    Getting a bunch of erros and hangups on a new installation
    6 Posts 2 Posters 839 Views 2 Watching
    • N Offline
      nakulbende
      Hey all -
      I had a magicmirror running fine for months and months. I then tried to update to recent version. Everything seemed fine at first, but soon started to hangup a lot. I think switching it on and off consistently because of all the hangups caused the SD card to corrupt.
      So, I reinstalled everythign ona fresh card. Unfortunately, I am again getting hangups. Here are some of the errors in my error logs from pm2 folder: What do these individually mean? Is there any other log I can check to help?
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.11.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2020-04-23T14_56_01_628Z-debug.log
      [2020-04-24 14:19:30.936] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/XXXXXgroup.calendar.google.com/private-XXXXX/basic.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
        errno: 'EAI_AGAIN',
        code: 'EAI_AGAIN',
        syscall: 'getaddrinfo',
        hostname: 'calendar.google.com'
      [2020-04-24 14:04:21.702] [ERROR]  TypeError: Cannot read property 'parent' of undefined
          at Function.exports.update (/home/pi/MagicMirror/modules/MMM-Comics/node_modules/cheerio/lib/parse.js:69:26)
          at module.exports (/home/pi/MagicMirror/modules/MMM-Comics/node_modules/cheerio/lib/parse.js:19:11)
          at Function.exports.load (/home/pi/MagicMirror/modules/MMM-Comics/node_modules/cheerio/lib/static.js:27:14)
          at Request._callback (/home/pi/MagicMirror/modules/MMM-Comics/node_helper.js:171:23)
          at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
          at Request.emit (events.js:200:13)
          at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
          at ClientRequest.emit (events.js:200:13)
          at TLSSocket.socketErrorListener (_http_client.js:402:9)
          at TLSSocket.emit (events.js:200:13)
      During my last restart, I also got a SD card is still busy error on the raspian splash screen - probably again because of constant restarting.
        sdetweil @nakulbende
        @nakulbende said in Getting a bunch of erros and hangups on a new installation:
        code: ‘EAI_AGAIN’,
        there was a network problem, probably outside your house… it should recover
        TypeError: Cannot read property ‘parent’ of undefined
        MMM-Comics
        this module had an error getting data, and did not handle the error… it most likely WON’T recover by itself
        why it had trouble I cannot tell
        on the MM shutdown? , I would need to see the pm2 logs, --lines=100 (or more)
        • N Offline
          nakulbende
          Hello Sam - I have had a lot fo SD card issues lately. Not sure what is going on. I did manage to get the pi restart, my logs might have some private info - i am trying to lean them, but might have left something.
          Sending them you via DM. Stay safe!
            @nakulbende i won’t even see the info… and I will destroy the file once we are done…
            I don’t see a DM
            • N Offline
              nakulbende
              Hey @sdetweil - I have the power management on wifi turned off. I am not getting complete crash of pi - to the extent that i have to restart, BUT - I am getting a lot of freezes which automatically resolve in a while.
              In the pm2 logs:
              [2020-05-04 03:03:04.470] [ERROR]  Mon May 04 2020 03:03:00 GMT-0900 (Hawaii-Aleutian Daylight Time) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
              events.js:177
                    throw er; // Unhandled 'error' event
              Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                  at doWrite (_stream_writable.js:413:19)
                  at writeOrBuffer (_stream_writable.js:401:5)
                  at Socket.Writable.write (_stream_writable.js:301:11)
                  at Object.con.<computed> [as error] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:148:46)
                  at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10)
                  at process.emit (events.js:205:15)
                  at process._fatalException (internal/process/execution.js:146:25)
              npm ERR! errno 7
              npm ERR! Exit status 7
              npm ERR!
              npm ERR!     /home/pi/.npm/_logs/2020-05-04T12_17_10_505Z-debug.log
              Here is the npm error log
              1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'start' ]
              2 info using npm@6.14.4
              3 info using node@v10.19.0
              5 info lifecycle magicmirror@2.11.0~prestart: magicmirror@2.11.0
              6 info lifecycle magicmirror@2.11.0~start: magicmirror@2.11.0
              7 verbose lifecycle magicmirror@2.11.0~start: unsafe-perm in lifecycle true
              8 verbose lifecycle magicmirror@2.11.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
              9 verbose lifecycle magicmirror@2.11.0~start: CWD: /home/pi/MagicMirror
              10 silly lifecycle magicmirror@2.11.0~start: Args: [ '-c',
              10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
              11 silly lifecycle magicmirror@2.11.0~start: Returned: code: 1  signal: null
              12 info lifecycle magicmirror@2.11.0~start: Failed to exec start script
              13 verbose stack Error: magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
              13 verbose stack Exit status 1
              13 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
              13 verbose stack     at EventEmitter.emit (events.js:198:13)
              13 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
              13 verbose stack     at ChildProcess.emit (events.js:198:13)
              13 verbose stack     at maybeClose (internal/child_process.js:982:16)
              13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
              14 verbose pkgid magicmirror@2.11.0
              15 verbose cwd /home/pi/MagicMirror
              16 verbose Linux 4.19.97-v7+
              17 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "start"
              18 verbose node v10.19.0
              19 verbose npm  v6.14.4
              20 error code ELIFECYCLE
              21 error errno 1
              22 error magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
              22 error Exit status 1
              23 error Failed at the magicmirror@2.11.0 start script.
              23 error This is probably not a problem with npm. There is likely additional logging output above.
              24 verbose exit [ 1, true ]
                @nakulbende sorry, no idea…
                I spent a year debugging one system, added watchdog, and when watchdog was installed it restarted the system when i t didn’t need to… but there was a few moments of contact lost between front and back end, always recoverable, but watchdog killed the system… every night 4-5 times…
                never did figure it out…
