    .txt file include
    59 Posts 6 Posters 46.6k Views 6 Watching
      banbutcher
      Node_helper :)
      const NodeHelper = require("node_helper");
      const fs= require("fs");
      //here comes the part of the nodehelper after the 3 dots as posted above
      		if(notification === "START"){
      			this.config = payload;
      			this.readData();
          			setInterval(() => {
              			this.readData();
          			}, this.config.updateInterval);
      	readData: function(){
      		//to read a file to do the following
      		fs.readFile("new-tv-list.txt", "utf8", (err, data) => {
      			if (err) throw err;
      			this.sendSocketNotification("DATA", data);
        sdetweil @banbutcher
        @banbutcher I won’t have time to look at this tonight
        B 1 Reply Last reply
          banbutcher @sdetweil
          not a problem at all, i really appreciate your help so far in this topic and every other question ive had across the board! :thumbs_up_light_skin_tone:
            @banbutcher ok, the fs.readFile() returns ALL the content of the file. I still would remove the utf8.
            but you want a list of names, not a stream of characters…
            so you need to split the stream into an array.
            a list of text ‘lines’ has a character after each, called a line feed, we don’t want those
            but the last filename MAY or MAY NOT be followed by a line feed. (depends on how the file was created)
            anyhow we can fix that
            I would change the readData function in node_helper like this
            		fs.readFile("new-tv-list.txt", (err, data) => {
                                    var output_data = null
                                    // if there was no error
            			if (!err){
                                      // convert byte stream to array of names
                                      output_data=data.toString().concat("\n").split('\n')
                                    // always send something back to module, so it can display messages
                                    // might be null if there was an error
            			this.sendSocketNotification("DATA", output_data);
            then to fix the module side
            build an html table structure
            		if(this.dataFile){
                                    var output_list= [];
                                    // setup regex, no i  no g (only once, and case sensitive)
                                    var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/;
                                    // loop thru the list of filenames
                                    for(filename of this.dataFile) {
                                        // if the name is not zero length (split could have returned for just linefeed
                                        if(filename.length >0) {
                                           // get the filename prefix
                                           var split = splitRegExp.exec(filename);
                                           // save name to the output list, as a table entry
                                           // remove space after the ->< , the forum hides everything after unless a space
                                           // table has a row,
                                           output_list.push("< tr>< td>")
                                           // with data
                                           output_list.push(split)
                                           // end of data and row
                                           output_list.push("< /td>< /tr>")
                                    // insert the table into the wrapper
            			wrapper.innerHTML = "< table>" + output_list.join('')+ "< /table>";
            		} else {
              @banbutcher
              you can also you divs instead of a table, and then set a css style
              ‘display’:‘inline-flex’
              ‘flex-direction’:‘vertical’
              and u can also use code to create the tree instead of text (don’t use the output_list anymore)
              (and u can use this with divs too, don’t need as many elements)
              var table=document.createElement("table")
              wrapper.appendChild(table)
                                    var tr=document.createElement("tr")
                                    table.appendChild(tr)
                                    var td=document.createElement("td")
                                    tr.appendChild(td)
                                    td.innerText=split
              return wrapper;
                banbutcher
                Awesome i will try and get it working tonight!
                Thanks,
                Richie
                  banbutcher
                  wow… works like a charm! lists all tv shows perfectly! :)
                  is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
                  and possibly limit output to 10 lines?
                  Thanks,
                  Richie
                    @banbutcher >is there any way to print a line if the regex isn’t met… ie like a movie title instead of a series title with s01e03 attached?
                    sure
                    // should make this a config variable by adding to module defaults
                    // then would be this.config.counter
                    // get display limit, 10 if not specified in defaults
                    var counter=this.config.counter || 10
                                   // and the view limit has not been reached
                                   if(filename.length >0 && counter>0) {
                                          tr.appendChild(td)
                                          if(split)
                                              td.innerText=split
                                          else
                                              td.innerText='name not matched '+ filename
                                          counter--;
                    return wrapper;
                    or using the text form
                    		if(this.dataFile){
                                                if(filename.length >0 && counter >0) {
                                                   // table has a row,
                                                   // with data
                                                   if(split)
                                                   else
                                                       output_list.push('name not matched '+ filename)
                                                   counter--;
                    		} else {
                      banbutcher
                      the counter part worked great, but then when i tried to add it if loop for the name check, im getting “no data” maybe i messed up copying across?
                      			var counter=this.config.counter || 11
                                                     // table has a row,
                                                     output_list.push("<tr><td>")
                      			       // with data
                      			       if(split )
                      			       else
                      			          output_list.push('name not found:'+ filename)
                                                     output_list.push("</td></tr>")
                      			       counter--;
                      			wrapper.innerHTML = "<table>" + output_list.join('')+ "</table>";
                      		 } else {
                      			wrapper.innerHTML = "No Data";
                        @banbutcher said in .txt file include:
                        sorry, don’t understand the words…
                        this is the test if the regex worked
                                                       if(split)
                        			       else
                          banbutcher
                          this code works…
                          		if(this.dataFile){
                                                         // table has a row,
                                                         // with data
                          			       counter--;
                          		 } else {
                          this code doesnt…
                                                         // table has a row,
                          			       // with data
                          			       if(split.length >0 )
                          			       else
                          			       counter--;
                          		 } else {
                          Richie :)
                            @banbutcher
                            my fault… I ‘assumed’ that regex would return an empty string… it returns a null value…
                            I fixed my sample, and your paste with the correct test
                            if(split)
                            instead of
                            if(split.length>0)
                              and for others trying to implement code, you can debug using the developers console, OR make little sample files and run them directly in node
                              i named this testit.js in the user home folder (~/testit.js)
                              var dataFile=["Archer S01E02Someshow.tv",
                              "Archer S01E03Someshow .tv",
                              "Archer S01e02Someshow .tv",
                              "Archer S01E04Someshow .tv",
                              "Archer S01E05someshow .tv",
                              "Archer s01E02Someshow .tv",
                              "Archer S01E09Someshow .tv",
                              var counter1=10
                                                  if(dataFile){
                                                     var counter=counter1 || 10
                                                      for(filename of dataFile) {
                                                             // table has a row,
                                                             // with data
                                                             if(split)
                                                             else
                                                             counter--;
                                          console.log( "<table>" + output_list.join('')+ "</table>");
                              and then
                              cd ~
                              node testit.js
                                banbutcher
                                Perfect!!
                                now i can go to bed! :D tomorrows task will be styling with css! any pointers?
                                as always… thanks again!!
                                Richie
                                  sorry, that is my weakness… I cannot make anything look good… I can tell you if it DOES look good, but cannot do it myself… I have no eye for that all…
                                  • 3 / 3
