    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 219.1k Views 28 Watching
      selarp
      Thanks @Alvinger for an awesome module! However, I have a problem when I add more than one destination (to:). Displays only the result of the destination that appears first.
      Here is my config.js:
          module: "MMM-ResRobot",
          position: "left",
          header: "Departures from Skanör C",
              from: "740000950",   // ResRobot Station ID (or a comma-separated string of IDs)
              to: "740000003,740001586", // ResRobot Station ID of destination (or a comma-separated string of IDs)
              maximumEntries: 6,  // Number of departures to show on screen
              truncateAfter: 5,   // A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
              apiKey: ”[My API-key]"  // Your ResRobot apiKey
        Alvinger
        you need to specify a station id in “from” as well. “from” is used to find the station’s departures, “to” is used to differentiate between destinations going from the “from” station.
        Change “from” to ‘from: “740000950,740000950”’ to make it work as you want.
          selarp @Alvinger
          Of course! Thank you very much @Alvinger!
          • K Offline
            Klzow
            Hi!
            I have a question /idea /request.
            Would it be possible to set a limit in minutes in which the module won’t show departures before that limit?
            For example I have a 15 min walk to bus/subway and during rush hour in Stockholm lots of departures are happening every minute. To be able to plan ahead and see when the bus is leaving I need to show many departures on the mirror to see that far ahead in time. Would it be possible to set a limit to not show departures happening earlier then 15 min ahead since it would not be necessary to know that the subway is leaving in 1 min when I can’t get her there in time to catch it? This would clean up the mirror and save some space on the screen.
              Alvinger @Klzow
              @Klzow,
              That shouldn’t be too hard to do. I will look into it. My current thinking is to introduce a new config value (something like “ignoreBefore=5” with default 0 for backward compatibility) Keep an eye on this thread for developments!
                Alvinger @Alvinger
                @Klzow,
                I’ve uploaded a new version of the module. It has a new config option, skipMinutes, which allows you to skip departures occuring within skipMinutes from now. Feel free to try it out.
                • FallandeGubbeF Offline
                  FallandeGubbe
                  Hej!
                  Excellent module. Would it be possible to get it to work on Raspberry Pi 1 ? I get it fully working with my Raspberry pi 3 , but when I try with my 1 I get “connection refused” when starting midori…
                  … and when accessing the mirror via Chrome on my PC I see all modules loaded and working…
                    Alvinger
                    @FallandeGubbe,
                    I’m running it on a Raspberry Pi 1 B with 256MB so yes, it’s possible… :-)
                    You can’t run MagicMirror out of the box but I wrote a post in another thread about it:
                    [https://forum.magicmirror.builders/topic/1659/3-tries-3-fails-raspberry-b/13]
                    FallandeGubbeF 1 Reply Last reply Reply Quote 0
                      FallandeGubbe @Alvinger
                      @Alvinger Thanks for replying! Yes, I know that Raspberry Pi 1 needs some manual work :)
                      I followed the tutorial at https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
                      and everything is working great! Until I try to install MMM-ResRobot. Something gets messed up apparently… But it works fine on my Raspberry Pi 3 … (same SD card, same image)
                      OK, I’ll keep investigating then, since you got it working!!
                        Alvinger @FallandeGubbe
                        @FallandeGubbe
                        Maybe a stupid quesrion but did you run npm install after cloning the repository?
                          @Alvinger No problem :)
                          Yes , I did. And as mentioned - when I plug the SD-card into my RPi3 all work fine.
                          When I plug the SD-card in my RPi1 midori won’t connect. If I remove MMM-resrobot from config-file and reboot MagicMirror works fine on my RPi 1 (all other modules load OK)…
                          I find it strange …
                            broberg Project Sponsor @FallandeGubbe
                            @FallandeGubbe @Alvinger could it have something to do with this :
                            https://forum.magicmirror.builders/topic/922/modules-not-showing-up-on-kweb-or-midori
                            There are other modules that midori doesn’t like apparently.
                              Alvinger @broberg
                              @broberg @FallandeGubbe
                              One thing popped into my mind: the Pi 1 is much slower than a Pi 3 and loading all the modules takes quite some time. Could it be that you are trying to open midori before MagicMirror has loaded all the modules and therefore is refusing connections? That in itself was the reason I had to go with a script that checked that midori was listening before launching MagicMirror.
                              Have you checked with journalctl that magicmiror is ready for action?
                              FallandeGubbeF 1 Reply Last reply Reply Quote 1
                                @Alvinger aahh… I think you might be right! I will do some investigation on this!
                                Thanks! :thumbsup:
                                  albertc
                                  @Alvinger
                                  Is it possible to make the departure times show up as relative instead of absolute? As in: bus leaving in 5 mins, instead of at 09:44 (just as it looks at the bus stop).
                                  A 1 Reply Last reply Reply Quote -1
                                    Alvinger @albertc
                                    @albertc
                                    Not right now. This was a conscious decision on my part as the mirror updates fairly seldom. relative departure times would be showing the wrong info after one minute.
                                      MobbareKurtZ
                                      Module doesn’t show anything except the header for me, found this in the logs:
                                      node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: [object Object]
                                      What to do?
                                        MobbareKurtZ @MobbareKurtZ
                                        @MobbareKurtZ said in MMM-ResRobot - Public transport information for Sweden:
                                        What to do?
                                        Oh I think I got it. You can’t have a route that isn’t a direct run?
                                          albertc @Alvinger
                                          @Alvinger
                                          Thanks for the response! But wouldn’t it be possible to use the (seldomly updated) time and subtract real time and still have an accurate “time left to departure”? I guess the table on screen would need to be updated more often than data is loaded.
                                            Alvinger @MobbareKurtZ
                                            @MobbareKurtZ
                                            It all depends on the underlying ResRobot API but it sounds reasonable that ResRobot needs to know in what direction you are travelling.
                                            As the module only shows departures there is no need to specify a destination unless you want to limit the displayed departures to the ones going in that specific direction. In that case I would suggest to enter not the ultimate destination but rather the next “logical” stop such as point of transit between modes of transport.
                                            • 2 / 7
