    Monthly Calendar Add
    4 Posts 2 Posters 989 Views 2 Watching
      StewartBaird86
      Hey Guys and Girls
      I am working on my first magic mirror and learning the whole command thing…its not going well.
      I have cloned the file and created a config.js file.
      When I go to add Monthly_Calendar (https://github.com/KirAsh4/calendar_monthly/blob/master/README.md)
      My Magic Mirror wont load. I have copied and pasted the command lines to no success.
      I have ran my syntax through jshint.com but the errors don’t make sense to me, or I cant figure it out.
      When I add the calendar I have “{” on the line before module. I get an error saying it should be “}” as it expects that because of line 27 (Var secion) has a “{”
      I comply and make the switch, error disappears from syntax check, but then it starts asking for semi colons and such.
      When I change Position: to Position; and swap ’ to" I get the following error:
      Expected an assignment or function call and instead saw an expression.
      I am adding the module in the way the default modules appear in the config file.
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: ‘calendar_monthly’,
      		    position: “top_center”,
      Syntax Errors:
      Three warnings
      97 Expected ‘}’ to match ‘{’ from line 27 and instead saw ‘module’.
      97 Missing semicolon.
      97 Unrecoverable syntax error. (75% scanned).
        StewartBaird86
        Anybody able to explain what I am doing wrong? I am following the Read ME
          sdetweil @StewartBaird86
          @StewartBaird86 said in Monthly Calendar Add:
          wrong kind of single and double quotes, note that they are slightly tilted… this is a word processing program quote,
          vs a text editor quote, both are straight up and down
            StewartBaird86 @sdetweil
            @sdetweil THANK YOU SO MUCH!!!
