    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 216.4k Views 28 Watching
      Alvinger
      Thanks.
      Västtrafik is actually already covered by ResRobot. Just look up the stop id at Trafiklab (see README.md for instructions) and you’re ready to go!
      1 Reply Last reply Reply Quote -1
      • N Offline
        Notumlord
        Unfortently i can’t get it to work, all i get is a black screen when i load the mirror.
        This is my config:
            module: "ResRobot",
            position: "left",
            header: "Departures",
                from: "740059685",   // ResRobot Station ID (or a comma-separated string of IDs)
                to: "740072430", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                maximumEntries: 6,  // Number of departures to show on screen
                truncateAfter: 5,   // A value > 0 will truncate direction name at first space after <value> characters. 0 = no truncation
                apiKey: "57434e24-a128-4cdb-bb88-e4b1e857c1aa"  // Your ResRobot apiKey
        If i remove the code again the mirror loads fine.
          Alvinger
          The module name is “MMM-ResRobot”, not “ResRobot”. Change that and it will work. Sorry, my bad!
          • N Offline
            Notumlord @Alvinger
            @Alvinger Woops, don’t know how i missed that. It was copied from your README but i can see you’ve fixed it now, i’ll give it another try. :)
              Alvinger
              @Notumlord, please give it another try. I actually made a last-minute name change but forgot to update the README. :-(
              • N Offline
                Notumlord @Alvinger
                @Alvinger Tried it and now it works, another issue though is that the “To/From” doesnt seem to work properly. If i put station A in “From” and station B in “To” the module also shows “From B to A” so it shows both directions (if that makes sense).
                  Alvinger
                  Can you post your config?
                  • N Offline
                    Notumlord @Alvinger
                    @Alvinger
                        module: "MMM-ResRobot",
                        position: "left",
                        header: "Avgång",
                            from: "740015597",   // ResRobot Station ID (or a comma-separated string of IDs)
                            to: "740000002", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                            apiKey: "<key>"  // Your ResRobot apiKey
                      Alvinger
                      @Notumlord
                      When I use your from: and to: I only get departures from Svingeln. I do get a lot of replies but cannot determine if they are all going in the same direction. As far as I can tell they are all departures from Svingeln, not arrivals.
                      There is a comment in the documentation of the ResRobot API which states that in some situations duplicate data is returned (has to do with real time information). My guess is that it whas just something with the data.
                      If you want to troubleshoot you can uncomment the print of “body” in node_helper.js, this will print the json-reply from ResRobot.
                      • N Offline
                        Notumlord @Alvinger
                        @Alvinger
                        My mistake, here is the config:
                        to: "740098001"
                        Since this is from “Vagnhallen Gårda” to “Centralstaionen” it should only show Bus 60 with the title/destination “Masthugget”.While this does show up it also shows “Redbergsplatsen” which is the opposite direction.
                        Maybe this is intended?
                          Alvinger
                          It might be. I can’t control what replies ResRobot gives for a specific search. According to its documentation it should only return the result matching the from and to parameters. I’ll do some additionsl checking but you could try the search without a “to” valur to see if there is a difference.
                            MrH
                            Hi
                            Anyone got this working with Skånetrafiken bus traffic? so far I only get “fetching departures…” but someone said that I need to use their own API, not Trafiklabs, is that true?
                              Alvinger
                              According to Trafiklab site Skånetrafiken is included in ResRobot so it should work.
                                MrH @Alvinger
                                did’nt work yesterday at all… now, I get a response but as of right now 16:16 it only shows one departure at 16:30 ?
                                                        position: "right",
                                                        header: "Femman",
                                                        from: "740015772",   // ResRobot Station ID (or a comma-separated string of IDs)
                                                        to: "740015577", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                                                        apiKey: "407fe5c8-4621-4a20-a171-xxxxxxxxx"  // Your ResRobot apiKey
                                edit:
                                sometimes only one departure shows up… after a while 5-6 shows… then it’s back to one. Will try different to: ID’s and see if I can get a better response
                                  Alvinger
                                  @MrH, ResRobot (Samtrafiken) had a service window between between 22.00 and 24.00 on October 10th. That was probably why you didn’t get a response then.
                                  I will have a look this evening using your station ids.
                                  • K Offline
                                    Klzow
                                    Hi I’m in the making of building my Magic Mirror and came across this module. I have a problem that after roughly 7 hours it stops to update with the buss departures and freezes. Have anyone else had the same problem and found a solution to it? Works perfectly again after a restart but would like to find a solution to it.
                                      Alvinger
                                      @Klzow, I’ve noticed the same but thought it had to do with the fact that I’m running of a first-generation pi with 256MB. Will look into it to see if I can find out why.
                                      • N Offline
                                        Notumlord @Klzow
                                        @Klzow same here, sometimes it works for a few days but usually it stops working within 24h
                                        • E Offline
                                          Escenda
                                          I don’t get it to work. Followed the instructions in the readme and registered to get th APIkey. But it still doesn’t start.
                                          What could be wrong? Here is the output:
                                          magicmirror@2.0.0 start /home/pi/MagicMirror
                                          electron js/electron.js
                                          Loading config …
                                          Loading module helpers …
                                          No helper found for module: faceemployee.
                                          All module helpers loaded.
                                          Starting server op port 8080 …
                                          Server started …
                                          Connecting socket for: MMM-Facial-Recognition
                                          Staring module helper: MMM-Facial-Recognition
                                          Connecting socket for: MMM-ResRobot
                                          Starting node_helper for module: MMM-ResRobot
                                          Starting module: newsfeed
                                          Sockets connected & modules started …
                                          Launching application.
                                          Create new news fetcher for url: http://nyhetsbrev.viktoria.se/feed/ - Interval: 300000
                                          [MMM-Facial-Recognition] Facerecognition started…
                                          [MMM-Facial-Recognition] Loading training data…
                                          [MMM-Facial-Recognition] ALGORITHM: LBPH
                                          [MMM-Facial-Recognition] Training data loaded!
                                          [MMM-Facial-Recognition] --------------------
                                          [MMM-Facial-Recognition] PiCam connected
                                            Alvinger
                                            Could you please post your config? It seems that MMM-ResRobot is never executed.
                                            • 1 / 7
