    read csv-data and put it in an array
    313 Posts 3 Posters 579.0k Views 4 Watching
    • PerlchampP
      Perlchamp
      bloody nice dreams, sam
      • PerlchampP
        Perlchamp
        hi sam, for me it’s a milestone :
            // type: td, id: id of element, className: classname of element
            // parent: parent of element, value: value
            createEl : function (type, id, className, parent, value) {
        	var el= document.createElement(type);
        	if(id)
        	    el.id = id;
        	if(className)
        	    el.className = className;
        	if(parent)
        	    parent.appendChild(el);
        	if(value)
        	    el.appendChild(document.createTextNode(value));
        	return el;
            // creates a tableheader with columnnaes
            createTableHeader: function(parent, className, columnlabels) {
        	var header = document.createElement("tr");
        	for(columnName of columnlabels) {
        	    this.createEl("th", null, className, header, columnName);
        	parent.appendChild(header);
        	return header;
            // creates a tablefooter with columns
            createTableFooter: function(parent, className, column) {
        	var footer = document.createElement("tr");
        	for(colContent of column) {
        	    this.createEl("td", null, className, footer, colContent);
        	parent.appendChild(footer);
        	return footer;
            // this is the major worker of the module, it provides the
            // 	   displayable content for this module
            getDom: function() {
        	var wrapper = this.createEl("div",null,null,null,null);
        	// tell MM to call and get our content
        	Log.log(JSON.stringify(this.active_birthdays));
        	if ((moment() > this.midnight) || (!this.loaded)) {
        	    var month = moment().month();
        	    var year = moment().year();
        	    var monthName = moment().format("MMMM");
        	    var monthLength = moment().daysInMonth();
        	    var now_day_month = moment().format("DD.MM");
        	    if(Object.keys(this.active_birthdays).length > 0) {
        		// create table
        		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
        		// create tableheader here
        		var table_header = this.createTableHeader(table, null, [" "," "]);
        		// create TBODY section with day names
        		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
        		var day_month_now = moment().format("DD.MM");
        		var birthdays_seen= {}
        		var spacer = " ";
        		for(var birthday of Object.keys(this.active_birthdays)) {
        		    for(var person of this.active_birthdays[birthday]) {
        			// create looped row section
        			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
        			// delete leading 0 and month
        			var bd = "";
        			if(birthdays_seen[birthday] == undefined) {
        			    bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                     		    birthdays_seen[birthday] = true;
        			let date1 = moment(birthday,'DD.MM').valueOf();
        			let date2 = moment(now_day_month,'DD.MM').valueOf();
        			if (date1 < date2) {
        			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE_DIMMED" , bodyTR, bd);
        			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY_DIMMED" , bodyTR, person.name);
        			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE_DIMMED", nameTD, person.age);
        			else {
        			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, bd);
        			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
        			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE", nameTD, person.age);
        			var spacerTR = this.createEl('tr', null, null , tBody, null);
        			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, spacer);
        			spacerTD.colSpan = "2";
        		// Create TFOOT section -- currently used for debugging only
        		if (this.config.debugging) {
        		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
        		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
        		else {
        	    // pass the created content back to MM to add to DOM.
        	    return wrapper;
        	// Dom is loaded
        	this.loaded = true;
        css-file via email
        • PerlchampP
          Perlchamp
          the next working step:
          			var bd = "";
          			let entrie = moment(birthday,'DD.MM').valueOf();
          			let now = moment(now_day_month,'DD.MM').valueOf();
          			if (entrie < now) {
          			    if(this.config.dimmEntries) {
          			    else {
          			else {
          now should be the last step:
          people who are their birthday at the same day in one cell separated by < /br > … that’s (maybe) too difficult for me, but just figuring out …
            sdetweil @Perlchamp
            @Perlchamp ok, busy at the moment… about an hour 13:30 my time
            • PerlchampP
              Perlchamp
              ok, doesn’t matter. enjoy your meal with your family.
              • PerlchampP
                Perlchamp
                i’m a step foward (did write two functions for smarter code) :
                	return footer;
                    // compares two dates, requires moment.js :
                    // output "1"  : date1 > date2
                    // output "-1" : date1 < date2
                    // output "0"  : fault
                    compareDate: function(now, entrie, format) {
                	let date_1 = moment(now,format).valueOf();
                	let date_2 = moment(entrie,format).valueOf();
                	if (date_1 > date_2) {
                	    return 1;
                	else if (date_1 < date_2) {
                	    return -1;
                	else {
                	    return 0;
                the lastone is used here:
                			var bd = "";
                			if (this.compareDate(now,birthday,"DD.MM") === 1) {
                			    else {
                			else {
                it works fine for me :-). for the last step (people with the same birthday in one cell, separeted via < /br >) i have momently no ideas…
                  sdetweil @Perlchamp
                  @Perlchamp ok, not sure how u want to present the two people with the same date
                  simplified code
                  	getDom: function(){
                  		var wrapper = this.createEl("div",null,null,null);
                  		if(Object.keys(this.active_birthdays).length>0){
                  			// create your table  here
                  			var table = this.createEl("table", "birthday-table", null, wrapper );
                  			// table header here, array of column names
                  			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                  			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
                  					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
                  					let now = moment().format('DD.MM').valueOf();
                  					let entrie=now
                  					var bd = "";
                  			    	if(birthdays_seen[birthday]==undefined){
                  						var imageTD = this.createEl('td', null, "TD-IMAGE_"+(entrie < now)?"DIMMED":'' , bodyTR, bd);
                  					else{
                  						this.createEl('span', null , null , bodyTR,bd);
                  					var nameTD = this.createEl('td', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' , bodyTR, person.name);
                  					var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
                  					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, "----");
                  		return wrapper;
                  maybe? but why?
