    Fullscreen help
    15 Posts 3 Posters 4.4k Views 3 Watching
      prvrami
      Hey,
      Need some help with to make MM fullscreen. As seen in photo attached, i can’t get rid of the MagicMirror header on Midori browser and neither the white edges.
      Please, your solution will be highly appreciated.
      Regards,
        sdetweil @prvrami
        @prvrami hit f11 key?
          prvrami @sdetweil
          @sdetweil if it was that easy…
            sdetweil @prvrami
            @prvrami everybody else uses that
            S P 2 Replies Last reply Reply Quote 0
              @prvrami looks like you have to pass param to get it to go fs
              midori -e Fullscreen -a [url_to_site]
                prvrami @sdetweil
                @sdetweil ok, i give up. Tried a common keyboard, tried VNC-ing from my laptop but nothing seems to work. Is there another key combination for Midori ?
                  sdetweil @prvrami
                  @prvrami i didn’t find any keyboard operation to go fs, in my google searches
                  see my comment about about parameter
                    prvrami @sdetweil
                    @sdetweil said in Fullscreen help:
                    i -e Ful
                    is already set
                      prvrami @sdetweil
                      #!/bin/sh
                      unclutter &
                      xset -dpms
                      xset s off
                      xset s noblank
                      matchbox-window-manager &
                      midori -e Fullscreen -a http://localhost:8080
                        sdetweil @prvrami
                        @prvrami
                        unclutter &
                        xset -dpms
                        xset s off
                        xset s noblank
                        that turns off screen saver and power mgmt
                        that must be the trick
                          prvrami @sdetweil
                          I thought the same thing but it doesn’t work. Still the same after cutting the line you mentioned…
                            sdetweil @prvrami
                            @prvrami weird
                              prvrami @sdetweil
                              yeah, looks like i need to start from scratch. I honestly don’t know why i can’t go fullscreen…
                                prvrami
                                Update: Reinstalled everything from scratch, still the same. Changed the sd card, reinstalled again and everything worked flawless. Cheers!
                                • V Offline
                                  valentindey
                                  For anyone experiencing similar problems, another solution could be to build midori from source.
                                  With midori v7.0.2 (latest you can install for raspberry os at the time of writing) I couldn’t get rid of the tab bar and some window borders. Building midori v9.0 from source it works nicely in full screen mode with the parameter -e Fullscreen. See description how to do that here https://github.com/midori-browser/core . There are also some related and resolved issues on github.
