    MMM-SunnyPortal Solar Module
    23 Posts 7 Posters 11.2k Views 7 Watching
    • L Offline
      linuxtuxie
      Hi Peter,
      If the inverter is visible on https://www.sunnyportal.com/ I would expect it to work.
      The main idea behind the module is that it is going to fetch the information in quite the same way as your browser would do when you visit the sunnyportal site.
      I personally have only tested the code with the inverter model Sunny Boy 1.5 1VL-40 (because that’s the one I could get my hands on ;)
      So I cannot guarantee that other inverters will work flawlessly.
      Regards,
      Linuxtuxie
      • T Offline
        TheDuDiop
        good evening, I have a system from SMA. I have a login. My problem is the module I installed. Enter login for this, unfortunately it is not possible. It shows shop all the time.
        cd ~ / MagicMirror / modules
        git clone https://github.com/linuxtuxie/MMM-SunnyPortal.git
        cd MMM-SunnyPortal
        npm install
        after that
        npm install request --save
        npm install flow --save
        npm install chart.js --save
        enter everything in the config and unfortunately does not work … where could be the error?
        guten abend, ich habe eine Anlage von SMA. Ich habe dazu ein Login. Mein Problem ist das Modul habe ich installiert. Login dazu eingeben nur leider geht es nicht. Es zeigt die ganze Zeit Laden an.
        cd ~/MagicMirror/modules
        cd MMM-SunnyPortal
        npm install
        danach
        in der config alles eingeben und geht leider nicht,… wo könnte de fehler liegen?
          sdetweil @TheDuDiop
          @TheDuDiop because the module provides a package,json, and the dependencies are already listed,
          YOU do not need to install them separately
            "dependencies": {
              "chart.js": "^2.9.3",
              "flow": "^0.2.3",
              "request": "^2.88.0"
          when u install the module, those dependencies will be installed too
          • T Offline
            TheDuDiop
            Thank you for your prompt reply, i have install again.
            but sorry i am still standing on the tube …
            where does that go ??
            “dependencies”: {
            “chart.js”: “^2.9.3”,
            “flow”: “^0.2.3”,
            “request”: “^2.88.0”
            module: ‘MMM-SunnyPortal’,
            position: ‘top_right’,
            header: ‘Solar Panels’, // The header text above the module. Use: “” to remove.
            url: ‘https://www.sunnyportal.com’, // The SunnyPortal website’s URL
            updateInterval: 900, // How many times do we update the graphs?
            // Note: Do not update too frequently or you will get locked out
            // 15 Minutes is ideal
            username: ‘’, // Username for logging into https://www.sunnyportal.com/
            password: ‘’, // Password for logging into https://www.sunnyportal.com/
            width: 500, // The total width of the module
            height: 400 // The total height of the module
            “dependencies”: {
            “flow”: “^0.2.3”,
            “request”: “^2.88.0”,
              sdetweil @TheDuDiop
              @TheDuDiop i was just showing it was already there in the package.json file.
              you did this
              cd MMM-SunnyPortal
              npm install
              danach
              but only needed to do
              cd MMM-SunnyPortal
              npm install
              1 Reply Last reply Reply Quote -1
                open the developers window, f12 or ctrl-shift-i on the keyboard, select the tab labeled console and scroll up to see any errors,
                usually red text
                you can also add part of the module name to the filter field to help reduce the number of messages to look at
                sunn will be enough
                • T Offline
                  TheDuDiop
                  @sdetweil said in MMM-SunnyPortal Solar Module:
                  developers window
                  did you mean this:
                  pi@raspberrypi:~ $ cd MagicMirror
                  magicmirror@2.11.0 start /home/pi/MagicMirror
                  [2020-05-01 07:49:55.511] [LOG] Starting MagicMirror: v2.11.0
                  [2020-05-01 07:49:55.522] [LOG] Loading config …
                  [2020-05-01 07:49:55.530] [LOG] Loading module helpers …
                  [2020-05-01 07:49:55.534] [LOG] No helper found for module: alert.
