    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 227.4k Views 28 Watching
    • AlvingerA
      Alvinger
      It might be. I can’t control what replies ResRobot gives for a specific search. According to its documentation it should only return the result matching the from and to parameters. I’ll do some additionsl checking but you could try the search without a “to” valur to see if there is a difference.
      • MrHM
        MrH
        Hi
        Anyone got this working with Skånetrafiken bus traffic? so far I only get “fetching departures…” but someone said that I need to use their own API, not Trafiklabs, is that true?
        • AlvingerA
          Alvinger
          According to Trafiklab site Skånetrafiken is included in ResRobot so it should work.
          Can you post your config?
          MrHM 1 Reply Last reply
          • MrHM
            MrH @Alvinger
            did’nt work yesterday at all… now, I get a response but as of right now 16:16 it only shows one departure at 16:30 ?
                                    module: "MMM-ResRobot",
                                    position: "right",
                                    header: "Femman",
                                    from: "740015772",   // ResRobot Station ID (or a comma-separated string of IDs)
                                    to: "740015577", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                                    maximumEntries: 6,  // Number of departures to show on screen
                                    truncateAfter: 5,   // A value > 0 will truncate direction name at first space after <value> characters. 0 = no truncation
                                    apiKey: "407fe5c8-4621-4a20-a171-xxxxxxxxx"  // Your ResRobot apiKey
            edit:
            sometimes only one departure shows up… after a while 5-6 shows… then it’s back to one. Will try different to: ID’s and see if I can get a better response
            • AlvingerA
              Alvinger
              @MrH, ResRobot (Samtrafiken) had a service window between between 22.00 and 24.00 on October 10th. That was probably why you didn’t get a response then.
              I will have a look this evening using your station ids.
              • K
                Klzow
                Hi I’m in the making of building my Magic Mirror and came across this module. I have a problem that after roughly 7 hours it stops to update with the buss departures and freezes. Have anyone else had the same problem and found a solution to it? Works perfectly again after a restart but would like to find a solution to it.
                N 1 Reply Last reply
                • AlvingerA
                  Alvinger
                  @Klzow, I’ve noticed the same but thought it had to do with the fact that I’m running of a first-generation pi with 256MB. Will look into it to see if I can find out why.
                  • N
                    Notumlord @Klzow
                    @Klzow same here, sometimes it works for a few days but usually it stops working within 24h
                    AlvingerA 1 Reply Last reply
                    • E
                      Escenda
                      I don’t get it to work. Followed the instructions in the readme and registered to get th APIkey. But it still doesn’t start.
                      What could be wrong? Here is the output:
                      magicmirror@2.0.0 start /home/pi/MagicMirror
                      electron js/electron.js
                      Loading config …
                      Loading module helpers …
                      No helper found for module: faceemployee.
                      All module helpers loaded.
                      Starting server op port 8080 …
                      Server started …
                      Connecting socket for: MMM-Facial-Recognition
                      Staring module helper: MMM-Facial-Recognition
                      Connecting socket for: MMM-ResRobot
                      Starting node_helper for module: MMM-ResRobot
                      Starting module: newsfeed
                      Sockets connected & modules started …
                      Launching application.
                      Create new news fetcher for url: http://nyhetsbrev.viktoria.se/feed/ - Interval: 300000
                      [MMM-Facial-Recognition] Facerecognition started…
                      [MMM-Facial-Recognition] Loading training data…
                      [MMM-Facial-Recognition] ALGORITHM: LBPH
                      [MMM-Facial-Recognition] Training data loaded!
                      [MMM-Facial-Recognition] --------------------
                      [MMM-Facial-Recognition] PiCam connected
                      • AlvingerA
                        Alvinger
                        Could you please post your config? It seems that MMM-ResRobot is never executed.
                        • E
                          Escenda
                          Here is my config:
                          module: “MMM-ResRobot”,
                          position: “left”,
                          header: “Departures”,
                          from: “740059355”, // ResRobot Station ID (or a comma-separated string of IDs)
                          to: “740059412”, // ResRobot Station ID of destination (or a comma-separated string of IDs)
                          truncateAfter: 5, // A value > 0 will truncate direction name at first space after characters. 0 = no truncation
                          apiKey: “a6e181d4-3065-4214-a30b-780163xxxxxx” // Your ResRobot apiKey
                          • AlvingerA
                            Alvinger
                            I copied your config and eslint complained about the quote characters. Make sure that you use the standard " character, not “ or ”.
                            Using your config with my apiKey works as it should.
                            /j
                            • AlvingerA
                              Alvinger @Notumlord
                              @Notumlord and @Klzow, I think I have found the issue. When the ResRobot API call failed for some reason the next update was never scheduled resulting in a “freeze”. I have pushed an update to github which schedules an update when the API call fails. (In my case the ResRobot site returned a “site unavailable” error every now and then which froze the module) Sorry for the bug!
                              K 1 Reply Last reply
                              • K
                                Klzow @Alvinger
                                @Alvinger Perfect! Thank you very much! Have been running it for 48 hours without any problem now.
                                • AlvingerA
                                  Alvinger
                                  New version out with one minor change: transportation type icons are now displayed (to the left of the linenumber). All rail-bound types are displayed as trains (fa-train), all buses are displayed as bus (fa-bus) and all waterborne transportation is displayed as ship (fa-ship).
                                    selarp
                                    Thanks @Alvinger for an awesome module! However, I have a problem when I add more than one destination (to:). Displays only the result of the destination that appears first.
                                    Here is my config.js:
                                        position: "left",
                                        header: "Departures from Skanör C",
                                            from: "740000950",   // ResRobot Station ID (or a comma-separated string of IDs)
                                            to: "740000003,740001586", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                                            apiKey: ”[My API-key]"  // Your ResRobot apiKey
                                    • AlvingerA
                                      Alvinger
                                      you need to specify a station id in “from” as well. “from” is used to find the station’s departures, “to” is used to differentiate between destinations going from the “from” station.
                                      Change “from” to ‘from: “740000950,740000950”’ to make it work as you want.
                                        selarp @Alvinger
                                        Of course! Thank you very much @Alvinger!
                                        • K
                                          Klzow
                                          Hi!
                                          I have a question /idea /request.
                                          Would it be possible to set a limit in minutes in which the module won’t show departures before that limit?
                                          For example I have a 15 min walk to bus/subway and during rush hour in Stockholm lots of departures are happening every minute. To be able to plan ahead and see when the bus is leaving I need to show many departures on the mirror to see that far ahead in time. Would it be possible to set a limit to not show departures happening earlier then 15 min ahead since it would not be necessary to know that the subway is leaving in 1 min when I can’t get her there in time to catch it? This would clean up the mirror and save some space on the screen.
                                          • AlvingerA
                                            Alvinger @Klzow
                                            @Klzow,
                                            That shouldn’t be too hard to do. I will look into it. My current thinking is to introduce a new config value (something like “ignoreBefore=5” with default 0 for backward compatibility) Keep an eye on this thread for developments!
                                            • 2 / 7
