    MagicMirror project for sister
    32 Posts 11 Posters 21.6k Views 12 Watching
      blaukon @bachoo786
      @bachoo786
      sadly, I do not have more pictures or access to the mirror at the moment - alt text
      But I made 3d modell in tinkercad to show you the necessary construction:
      front:
      alt text
      -> orange: mirrorglass (bigger than the hole)
      alt text
      -> monitor right onto the glass
      alt text
      backside:
      alt text
      the frame is massiv, about 2-2.5cm wood, I have absolutly no worries that this frame would brake by itself :)
      and that’s basically how it’s mounted:
      alt text
      B 1 Reply Last reply
      • T
        thoeng
        Hi, I have seen the video and its great work.
        I have similar setup with yours i.e.: AssistantMK2 and Kinobo USB mic (not Akiro but that mini USB one) and it is nowhere as sensitive as yours. I have to speak almost next to the microphone for the hotword to activate AssistantMK2. This reduce the mirror usability considerably.
        Can you please let me know what you have done to increase the sensitivity? so far, I have increased mic to max sensitivity with ALSA mixer but still nowhere near yours.
        Regards,
          blaukon
          hi, all I did is to set a higher but not too high sensitivity via alsa mixer or on desktop - right click on audio - audio input - input device settings and adjust the sesitivity:
          alt text
          did you test your mic? arecord test.wav -> aplay test.wav?
          • T
            thoeng
            Thanks @blaukon
            Yes, i tried to raise the sensitivity via UI and Terminal. Volume from arecord is still very low.
            If I replace the mic, is it direct replacement or any configuration required?
              blaukon
              if your recoding is still quiet, even when you’ve raised the sensitivity, it’s mostlikly your microphone :/
              I’ve bought this one https://www.amazon.de/Kinobo-Mini-Akiro-Mikrofon-Windows/dp/B00NSOWWIS
              and also one that looked like 99% the same, was cheaper, but wayyy worse in comparison.
              T 1 Reply Last reply
              • A
                amsuvarna27 @blaukon
                @blaukon I’m doing also same project.
                Sir can you please share the Back up file of this project.
                I’m trying from last 3 months but unable to complete.
                Please share with me.
                • T
                  thoeng @blaukon
                  @blaukon yep its definetely the mic. I will change and reply back.
                  Thanks!
                    bachoo786 @blaukon
                    @blaukon hey so are you saying your mirror glass is bigger than your monitor?
                    I have the issue if the mirror glass is bigger than the monitor then the edge which is not covered by the monitor it needs to be painted black or covered with a black material. This causes reflection issues on the mirror from the front I.e. you can see distorted images on the edge I.e. the image looks stretched…
                      blaukon @bachoo786
                      @bachoo786
                      hey, as far as I can remember, the glass is slightly bigger than the monitor and the frame is also slightly bigger than the glass, no tape was used, since you only see the monitor in the frame and not the “frame” of the 27" monitor.
                      tried to show it graphically with my old expanded notebookdisplay:
                      alt text
                        Blauenfeldt
                        @blaukon I saw your pictures, and I see the text is easy to see in daylight, but in the video, it’s kinda hard to see in low light. But how is it with your own eyes in brought daylight and with low light/night?
                          phmandl
                          Where did you pruchase your mirror? Directly form Pilkington? And how much did it cost you?
                          Thanks in advance.
                            blaukon @Blauenfeldt
                            @bachoo786
                            I had no trouble reading the texts neither at night or day - you can easily adjust the brightness via MMM-Remote: alt text
                            @phmandl bought at glas-star.de “Pilkington Mirropane Chrome Spy 4mm (Spy4) 0.3” : 82,00 € + 70,00€ shipping (:/)
                              bachoo786 @blaukon
                              @blaukon thanks man
                              • H
                                hayman
                                Nice work,can you share how to change the icon of MK2 instead of Google icon???
                                  blaukon @hayman
                                  @hayman thanks! Please keep in mind that I’m not using the newest version of AssistantMK2. I’ve changed the following lines in his code (commented as “NEW”), this way, it will only me shown, if MMM-Hotword detected the hotword:
                                    prepareDom() {
                                      this.subdom.youtube = ytOutput
                                      this.subdom.wrapper = wrapper
                                      wrapper.style.display = "none"			//NEW
                                      return wrapper
                                    activate(profile, textQuery=null, sender=null, id=null, sayMode=false) {
                                        if (this.config.onActivate) {
                                  	this.subdom.wrapper.style.display = "block"	                   // NEW
                                          setTimeout(()=>{
                                            this.doCommand(this.config.onActivate, "onActivate", "onActivate")
                                          }, this.config.onActivate.timer)
                                    deactivate(cb=()=>{}) {
                                      this.changeStatus("STANDBY")
                                      this.subdom.wrapper.style.display = "none"			// NEW
                                      this.sendNotification(this.config.notifications.ASSISTANT_DEACTIVATED)
                                      this.quietRequest = false
                                      cb()
                                  H 1 Reply Last reply
                                  • H
                                    hayman @blaukon
                                    @blaukon thanks I’ll try it out. Great work
                                      phmandl
                                      @hayman Could you share your config file for the MMM-remote? Would be helpful and save much time :D
                                        blaukon @phmandl
                                        @phmandl hey, what do you mean by config-file? I’ve already uploaded the config.js to my google-drive: https://drive.google.com/drive/folders/16hNIqnGdpdmm9KeE-jcLGc0-fB80OpML
                                        or do you mean the modul-files?
                                        I have not changed any mmm-remote settings or module-code.
                                          sdetweil @blaukon
                                          @blaukon i think he was looking for the part of you config.js for this module
                                            stro
                                            @blaukon
                                            Really great job, thanks for sharing. How did you create the MP3 files or do you have them from a free database?
