MMM-ResRobot - Public transport information for Sweden
According to Trafiklab site Skånetrafiken is included in ResRobot so it should work.
Can you post your config? -
did’nt work yesterday at all… now, I get a response but as of right now 16:16 it only shows one departure at 16:30 ?
{ module: "MMM-ResRobot", position: "right", header: "Femman", config: { from: "740015772", // ResRobot Station ID (or a comma-separated string of IDs) to: "740015577", // ResRobot Station ID of destination (or a comma-separated string of IDs) maximumEntries: 6, // Number of departures to show on screen truncateAfter: 5, // A value > 0 will truncate direction name at first space after <value> characters. 0 = no truncation apiKey: "407fe5c8-4621-4a20-a171-xxxxxxxxx" // Your ResRobot apiKey } },
edit:
sometimes only one departure shows up… after a while 5-6 shows… then it’s back to one. Will try different to: ID’s and see if I can get a better response
@MrH, ResRobot (Samtrafiken) had a service window between between 22.00 and 24.00 on October 10th. That was probably why you didn’t get a response then.
I will have a look this evening using your station ids.
Hi I’m in the making of building my Magic Mirror and came across this module. I have a problem that after roughly 7 hours it stops to update with the buss departures and freezes. Have anyone else had the same problem and found a solution to it? Works perfectly again after a restart but would like to find a solution to it.
@Klzow, I’ve noticed the same but thought it had to do with the fact that I’m running of a first-generation pi with 256MB. Will look into it to see if I can find out why.
@Klzow same here, sometimes it works for a few days but usually it stops working within 24h
I don’t get it to work. Followed the instructions in the readme and registered to get th APIkey. But it still doesn’t start.
What could be wrong? Here is the output:magicmirror@2.0.0 start /home/pi/MagicMirror
electron js/electron.jsLoading config …
Loading module helpers …
No helper found for module: faceemployee.
All module helpers loaded.
Starting server op port 8080 …
Server started …
Connecting socket for: MMM-Facial-Recognition
Staring module helper: MMM-Facial-Recognition
Connecting socket for: MMM-ResRobot
Starting node_helper for module: MMM-ResRobot
Starting module: newsfeed
Sockets connected & modules started …
Launching application.
Create new news fetcher for url: http://nyhetsbrev.viktoria.se/feed/ - Interval: 300000
[MMM-Facial-Recognition] Facerecognition started…
[MMM-Facial-Recognition] Loading training data…
[MMM-Facial-Recognition] ALGORITHM: LBPH
[MMM-Facial-Recognition] Training data loaded!
[MMM-Facial-Recognition] --------------------
[MMM-Facial-Recognition] PiCam connected -
Could you please post your config? It seems that MMM-ResRobot is never executed. -
Here is my config:
module: “MMM-ResRobot”,
position: “left”,
header: “Departures”,
from: “740059355”, // ResRobot Station ID (or a comma-separated string of IDs)
to: “740059412”, // ResRobot Station ID of destination (or a comma-separated string of IDs)
truncateAfter: 5, // A value > 0 will truncate direction name at first space after characters. 0 = no truncation
apiKey: “a6e181d4-3065-4214-a30b-780163xxxxxx” // Your ResRobot apiKey
I copied your config and eslint complained about the quote characters. Make sure that you use the standard " character, not “ or ”.
Using your config with my apiKey works as it should.
/j