                  we have currently two rows, 3 columns
                     day       name   age
                     empty  name   age
                  you want ?? two columns?
                     row (2 cols)
                       day      name + age < br>
                                   name + age
                     row (3 cols)
                       dayn   name   age
                  • PerlchampP
                    Perlchamp
                    hi sam,
                    right row 2 cols day name + age < br > … < br > name+age < br >
                    the image below displays that:
                    look at my code, it’s all implemated but not the users in one cell :
                    	    var now = moment();
                    		// create table
                    		var spacer = " ";
                    			var bd = "";
                    			    else {
                    			else {
                    		else {
                    	    return wrapper;
                    	// Dom is loaded
                    	this.loaded = true;
                      sdetweil @Perlchamp
                      @Perlchamp i missed the span instead of td for age… working on the join
                      • PerlchampP
                        Perlchamp
                        i have the span ! look in my code !
                          sdetweil @Perlchamp
                          @Perlchamp
                          updated
                          	getDom: function(){
                          					let entrie=now
                          					var bd = "";
                          									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
                          						var spanTDo = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
                          					else{
                          						// add a break
                          						this.createEl('br', null , null , spanTDo,null);
                          						// add a span with name
                          						var nameTD = this.createEl('span', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' ,spanTDo, person.name);
                          						// add a span with age
                          						var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', spanTDo, person.age);
                          					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
                          		return wrapper;
                          if we see 1st time br, do date, name/span/age
                          if second time add line break to old name list
                          add span for name, span span for separator (need class for width), span for age
                          • PerlchampP
                            Perlchamp
                            first i have to change my classes ? instead of TD-IMAGE TD-IMAGE_, ?
                              sdetweil @Perlchamp
                              @Perlchamp the classname is a string
                              and the front part is the same
                              so , you had duplicated code, just to change the classname…
                              I just used your if(entrie) to decide it the name needed the’DIMMED" part added
                              move the _ to the “DIMMED”, like this “_DIMMED”
                              then they will be TD-IMAGE and TD-IMAGE_DIMMED , just like you had it…
                              its the same row data and parentage, just a class change… (nice work having common names, so you could do this), got rid of that big else…
                              • PerlchampP
                                Perlchamp
                                css i don’t get to work. here’s my getDom:
                                	    var now = moment();
                                		// create table
                                		// create tableheader here, array of column names
                                		var spacer = " ";
                                			let entrie=now;
                                			var bd = "";
                                			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                                			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                                			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
                                			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
                                			else{
                                			    // add a break
                                			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
                                			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
                                		else {
                                	    return wrapper;
                                	// Dom is loaded
                                	this.loaded = true;
                                there should be an error i don’t see.
                                  sdetweil @Perlchamp
                                  @Perlchamp use the debugger, expand the elements tree, find the table and look at the classes assigned
                                  • PerlchampP
                                    Perlchamp
                                    hi sam,
                                    if i do this:
                                       var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
                                    instead of this :
                                    var imageTD = this.createEl("td", null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                                    css are addressed. maybe something has to change in the createEl function ?
                                      sdetweil @Perlchamp
                                      @Perlchamp let me look…
                                        sdetweil @Perlchamp
                                        @Perlchamp
                                        warning one ( was missing, fixed
                                        SORRY… tested now… the + append didn’t work, had to force with concat()…
                                        Its the two values, now and entrie
                                        				let now = moment().format('DD.MM').valueOf();				 // this is string dd.mm
                                        				let entrie=now
                                        					entrie = moment(birthday,'DD.MM').format.valueOf();     // this is a moment
                                        so later when compared, it doesn;t work
                                        and comparing strings with < doesn’t really work…
                                        I would do
                                        let now=moment()
                                        let entrie = moment(birthday,‘DD.MM’)
                                        then in the compare
                                        (entrie.isBefore(now))?..
                                        	getDom: function(){
                                        					let now = moment()
                                        					let entrie=now
                                        					var bd = "";
                                        						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
                                        						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
                                        						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
                                        					else{
                                        						// add a break
                                        						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
                                        						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
                                        		return wrapper;
                                          @Perlchamp see my update above
                                          • PerlchampP
                                            Perlchamp
                                            @sdetweil said in read csv-data and put it in an array:
                                            sorry, doesn’t work. blackscreen. if i change back (my post) css is addressed. i didn’t change the jet = part. i think, something’s wrong with the cerateEl function, but you know i’m not an expert.but to control. here is my code :
                                            			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY", tBody, null);
                                            			let now = moment();
                                            			let entrie = moment(birthday,"DD.MM");
                                            			    entrie = moment(birthday,'DD.MM');
                                            			var bd = "";
                                            			    //var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                                            			    //var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
                                            			    var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                            			    this.createEl("span", null, "TD-AGE", nameTD, " ");
                                            			    //var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
                                            			    var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                                            			else{
                                            			    // add a break
                                            			    this.createEl("br", null , null , spanTDo, null);
                                            			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
                                            			    var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                                            			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
                                            			    var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                                            			var spacerTR = this.createEl("tr", null, null , tBody, null);
                                            			var spacerTD = this.createEl("td", null, "SPACER", spacerTR, " ");
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
