    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp no images email or text
      (cannot do fixed font here)
      date	Name	age
      12	Sam	69
      2	Frank	81
              Sue	81
      5	mary	65
      10	eee EEEEE	51
      16	fff FFFFF	8
              ggg GGGGG	32
      27	hhh HHHHH	18
      code
      	getDom: function() {
      		var wrapper = this.createEl("div",null,null,null);
      		if(Object.keys(this.active_birthdays).length>0){
      			// create your table  here
      			var table = this.createEl("table", "birthday-table", null, wrapper );
      			// table header here, array of column names
      			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
      		    // create TBODY section with day names
      		    var tBody = this.createEl("tBody", "birthday-tbody", null, table );
      		    var birthdays_seen= {}
      			for(var birthday of Object.keys(this.active_birthdays)){
      				for(var person of this.active_birthdays[birthday]){
      				    var bodyTR = this.createEl("tr", null,null, tBody);
      				    		var bd =""
      					    	if(birthdays_seen[birthday] == undefined){
      					    		bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0]
                   				 	        birthdays_seen[birthday] = true
      					 	   var bodyTDimage = this.createEl("td",null, null, bodyTR , bd );
      					    var bodyTD = this.createEl("td", null, null, bodyTR , person.name);
      						var ageTD = this.createEl("td",null, null, bodyTR  ,person.age );
      // create your table footer here
      		// pass the created content back to MM to add to DOM.
      		return wrapper;
      • PerlchampP
        Perlchamp
        my code:
           createEl : function (type, id, className, parent, value) {
        	var el= document.createElement(type);
        	if(id)
        	    el.id = id;
        	if(className)
        	    el.className = className;
        	if(parent)
        	    parent.appendChild(el);
        	if(value)
        	    el.appendChild(document.createTextNode(value));
        	return el;
            createTableHeader: function(parent, className, columnlabels) {
        	var header = document.createElement("tr");
        	for(columnName of columnlabels) {
        	    this.createEl("th", null, className, header, columnName);
        	parent.appendChild(header);
        	return header;
        	Log.log(JSON.stringify(this.active_birthdays))
        	if ((moment() > this.midnight) || (!this.loaded)) {
        	    var month = moment().month();
        	    var year = moment().year();
        	    var monthName = moment().format("MMMM");
        	    var monthLength = moment().daysInMonth();
        	    if(Object.keys(this.active_birthdays).length>0) {
        		// create table
        		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper)
        		// create tableheader
        		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table);
        		for(var birthday of Object.keys(this.active_birthdays)) {
        		    for(var person of this.active_birthdays[birthday]) {
        			var bodyTR = this.createEl('tr', "birthday-tr-body", "tr-body" , tBody);
        			if (birthday.charAt(0) === "0") {
        			    birthday = birthday.replace("0","");
        			    birthday = birthday.substring(0,1);
        			var bodyTDimage = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, birthday.substring(0,2));
        			var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
        			var ageTD = this.createEl("td", "birthday-td-age", "TD-AGE", bodyTR  ,person.age );
        	    // Create TFOOT section -- currently used for debugging only
        	    return wrapper;
        	this.loaded = true;
          sdetweil @Perlchamp
          @Perlchamp the short birthday
          bd =(birthday.startsWith(“0”)? birthday.substring(1): birthday).split(‘.’)[0]
          if the birthday starts with ‘0’ then get the rest skipping the 0
          01.05 -> 1.05
          then split the result on ‘.’
          yields array of [ 1, 05]
          and take the first element in the array [0] = 1
          if it doesn’t start with 0,use the whole string, split and take the 1st element of array
          10.05 = [10,05] = 10
          • PerlchampP
            Perlchamp
            sorry, i’m still sorting my code …uff
            • PerlchampP
              Perlchamp
              back again. WITHOUT a class reference (third element = null) i see the days.
              WITH class-reference (“TD-IMAGE”) i see NO days.
              the rest is working very good, thank you for that :-)
                sdetweil @Perlchamp
                @Perlchamp what does TD-IMAGE class def look like?
                • PerlchampP
                  Perlchamp
                  .birthdaylist .TD-IMAGE {
                    width: 27px;
                    font-size: 20px;
                    color: #000000;
                    background-repeat: no-repeat;
                    background-position: top left;
                    background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                    font-weight: 400;
                    line-height: 26px;
                    vertical-align: top;
                    text-align: center;
                    margin: 0px;
                    padding: 10px 0px 0px 0px;
                    sdetweil @Perlchamp
                    @Perlchamp said in read csv-data and put it in an array:
                    .birthdaylist
                    there is no birthdaylist class being used (unless u changed the modulename again)
                    maybe
                    .TD-IMAGE {
                    • PerlchampP
                      Perlchamp
                      IT WORKS !!, Sam, it WORKS !
                      had a wrong image-name. that is UNPARDONABLE !!
                      now, this background-image will shown, if two people tzhe same day… problems, problems, problems …
                      SOLUTION: these people (same day) should be in ONE cell, separated by < /br > therefor i don’t need a third cell ;-)
                      @Perlchamp no images email or text => i would like sending emails (with attached images, too)
                      this is the homerun, touchdown and goal !
                        sdetweil @Perlchamp
                        @Perlchamp oh by the way TD-IMAGE color is black, on black background!
