    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 225.2k Views 28 Watching
    • A
      Alvinger
      The module name is “MMM-ResRobot”, not “ResRobot”. Change that and it will work. Sorry, my bad!
      • N
        Notumlord @Alvinger
        @Alvinger Woops, don’t know how i missed that. It was copied from your README but i can see you’ve fixed it now, i’ll give it another try. :)
        • A
          Alvinger
          @Notumlord, please give it another try. I actually made a last-minute name change but forgot to update the README. :-(
          • N
            Notumlord @Alvinger
            @Alvinger Tried it and now it works, another issue though is that the “To/From” doesnt seem to work properly. If i put station A in “From” and station B in “To” the module also shows “From B to A” so it shows both directions (if that makes sense).
            • A
              Alvinger
              Can you post your config?
              • N
                Notumlord @Alvinger
                @Alvinger
                    module: "MMM-ResRobot",
                    position: "left",
                    header: "Avgång",
                        from: "740015597",   // ResRobot Station ID (or a comma-separated string of IDs)
                        to: "740000002", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                        maximumEntries: 6,  // Number of departures to show on screen
                        truncateAfter: 5,   // A value > 0 will truncate direction name at first space after <value> characters. 0 = no truncation
                        apiKey: "<key>"  // Your ResRobot apiKey
                • A
                  Alvinger
                  @Notumlord
                  When I use your from: and to: I only get departures from Svingeln. I do get a lot of replies but cannot determine if they are all going in the same direction. As far as I can tell they are all departures from Svingeln, not arrivals.
                  There is a comment in the documentation of the ResRobot API which states that in some situations duplicate data is returned (has to do with real time information). My guess is that it whas just something with the data.
                  If you want to troubleshoot you can uncomment the print of “body” in node_helper.js, this will print the json-reply from ResRobot.
                  • N
                    Notumlord @Alvinger
                    @Alvinger
                    My mistake, here is the config:
                    to: "740098001"
                    Since this is from “Vagnhallen Gårda” to “Centralstaionen” it should only show Bus 60 with the title/destination “Masthugget”.While this does show up it also shows “Redbergsplatsen” which is the opposite direction.
                    Maybe this is intended?
                    • A
                      Alvinger
                      It might be. I can’t control what replies ResRobot gives for a specific search. According to its documentation it should only return the result matching the from and to parameters. I’ll do some additionsl checking but you could try the search without a “to” valur to see if there is a difference.
                        MrH
                        Hi
                        Anyone got this working with Skånetrafiken bus traffic? so far I only get “fetching departures…” but someone said that I need to use their own API, not Trafiklabs, is that true?
                        • A
                          Alvinger
                          According to Trafiklab site Skånetrafiken is included in ResRobot so it should work.
                            MrH @Alvinger
                            did’nt work yesterday at all… now, I get a response but as of right now 16:16 it only shows one departure at 16:30 ?
                                                    position: "right",
                                                    header: "Femman",
                                                    from: "740015772",   // ResRobot Station ID (or a comma-separated string of IDs)
                                                    to: "740015577", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                                                    apiKey: "407fe5c8-4621-4a20-a171-xxxxxxxxx"  // Your ResRobot apiKey
                            edit:
                            sometimes only one departure shows up… after a while 5-6 shows… then it’s back to one. Will try different to: ID’s and see if I can get a better response
                            • A
                              Alvinger
                              @MrH, ResRobot (Samtrafiken) had a service window between between 22.00 and 24.00 on October 10th. That was probably why you didn’t get a response then.
                              I will have a look this evening using your station ids.
                              • K
                                Klzow
                                Hi I’m in the making of building my Magic Mirror and came across this module. I have a problem that after roughly 7 hours it stops to update with the buss departures and freezes. Have anyone else had the same problem and found a solution to it? Works perfectly again after a restart but would like to find a solution to it.
                                • A
                                  Alvinger
                                  @Klzow, I’ve noticed the same but thought it had to do with the fact that I’m running of a first-generation pi with 256MB. Will look into it to see if I can find out why.
                                  • N
                                    Notumlord @Klzow
                                    @Klzow same here, sometimes it works for a few days but usually it stops working within 24h
                                    • E
                                      Escenda
                                      I don’t get it to work. Followed the instructions in the readme and registered to get th APIkey. But it still doesn’t start.
                                      What could be wrong? Here is the output:
                                      magicmirror@2.0.0 start /home/pi/MagicMirror
                                      electron js/electron.js
                                      Loading config …
                                      Loading module helpers …
                                      No helper found for module: faceemployee.
                                      All module helpers loaded.
                                      Starting server op port 8080 …
                                      Server started …
                                      Connecting socket for: MMM-Facial-Recognition
                                      Staring module helper: MMM-Facial-Recognition
                                      Connecting socket for: MMM-ResRobot
                                      Starting node_helper for module: MMM-ResRobot
                                      Starting module: newsfeed
                                      Sockets connected & modules started …
                                      Launching application.
                                      Create new news fetcher for url: http://nyhetsbrev.viktoria.se/feed/ - Interval: 300000
                                      [MMM-Facial-Recognition] Facerecognition started…
                                      [MMM-Facial-Recognition] Loading training data…
                                      [MMM-Facial-Recognition] ALGORITHM: LBPH
                                      [MMM-Facial-Recognition] Training data loaded!
                                      [MMM-Facial-Recognition] --------------------
                                      [MMM-Facial-Recognition] PiCam connected
                                      • A
                                        Alvinger
                                        Could you please post your config? It seems that MMM-ResRobot is never executed.
                                        • E
                                          Escenda
                                          Here is my config:
                                          module: “MMM-ResRobot”,
                                          position: “left”,
                                          header: “Departures”,
                                          from: “740059355”, // ResRobot Station ID (or a comma-separated string of IDs)
                                          to: “740059412”, // ResRobot Station ID of destination (or a comma-separated string of IDs)
                                          truncateAfter: 5, // A value > 0 will truncate direction name at first space after characters. 0 = no truncation
                                          apiKey: “a6e181d4-3065-4214-a30b-780163xxxxxx” // Your ResRobot apiKey
                                          • A
                                            Alvinger
                                            I copied your config and eslint complained about the quote characters. Make sure that you use the standard " character, not “ or ”.
                                            Using your config with my apiKey works as it should.
                                            /j
                                            • 1 / 7