                  [2020-05-01 07:49:55.614] [LOG] Initializing new module helper …
                  [2020-05-01 07:49:55.615] [LOG] Module helper loaded: updatenotification
                  [2020-05-01 07:49:55.616] [LOG] No helper found for module: clock.
                  [2020-05-01 07:49:55.619] [LOG] Initializing new module helper …
                  [2020-05-01 07:49:55.620] [LOG] Module helper loaded: mmm-udr
                  [2020-05-01 07:49:56.243] [LOG] Initializing new module helper …
                  [2020-05-01 07:49:56.244] [LOG] Module helper loaded: calendar
                  [2020-05-01 07:49:56.770] [LOG] Initializing new module helper …
                  [2020-05-01 07:49:56.771] [LOG] Module helper loaded: MMM-DWD-WarnWeather
                  [2020-05-01 07:49:56.772] [LOG] No helper found for module: currentweather.
                  [2020-05-01 07:49:56.773] [LOG] No helper found for module: weatherforecast.
                  [2020-05-01 07:49:56.879] [LOG] Initializing new module helper …
                  [2020-05-01 07:49:56.880] [LOG] Module helper loaded: MMM-Fuel
                  [2020-05-01 07:49:57.384] [LOG] Initializing new module helper …
                  [2020-05-01 07:49:57.385] [LOG] Module helper loaded: MMM-SunnyPortal
                  [2020-05-01 07:49:57.385] [LOG] All module helpers loaded.
                  [2020-05-01 07:49:57.574] [LOG] Starting server on port 8080 …
                  [2020-05-01 07:49:57.596] [LOG] Server started …
                  [2020-05-01 07:49:57.597] [LOG] Connecting socket for: updatenotification
                  [2020-05-01 07:49:57.599] [LOG] Connecting socket for: mmm-udr
                  [2020-05-01 07:49:57.599] [LOG] Starting node_helper
                  [2020-05-01 07:49:57.600] [LOG] Connecting socket for: calendar
                  [2020-05-01 07:49:57.601] [LOG] Starting node helper for: calendar
                  [2020-05-01 07:49:57.602] [LOG] Connecting socket for: MMM-DWD-WarnWeather
                  [2020-05-01 07:49:57.603] [LOG] MMM-DWD-WarnWeather helper started…
                  [2020-05-01 07:49:57.604] [LOG] Connecting socket for: MMM-Fuel
                  [2020-05-01 07:49:57.605] [LOG] Starting module helper: MMM-Fuel
                  [2020-05-01 07:49:57.606] [LOG] Connecting socket for: MMM-SunnyPortal
                  [2020-05-01 07:49:57.607] [LOG] Starting node helper for: MMM-SunnyPortal
                  [2020-05-01 07:49:57.607] [LOG] Sockets connected & modules started …
                  [2020-05-01 07:49:57.756] [LOG] Launching application.
