    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
    • PerlchampP
      Perlchamp
      back again. WITHOUT a class reference (third element = null) i see the days.
      WITH class-reference (“TD-IMAGE”) i see NO days.
      the rest is working very good, thank you for that :-)
        sdetweil @Perlchamp
        @Perlchamp what does TD-IMAGE class def look like?
        • PerlchampP
          Perlchamp
          .birthdaylist .TD-IMAGE {
            width: 27px;
            font-size: 20px;
            color: #000000;
            background-repeat: no-repeat;
            background-position: top left;
            background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
            font-weight: 400;
            line-height: 26px;
            vertical-align: top;
            text-align: center;
            margin: 0px;
            padding: 10px 0px 0px 0px;
            sdetweil @Perlchamp
            @Perlchamp said in read csv-data and put it in an array:
            .birthdaylist
            there is no birthdaylist class being used (unless u changed the modulename again)
            maybe
            .TD-IMAGE {
            • PerlchampP
              Perlchamp
              IT WORKS !!, Sam, it WORKS !
              had a wrong image-name. that is UNPARDONABLE !!
              now, this background-image will shown, if two people tzhe same day… problems, problems, problems …
              SOLUTION: these people (same day) should be in ONE cell, separated by < /br > therefor i don’t need a third cell ;-)
              @Perlchamp no images email or text => i would like sending emails (with attached images, too)
              this is the homerun, touchdown and goal !
                sdetweil @Perlchamp
                @Perlchamp oh by the way TD-IMAGE color is black, on black background!
                my email was in the chat message
                • PerlchampP
                  Perlchamp
                  yes black on black, why not ? because of the mirrors lucidity … better safe than sorry ;-)
                    great progress. smaller more manageable code…
                    off to sleep
                    • PerlchampP
                      Perlchamp
                      bloody nice dreams, sam
                      • PerlchampP
                        Perlchamp
                        hi sam, for me it’s a milestone :
                            // type: td, id: id of element, className: classname of element
                            // parent: parent of element, value: value
                            createEl : function (type, id, className, parent, value) {
                        	var el= document.createElement(type);
                        	if(id)
                        	    el.id = id;
                        	if(className)
                        	    el.className = className;
                        	if(parent)
                        	    parent.appendChild(el);
                        	if(value)
                        	    el.appendChild(document.createTextNode(value));
                        	return el;
                            // creates a tableheader with columnnaes
                            createTableHeader: function(parent, className, columnlabels) {
                        	var header = document.createElement("tr");
                        	for(columnName of columnlabels) {
                        	    this.createEl("th", null, className, header, columnName);
                        	parent.appendChild(header);
                        	return header;
                            // creates a tablefooter with columns
                            createTableFooter: function(parent, className, column) {
                        	var footer = document.createElement("tr");
                        	for(colContent of column) {
                        	    this.createEl("td", null, className, footer, colContent);
                        	parent.appendChild(footer);
                        	return footer;
                            // this is the major worker of the module, it provides the
                            // 	   displayable content for this module
                            getDom: function() {
                        	var wrapper = this.createEl("div",null,null,null,null);
                        	// tell MM to call and get our content
                        	Log.log(JSON.stringify(this.active_birthdays));
                        	if ((moment() > this.midnight) || (!this.loaded)) {
                        	    var month = moment().month();
                        	    var year = moment().year();
                        	    var monthName = moment().format("MMMM");
                        	    var monthLength = moment().daysInMonth();
                        	    var now_day_month = moment().format("DD.MM");
                        	    if(Object.keys(this.active_birthdays).length > 0) {
                        		// create table
                        		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
                        		// create tableheader here
                        		var table_header = this.createTableHeader(table, null, [" "," "]);
                        		// create TBODY section with day names
                        		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
                        		var day_month_now = moment().format("DD.MM");
                        		var birthdays_seen= {}
                        		var spacer = " ";
                        		for(var birthday of Object.keys(this.active_birthdays)) {
                        		    for(var person of this.active_birthdays[birthday]) {
                        			// create looped row section
                        			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
                        			// delete leading 0 and month
                        			var bd = "";
                        			if(birthdays_seen[birthday] == undefined) {
                        			    bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                                     		    birthdays_seen[birthday] = true;
                        			let date1 = moment(birthday,'DD.MM').valueOf();
                        			let date2 = moment(now_day_month,'DD.MM').valueOf();
                        			if (date1 < date2) {
                        			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE_DIMMED" , bodyTR, bd);
                        			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY_DIMMED" , bodyTR, person.name);
                        			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE_DIMMED", nameTD, person.age);
                        			else {
                        			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, bd);
                        			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
                        			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE", nameTD, person.age);
                        			var spacerTR = this.createEl('tr', null, null , tBody, null);
                        			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, spacer);
                        			spacerTD.colSpan = "2";
                        		// Create TFOOT section -- currently used for debugging only
                        		if (this.config.debugging) {
                        		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
                        		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                        		else {
                        	    // pass the created content back to MM to add to DOM.