                        my email was in the chat message
                        • PerlchampP
                          Perlchamp
                          yes black on black, why not ? because of the mirrors lucidity … better safe than sorry ;-)
                            great progress. smaller more manageable code…
                            off to sleep
                            • PerlchampP
                              Perlchamp
                              bloody nice dreams, sam
                              • PerlchampP
                                Perlchamp
                                hi sam, for me it’s a milestone :
                                    // type: td, id: id of element, className: classname of element
                                    // parent: parent of element, value: value
                                	if(id)
                                	    el.id = id;
                                	if(className)
                                	if(parent)
                                	if(value)
                                	return el;
                                    // creates a tableheader with columnnaes
                                	return header;
                                    // creates a tablefooter with columns
                                    createTableFooter: function(parent, className, column) {
                                	var footer = document.createElement("tr");
                                	for(colContent of column) {
                                	    this.createEl("td", null, className, footer, colContent);
                                	parent.appendChild(footer);
                                	return footer;
                                    // this is the major worker of the module, it provides the
                                    // 	   displayable content for this module
                                	var wrapper = this.createEl("div",null,null,null,null);
                                	// tell MM to call and get our content
                                	Log.log(JSON.stringify(this.active_birthdays));
                                	    var now_day_month = moment().format("DD.MM");
                                	    if(Object.keys(this.active_birthdays).length > 0) {
                                		// create table
                                		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
                                		// create tableheader here
                                		var table_header = this.createTableHeader(table, null, [" "," "]);
                                		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
                                		var day_month_now = moment().format("DD.MM");
                                		var spacer = " ";
                                			// create looped row section
                                			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
                                			// delete leading 0 and month
                                			var bd = "";
                                			if(birthdays_seen[birthday] == undefined) {
                                			    bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                                             		    birthdays_seen[birthday] = true;
                                			let date1 = moment(birthday,'DD.MM').valueOf();
                                			let date2 = moment(now_day_month,'DD.MM').valueOf();
                                			if (date1 < date2) {
                                			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE_DIMMED" , bodyTR, bd);
                                			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY_DIMMED" , bodyTR, person.name);
                                			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE_DIMMED", nameTD, person.age);
                                			else {
                                			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, bd);
                                			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE", nameTD, person.age);
                                			var spacerTR = this.createEl('tr', null, null , tBody, null);
                                			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, spacer);
                                			spacerTD.colSpan = "2";
                                		if (this.config.debugging) {
                                		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
                                		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                                		else {
                                	    return wrapper;
                                	// Dom is loaded
                                	this.loaded = true;
                                css-file via email
                                • PerlchampP
                                  Perlchamp
                                  the next working step:
                                  			var bd = "";
                                  			let entrie = moment(birthday,'DD.MM').valueOf();
                                  			let now = moment(now_day_month,'DD.MM').valueOf();
                                  			if (entrie < now) {
                                  			    if(this.config.dimmEntries) {
                                  			    else {
                                  			else {
                                  now should be the last step:
                                  people who are their birthday at the same day in one cell separated by < /br > … that’s (maybe) too difficult for me, but just figuring out …
                                    sdetweil @Perlchamp
                                    @Perlchamp ok, busy at the moment… about an hour 13:30 my time
                                    • PerlchampP
                                      Perlchamp
                                      ok, doesn’t matter. enjoy your meal with your family.
                                      • PerlchampP
                                        Perlchamp
                                        i’m a step foward (did write two functions for smarter code) :
                                        	return footer;
                                            // compares two dates, requires moment.js :
                                            // output "1"  : date1 > date2
                                            // output "-1" : date1 < date2
                                            // output "0"  : fault
                                            compareDate: function(now, entrie, format) {
                                        	let date_1 = moment(now,format).valueOf();
                                        	let date_2 = moment(entrie,format).valueOf();
                                        	if (date_1 > date_2) {
                                        	    return 1;
                                        	else if (date_1 < date_2) {
                                        	    return -1;
                                        	else {
                                        	    return 0;
                                        the lastone is used here:
                                        			var bd = "";
                                        			if (this.compareDate(now,birthday,"DD.MM") === 1) {
                                        			    else {
                                        			else {
                                        it works fine for me :-). for the last step (people with the same birthday in one cell, separeted via < /br >) i have momently no ideas…
                                          sdetweil @Perlchamp
                                          @Perlchamp ok, not sure how u want to present the two people with the same date
                                          simplified code
                                          	getDom: function(){
                                          			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
                                          					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
                                          					let now = moment().format('DD.MM').valueOf();
                                          					let entrie=now
                                          					var bd = "";
                                          			    	if(birthdays_seen[birthday]==undefined){
                                          						var imageTD = this.createEl('td', null, "TD-IMAGE_"+(entrie < now)?"DIMMED":'' , bodyTR, bd);
                                          					else{
                                          						this.createEl('span', null , null , bodyTR,bd);
                                          					var nameTD = this.createEl('td', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' , bodyTR, person.name);
                                          					var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
                                          					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, "----");
                                          		return wrapper;
                                          maybe? but why?
                                          we have currently two rows, 3 columns
                                             day       name   age
                                             empty  name   age
                                          you want ?? two columns?
                                             row (2 cols)
                                               day      name + age < br>
                                                           name + age
                                             row (3 cols)
                                               dayn   name   age
                                          • PerlchampP
                                            Perlchamp
                                            hi sam,
                                            right row 2 cols day name + age < br > … < br > name+age < br >
                                            the image below displays that:
                                            look at my code, it’s all implemated but not the users in one cell :
                                            	    var now = moment();
                                            		// create table
                                            		var spacer = " ";
                                            			var bd = "";
                                            			    else {
                                            			else {
                                            		else {
                                            	    return wrapper;
                                            	// Dom is loaded
                                            	this.loaded = true;
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
