    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 227.4k Views 28 Watching
    • N
      Notumlord @Klzow
      @Klzow same here, sometimes it works for a few days but usually it stops working within 24h
      AlvingerA 1 Reply Last reply
      • E
        Escenda
        I don’t get it to work. Followed the instructions in the readme and registered to get th APIkey. But it still doesn’t start.
        What could be wrong? Here is the output:
        magicmirror@2.0.0 start /home/pi/MagicMirror
        electron js/electron.js
        Loading config …
        Loading module helpers …
        No helper found for module: faceemployee.
        All module helpers loaded.
        Starting server op port 8080 …
        Server started …
        Connecting socket for: MMM-Facial-Recognition
        Staring module helper: MMM-Facial-Recognition
        Connecting socket for: MMM-ResRobot
        Starting node_helper for module: MMM-ResRobot
        Starting module: newsfeed
        Sockets connected & modules started …
        Launching application.
        Create new news fetcher for url: http://nyhetsbrev.viktoria.se/feed/ - Interval: 300000
        [MMM-Facial-Recognition] Facerecognition started…
        [MMM-Facial-Recognition] Loading training data…
        [MMM-Facial-Recognition] ALGORITHM: LBPH
        [MMM-Facial-Recognition] Training data loaded!
        [MMM-Facial-Recognition] --------------------
        [MMM-Facial-Recognition] PiCam connected
        • AlvingerA
          Alvinger
          Could you please post your config? It seems that MMM-ResRobot is never executed.
          • E
            Escenda
            Here is my config:
            module: “MMM-ResRobot”,
            position: “left”,
            header: “Departures”,
            from: “740059355”, // ResRobot Station ID (or a comma-separated string of IDs)
            to: “740059412”, // ResRobot Station ID of destination (or a comma-separated string of IDs)
            maximumEntries: 6, // Number of departures to show on screen
            truncateAfter: 5, // A value > 0 will truncate direction name at first space after characters. 0 = no truncation
            apiKey: “a6e181d4-3065-4214-a30b-780163xxxxxx” // Your ResRobot apiKey
            • AlvingerA
              Alvinger
              I copied your config and eslint complained about the quote characters. Make sure that you use the standard " character, not “ or ”.
              Using your config with my apiKey works as it should.
              /j
              • AlvingerA
                Alvinger @Notumlord
                @Notumlord and @Klzow, I think I have found the issue. When the ResRobot API call failed for some reason the next update was never scheduled resulting in a “freeze”. I have pushed an update to github which schedules an update when the API call fails. (In my case the ResRobot site returned a “site unavailable” error every now and then which froze the module) Sorry for the bug!
                K 1 Reply Last reply
                • K
                  Klzow @Alvinger
                  @Alvinger Perfect! Thank you very much! Have been running it for 48 hours without any problem now.
                  • AlvingerA
                    Alvinger
                    New version out with one minor change: transportation type icons are now displayed (to the left of the linenumber). All rail-bound types are displayed as trains (fa-train), all buses are displayed as bus (fa-bus) and all waterborne transportation is displayed as ship (fa-ship).
                      selarp
                      Thanks @Alvinger for an awesome module! However, I have a problem when I add more than one destination (to:). Displays only the result of the destination that appears first.
                      Here is my config.js:
                          module: "MMM-ResRobot",
                          position: "left",
                          header: "Departures from Skanör C",
                              from: "740000950",   // ResRobot Station ID (or a comma-separated string of IDs)
                              to: "740000003,740001586", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                              apiKey: ”[My API-key]"  // Your ResRobot apiKey
                      • AlvingerA
                        Alvinger
                        you need to specify a station id in “from” as well. “from” is used to find the station’s departures, “to” is used to differentiate between destinations going from the “from” station.
                        Change “from” to ‘from: “740000950,740000950”’ to make it work as you want.
                          selarp @Alvinger
                          Of course! Thank you very much @Alvinger!
                          • K
                            Klzow
                            Hi!
                            I have a question /idea /request.
                            Would it be possible to set a limit in minutes in which the module won’t show departures before that limit?
                            For example I have a 15 min walk to bus/subway and during rush hour in Stockholm lots of departures are happening every minute. To be able to plan ahead and see when the bus is leaving I need to show many departures on the mirror to see that far ahead in time. Would it be possible to set a limit to not show departures happening earlier then 15 min ahead since it would not be necessary to know that the subway is leaving in 1 min when I can’t get her there in time to catch it? This would clean up the mirror and save some space on the screen.
                            • AlvingerA
                              Alvinger @Klzow
                              @Klzow,
                              That shouldn’t be too hard to do. I will look into it. My current thinking is to introduce a new config value (something like “ignoreBefore=5” with default 0 for backward compatibility) Keep an eye on this thread for developments!
                              • AlvingerA
                                Alvinger @Alvinger
                                @Klzow,
                                I’ve uploaded a new version of the module. It has a new config option, skipMinutes, which allows you to skip departures occuring within skipMinutes from now. Feel free to try it out.
                                • FallandeGubbeF
                                  FallandeGubbe
                                  Hej!
                                  Excellent module. Would it be possible to get it to work on Raspberry Pi 1 ? I get it fully working with my Raspberry pi 3 , but when I try with my 1 I get “connection refused” when starting midori…
                                  … and when accessing the mirror via Chrome on my PC I see all modules loaded and working…
                                  • AlvingerA
                                    Alvinger
                                    @FallandeGubbe,
                                    I’m running it on a Raspberry Pi 1 B with 256MB so yes, it’s possible… :-)
                                    You can’t run MagicMirror out of the box but I wrote a post in another thread about it:
                                    [https://forum.magicmirror.builders/topic/1659/3-tries-3-fails-raspberry-b/13]
                                    FallandeGubbeF 1 Reply Last reply
                                    • FallandeGubbeF
                                      FallandeGubbe @Alvinger
                                      @Alvinger Thanks for replying! Yes, I know that Raspberry Pi 1 needs some manual work :)
                                      I followed the tutorial at https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
                                      and everything is working great! Until I try to install MMM-ResRobot. Something gets messed up apparently… But it works fine on my Raspberry Pi 3 … (same SD card, same image)
                                      OK, I’ll keep investigating then, since you got it working!!
                                      • AlvingerA
                                        Alvinger @FallandeGubbe
                                        @FallandeGubbe
                                        Maybe a stupid quesrion but did you run npm install after cloning the repository?
                                        • FallandeGubbeF
                                          @Alvinger No problem :)
                                          Yes , I did. And as mentioned - when I plug the SD-card into my RPi3 all work fine.
                                          When I plug the SD-card in my RPi1 midori won’t connect. If I remove MMM-resrobot from config-file and reboot MagicMirror works fine on my RPi 1 (all other modules load OK)…
                                          I find it strange …
                                          brobergB 1 Reply Last reply
                                          • brobergB
                                            broberg Project Sponsor @FallandeGubbe
                                            @FallandeGubbe @Alvinger could it have something to do with this :
                                            https://forum.magicmirror.builders/topic/922/modules-not-showing-up-on-kweb-or-midori
                                            There are other modules that midori doesn’t like apparently.
                                            • 2 / 7