                  [2020-05-01 07:50:00.854] [LOG] Create new calendar fetcher for url: hlaalalalallalalalalalalalalaic.ics - Interval: 600000
                  [2020-05-01 07:50:00.882] [LOG] SocketNotification START_SUNNYPORTAL received for the first time…setting updateInterval to 900000ms
                  [2020-05-01 07:50:01.996] [LOG] Cookie Value: ASP.NET_SessionId=pgoxqxmetvbxoywf5crvnphn; BIGipServerPool_P_SunnyPortal=3036981440.20480.0000
                  [2020-05-01 07:50:01.998] [LOG] Fetched VIEWSTATE value: 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
                  [2020-05-01 07:50:01.999] [LOG] Fetched VIEWSTATEGENERATOR value: 4E24AF74
                  [2020-05-01 07:50:02.063] [LOG] Cookie Value: ASP.NET_SessionId=ysbfmau4w0e3qicudfwhcvn2; BIGipServerPool_P_SunnyPortal=3053758656.20480.0000
                  [2020-05-01 07:50:02.064] [LOG] Fetched VIEWSTATE value: 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
                  [2020-05-01 07:50:02.064] [LOG] Fetched VIEWSTATEGENERATOR value: 4E24AF74
                  [2020-05-01 07:50:02.103] [LOG] Cookie Value: ASP.NET_SessionId=urv14lugscw4gcl3uqeqr51z; BIGipServerPool_P_SunnyPortal=3070535872.20480.0000
                  [2020-05-01 07:50:02.104] [LOG] Fetched VIEWSTATE value: 3ZlIJkTD6/Nu07+OvDaS7flws2Ju49t6GgYkY6wI/RUdY5M4pRBgABZpEgG+8Zk8w7MQnK/qkdUG7/Kp+Lp3z+expWtx2n9mUZAHD5QAE3Dno+fv9xNo7sbywprecoDCLdY4D8JhCOLv3haYOvaf1ilt7qi6CpArJDZMaLC7nCm9mNvTHtHMJoJhJ5B/Y/ygsb3EsJLWkdfQ/8LVB2abSjN43Ouk0UqAK4QK0jkerrpPMjMjQ2rC/wRSVf7LeZblhgEXOdq4jhggQhV0eQ4lhoSYITXqqh9wxHlF5/ATzQcFu8uhLXJLYnKJXFKz3RK8M4UU9xaloBQTXtNNcTCnOx78633Iy5z8BfVCfUbkJ5+aZ0YlYSz2xDYdCxTG+JqSIdDc2HzaAWlcUNkNLIqZUyArRoOxzLKjOyhmtm/Roz19IO/aANWrdZr/2RN/IoAE4vpU6UYw4/m3BUicYLIzqtLH/eFNgjyyqUx5MG2mTFhGhLhuXK+4BwExu5dGxbnrbyo6H1gn8u/L1H0O1jAWGrLG9bcamjuF49hErLxyQ/1hso1eHO36M5qhkcKS71GBrxX1tuWwbU8Qo46jxVWx8vGi6g7lLfmRrM+gJA9S/c6NIMg+DL/11HnA2upxjnDdrfi9kE2QeLZxPR+HzLPSo+sPXu9al9OCODVGgOyQa/8vwOEteg6cJQUXOhtENcoV0I1xyOWUfcWqZ45zzHx1+AfMiyvSsQCZkyX9OOcTEj6y07E5nwAI8fLNMa6N3DnyEtzCJAC6byIra88Yl7FTH27QVW+EdCHydcurXtaxb+tkL6jw4VqOCWWLSPiw/gWZyL9ONxUORABhhK39Zkf6V26pOy6rPBYYkNsqZ/J7zNumzSn7Bvh/hkf8mFNLszlfyxk1nEPTBHefKOLCzyskDo56vENg1LrmAqPWpjiL2kvj0a9JwtuZdVC1E9BHy5yYYriem7EHqr8B1jvfjfBkV3N7XeXTimSSNG5MAu44T3RBRMkJEB2l6ZNzNzcR6drXfZVUcTScA3U/dn7XvpJLUI7CP53nsFUHMmAmVt5BZkaBJEripsuPVBCcUd+ixwEHvxfeW6w8WkTsCw+w8HjLRPGBWE9fq2YYXiqGZMHitIH1X9aeYXf4K30no4UQTfbKJMmKHh2WQV4eNoQyc5nOl700wqwT9sKwS+Bj9kuwerZ+vCIH5B2gERwvJ+JTa4PH/FHJYmo+kqM3ldfFEuojsdcbhyKdjq/EWZ9pCWRVSe0PIuKQJnjmBr8WNIvMCuE9KZVRvLQbrWM8ZfJ3QzE+H8089zc/kQGcpja6+7ImjmgbrxKo106VVbGB+OQqAcBnmXfG/90mR4T+SsaLpnf78bx4cC+o3aPC5dRf6GsVYKERFVPwvzNlcJvIWVDCfyJKmtGhQOzN8YpG5Aayndqs4IGdztr95czozdNRxoNilYsuT7UQsUWkuur13R4yOYPU8mROAWRoLiLD/o+qyGhaWfK19iuWVli5+6LQfDA8zhWZfO64aXRG66CjwmPy6rsDcRNhMEeDcKfm15q++NR+SlYr1XPI0wJf50juBlPAUxQdAHkeZ3EnoFZXEVHWTmbXACkXFPKfzO/RdpaXpvnnf9aJv3f7SshD8EqYpQfTDRYMU4s0bu06wLy27hVGxMbXRiTNX3UxC6ti7KA6N7UvNkdac2napHUpGxfMfuotzvLSruENrCSlpqW3Wsstk1yeoQQnsh1u726hsOUDeXu52Y9SUh5xTc7jDSpRRQDHwQ6cAfbe4ehKF1GNXwOoC/VdbszYSHcJIYP+/cIsziKKEmewIumR/7DawpUtxEouOxpDblKj+xVm3X6EkKl1zS+Mgwvk6UR3FOt+/ksmizS7pMKfx0uKgVihJFLc/tph3J0NCCT7Ruy595FlIKfF0/GhbL+lsdXJZxGGduVQWHhr8xotftckg8d0yaJ3WNh47jxS+53bLwTfw9tHbM/dTu8rm4d3EZk1I88RmgyLAFONkMzz94YFpN2gBSohvcph2uWbT15g5rQjCIWC9S+CkqnLPoZUsijT8Y+PqetmtCO5sWoAv36eFX56cCiLeUWfcCMJ4f+RpUrgUtFuwRU12hgSxQFSgOy2JjS5zsqFKUlLrhCDo3lGmp09XIfdhWh7FeBFewaF