                        	    return wrapper;
                        	// Dom is loaded
                        	this.loaded = true;
                        css-file via email
                        • PerlchampP
                          Perlchamp
                          the next working step:
                          			var bd = "";
                          			let entrie = moment(birthday,'DD.MM').valueOf();
                          			let now = moment(now_day_month,'DD.MM').valueOf();
                          			if (entrie < now) {
                          			    if(this.config.dimmEntries) {
                          			    else {
                          			else {
                          now should be the last step:
                          people who are their birthday at the same day in one cell separated by < /br > … that’s (maybe) too difficult for me, but just figuring out …
                            sdetweil @Perlchamp
                            @Perlchamp ok, busy at the moment… about an hour 13:30 my time
                            • PerlchampP
                              Perlchamp
                              ok, doesn’t matter. enjoy your meal with your family.
                              • PerlchampP
                                Perlchamp
                                i’m a step foward (did write two functions for smarter code) :
                                	return footer;
                                    // compares two dates, requires moment.js :
                                    // output "1"  : date1 > date2
                                    // output "-1" : date1 < date2
                                    // output "0"  : fault
                                    compareDate: function(now, entrie, format) {
                                	let date_1 = moment(now,format).valueOf();
                                	let date_2 = moment(entrie,format).valueOf();
                                	if (date_1 > date_2) {
                                	    return 1;
                                	else if (date_1 < date_2) {
                                	    return -1;
                                	else {
                                	    return 0;
                                the lastone is used here:
                                			var bd = "";
                                			if (this.compareDate(now,birthday,"DD.MM") === 1) {
                                			    else {
                                			else {
                                it works fine for me :-). for the last step (people with the same birthday in one cell, separeted via < /br >) i have momently no ideas…
                                  sdetweil @Perlchamp
                                  @Perlchamp ok, not sure how u want to present the two people with the same date
                                  simplified code
                                  	getDom: function(){
                                  		var wrapper = this.createEl("div",null,null,null);
                                  		if(Object.keys(this.active_birthdays).length>0){
                                  			// create your table  here
                                  			var table = this.createEl("table", "birthday-table", null, wrapper );
                                  			// table header here, array of column names
                                  			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                                  			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
                                  					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
                                  					let now = moment().format('DD.MM').valueOf();
                                  					let entrie=now
                                  					var bd = "";
                                  			    	if(birthdays_seen[birthday]==undefined){
                                  						var imageTD = this.createEl('td', null, "TD-IMAGE_"+(entrie < now)?"DIMMED":'' , bodyTR, bd);
                                  					else{
                                  						this.createEl('span', null , null , bodyTR,bd);
                                  					var nameTD = this.createEl('td', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' , bodyTR, person.name);
                                  					var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
                                  					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, "----");
                                  		return wrapper;
                                  maybe? but why?
                                  we have currently two rows, 3 columns
                                     day       name   age
                                     empty  name   age
                                  you want ?? two columns?
                                     row (2 cols)
                                       day      name + age < br>
                                                   name + age
                                     row (3 cols)
                                       dayn   name   age
                                  • PerlchampP
                                    Perlchamp
                                    hi sam,
                                    right row 2 cols day name + age < br > … < br > name+age < br >
                                    the image below displays that:
                                    look at my code, it’s all implemated but not the users in one cell :
                                    	    var now = moment();
                                    		// create table
                                    		var spacer = " ";
                                    			var bd = "";
                                    			    else {
                                    			else {
                                    		else {
                                    	    return wrapper;
                                    	// Dom is loaded
                                    	this.loaded = true;
                                      sdetweil @Perlchamp
                                      @Perlchamp i missed the span instead of td for age… working on the join
                                      • PerlchampP
                                        Perlchamp
                                        i have the span ! look in my code !
                                          sdetweil @Perlchamp
                                          @Perlchamp
                                          updated
                                          	getDom: function(){
                                          					let entrie=now
                                          					var bd = "";
                                          									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
                                          						var spanTDo = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
                                          					else{
                                          						// add a break
                                          						this.createEl('br', null , null , spanTDo,null);
                                          						// add a span with name
                                          						var nameTD = this.createEl('span', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' ,spanTDo, person.name);
                                          						// add a span with age
                                          						var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', spanTDo, person.age);
                                          					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
                                          		return wrapper;
                                          if we see 1st time br, do date, name/span/age
                                          if second time add line break to old name list
                                          add span for name, span span for separator (need class for width), span for age
                                          • PerlchampP
                                            Perlchamp
                                            first i have to change my classes ? instead of TD-IMAGE TD-IMAGE_, ?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
