream of characters…
        so you need to split the stream into an array.
        a list of text ‘lines’ has a character after each, called a line feed, we don’t want those
        but the last filename MAY or MAY NOT be followed by a line feed. (depends on how the file was created)
        anyhow we can fix that
        I would change the readData function in node_helper like this
        readData: function(){
        		//to read a file to do the following
        		fs.readFile("new-tv-list.txt", (err, data) => {
                                var output_data = null
                                // if there was no error
        			if (!err){
                                  // convert byte stream to array of names
                                  output_data=data.toString().concat("\n").split('\n')
                                // always send something back to module, so it can display messages
                                // might be null if there was an error
        			this.sendSocketNotification("DATA", output_data);
        then to fix the module side
        build an html table structure
        		if(this.dataFile){
                                var output_list= [];
                                // setup regex, no i  no g (only once, and case sensitive)
                                var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/;
                                // loop thru the list of filenames
                                for(filename of this.dataFile) {
                                    // if the name is not zero length (split could have returned for just linefeed
                                    if(filename.length >0) {
                                       // get the filename prefix
                                       var split = splitRegExp.exec(filename);
                                       // save name to the output list, as a table entry
                                       // remove space after the ->< , the forum hides everything after unless a space
                                       // table has a row,
                                       output_list.push("< tr>< td>")
                                       // with data
                                       output_list.push(split)
                                       // end of data and row
                                       output_list.push("< /td>< /tr>")
                                // insert the table into the wrapper
        			wrapper.innerHTML = "< table>" + output_list.join('')+ "< /table>";
        		} else {
          @banbutcher
          you can also you divs instead of a table, and then set a css style
          ‘display’:‘inline-flex’
          ‘flex-direction’:‘vertical’
          and u can also use code to create the tree instead of text (don’t use the output_list anymore)
          (and u can use this with divs too, don’t need as many elements)
          var table=document.createElement("table")
          wrapper.appendChild(table)
                                var tr=document.createElement("tr")
                                table.appendChild(tr)
                                var td=document.createElement("td")
                                tr.appendChild(td)
                                td.innerText=split
          return wrapper;
            banbutcher
            Awesome i will try and get it working tonight!
            Thanks,
            Richie
              banbutcher
              wow… works like a charm! lists all tv shows perfectly! :)
              is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
              and possibly limit output to 10 lines?
              Thanks,
              Richie
                @banbutcher >is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
                sure
                // should make this a config variable by adding to module defaults
                // then would be this.config.counter
                // get display limit, 10 if not specified in defaults
                var counter=this.config.counter || 10
                               // and the view limit has not been reached
                               if(filename.length >0 && counter>0) {
                                      tr.appendChild(td)
                                      if(split)
                                          td.innerText=split
                                      else
                                          td.innerText='name not matched '+ filename
                                      counter--;
                return wrapper;
                or using the text form
                		if(this.dataFile){
                                            if(filename.length >0 && counter >0) {
                                               // table has a row,
                                               // with data
                                               if(split)
                                               else
                                                   output_list.push('name not matched '+ filename)
                                               counter--;
                		} else {
                  banbutcher
                  the counter part worked great, but then when i tried to add it if loop for the name check, im getting “no data” maybe i messed up copying across?
                  			var counter=this.config.counter || 11
                                                 // table has a row,
                                                 output_list.push("<tr><td>")
                  			       // with data
                  			       if(split )
                  			       else
                  			          output_list.push('name not found:'+ filename)
                                                 output_list.push("</td></tr>")
                  			       counter--;
                  			wrapper.innerHTML = "<table>" + output_list.join('')+ "</table>";
                  		 } else {
                  			wrapper.innerHTML = "No Data";
                    @banbutcher said in .txt file include:
                    sorry, don’t understand the words…
                    this is the test if the regex worked
                                                   if(split)
                    			       else
                      banbutcher
                      this code works…
                      		if(this.dataFile){
                                                     // table has a row,
                                                     // with data
                      			       counter--;
                      		 } else {
                      this code doesnt…
                                                     // table has a row,
                      			       // with data
                      			       if(split.length >0 )
                      			       else
                      			       counter--;
                      		 } else {
                      Richie :)
                        @banbutcher
                        my fault… I ‘assumed’ that regex would return an empty string… it returns a null value…
                        I fixed my sample, and your paste with the correct test
                        if(split)
                        instead of
                        if(split.length>0)
                          and for others trying to implement code, you can debug using the developers console, OR make little sample files and run them directly in node
                          i named this testit.js in the user home folder (~/testit.js)
                          var dataFile=["Archer S01E02Someshow.tv",
                          "Archer S01E03Someshow .tv",
                          "Archer S01e02Someshow .tv",
                          "Archer S01E04Someshow .tv",
                          "Archer S01E05someshow .tv",
                          "Archer s01E02Someshow .tv",
                          "Archer S01E09Someshow .tv",
                          var counter1=10
                                              if(dataFile){
                                                 var counter=counter1 || 10
                                                  for(filename of dataFile) {
                                                         // table has a row,
                                                         // with data
                                                         if(split)
                                                         else
                                                         counter--;
                                      console.log( "<table>" + output_list.join('')+ "</table>");
                          and then
                          cd ~
                          node testit.js
                            banbutcher
                            Perfect!!
                            now i can go to bed! :D tomorrows task will be styling with css! any pointers?
                            as always… thanks again!!
                            Richie
                              sorry, that is my weakness… I cannot make anything look good… I can tell you if it DOES look good, but cannot do it myself… I have no eye for that all…
                              • 3 / 3