                  [2020-05-01 07:50:02.105] [LOG] Fetched VIEWSTATEGENERATOR value: 4E24AF74
                  [2020-05-01 07:50:02.530] [LOG] Login Failed, no redirect to Dashboard
                  [2020-05-01 07:50:02.561] [LOG] Login Failed, no redirect to Dashboard
                  [2020-05-01 07:50:02.580] [LOG] Login Failed, no redirect to Dashboard
                  [2020-05-01 07:50:03.380] [LOG] HTTP Result: 200
                  [2020-05-01 07:50:03.385] [LOG] Whoops! There was an uncaught exception…
                  [2020-05-01 07:50:03.387] [ERROR] TypeError: Cannot read property ‘1’ of null
                  at Request._callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:103:121)
                  at Request.self.callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:185:22)
                  at Request.emit (events.js:200:13)
                  at Request. (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1154:10)
                  at IncomingMessage. (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1076:12)
                  at Object.onceWrapper (events.js:288:20)
                  at IncomingMessage.emit (events.js:205:15)
                  at endReadableNT (_stream_readable.js:1154:12)
                  at processTicksAndRejections (internal/process/task_queues.js:84:9)
                  [2020-05-01 07:50:03.405] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-05-01 07:50:03.406] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2020-05-01 07:50:03.418] [LOG] HTTP Result: 200
                  [2020-05-01 07:50:03.420] [LOG] Whoops! There was an uncaught exception…
                  [2020-05-01 07:50:03.421] [ERROR] TypeError: Cannot read property ‘1’ of null
                  [2020-05-01 07:50:03.428] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-05-01 07:50:03.431] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2020-05-01 07:50:03.440] [LOG] HTTP Result: 200
                  [2020-05-01 07:50:03.441] [LOG] Whoops! There was an uncaught exception…
                  [2020-05-01 07:50:03.442] [ERROR] TypeError: Cannot read property ‘1’ of null
                  [2020-05-01 07:50:03.444] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-05-01 07:50:03.445] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  ^A^A
                    sdetweil @TheDuDiop
                    @TheDuDiop said in MMM-SunnyPortal Solar Module:
                    the node_helper didn’t get the response from some service as it expected
                    • T Offline
                      TheDuDiop
                      thanks for your answer, what can I do that the node_helper goes again? or is this a developer problem?
                        probably a developer problem… don’t know the module at all
