    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
    • PerlchampP
      Perlchamp
      the classes are not addressed :
      … without header and footer.
      why the classes are null ?
        sdetweil @Perlchamp
        @Perlchamp sorry, typo
        className with upper case
        	createEl : function (type, id, className, parent, value){
        		var el= document.createElement(type)
        		if(id)
        			el.id=id
        		if(className)
        			el.className=className
        		if(parent)
        			parent.appendChild(el)
        		if(value)
        			el.appendChild(document.createTextNode(value))
        		return el
        • PerlchampP
          Perlchamp
          i set the classes in uppercase, allthough in the css-file. but the classes are not adressed.
          by the way. maybe there is a problem with TWO cells in a row, because the daynumbers are OVER the names. if you look at the picture i send before (not the last post), than you can see, that the daynumbers are in ONE row with the names …
            sdetweil @Perlchamp
            @Perlchamp well, part of the problem is the ID of the cells is the same for each row… removing id and class (which I don’t have)
            works
            cells don’t NEED ids… but if u wanted, you would have to create a counter to append each loop to make the ids unique
            new createEl which does text value too
            		if(id)
            			el.id=id
            		if(className)
            		if(parent)
            		if(value)
            		return el
            and table header
            	createTableHeader: function(parent, className, columnlabels){
            		var header = document.createElement("tr")
            		for(columnName of columnlabels){
            			this.createEl("th",null,className, header,columnName)
            		parent.appendChild(header)
            		return header
            getdom()
            	// this is the major worker of the module, it provides the displayable content for this module
            	getDom: function() {
            		var wrapper = this.createEl("div",null,null,null);
            		if(Object.keys(this.active_birthdays).length>0){
            			// create your table  here
            			var table = this.createEl("table", "birthday-table", null, wrapper );
            			// table header here, array of column names
            			var table_header=this.createTableHeader(table, null, ["date","Name","age"])
            		    // create TBODY section with day names
            		    var tBody = this.createEl("tBody", "birthday-tbody", null, table );
            			for(var birthday of Object.keys(this.active_birthdays)){
            				for(var person of this.active_birthdays[birthday]){
            				    var bodyTR = this.createEl("tr", null,null, tBody);
            					    var bodyTDimage = this.createEl("td",null, null, bodyTR , birthday );
            					    var bodyTD = this.createEl("td", null, null, bodyTR , person.name);
            						var ageTD = this.createEl("td",null, null, bodyTR  ,person.age );
            // create your table footer here
            		// pass the created content back to MM to add to DOM.
            		return wrapper;
            • PerlchampP
              Perlchamp
              ok, i’ve seen, the header function … uff, all is placed right (code).
              i don’t see the day of birth. the first cell is still the problem :-(
                sdetweil @Perlchamp
                @Perlchamp with my code I see
                I removed class
                date Name age
                12.05 Sam 69
                02.05 Frank 81
                02.05 Sue 81
                05.05 mary 65
                10.05 eee EEEEE 51
                16.05 fff FFFFF 8
                16.05 ggg GGGGG 32
                27.05 hhh HHHHH 18
                • PerlchampP
                  Perlchamp
                  i have a calendar OVER the birthdaylist, so i DON#T need the month in the first cell. the FIRST cell has a calendar sheet as background-image, THOUGH i DON’T need the leading null of the day of birth. should be:
                  5 Sam 69
                  Mary 12
                  8 Frank 81
                  15 Sue 81
                  did you seen the images i did send ?
                  and, of course, people with the same day of birth without day of birth
                    sdetweil @Perlchamp
                    @Perlchamp no images email or text
                    (cannot do fixed font here)
                    date	Name	age
                    12	Sam	69
                    2	Frank	81
                            Sue	81
                    5	mary	65
                    10	eee EEEEE	51
                    16	fff FFFFF	8
                            ggg GGGGG	32
                    27	hhh HHHHH	18
                    code
                    			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                    		    var birthdays_seen= {}
                    				    		var bd =""
                    					    	if(birthdays_seen[birthday] == undefined){
                    					    		bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0]
                                 				 	        birthdays_seen[birthday] = true
                    					 	   var bodyTDimage = this.createEl("td",null, null, bodyTR , bd );
                    		return wrapper;
                    • PerlchampP
                      Perlchamp
                      my code:
                         createEl : function (type, id, className, parent, value) {
                      	var el= document.createElement(type);
                      	if(id)
                      	    el.id = id;
                      	if(className)
                      	    el.className = className;
                      	if(parent)
                      	    parent.appendChild(el);
                      	if(value)
                      	    el.appendChild(document.createTextNode(value));
                      	return el;
                          createTableHeader: function(parent, className, columnlabels) {
                      	var header = document.createElement("tr");
                      	for(columnName of columnlabels) {
                      	    this.createEl("th", null, className, header, columnName);
                      	parent.appendChild(header);
                      	return header;
                      	Log.log(JSON.stringify(this.active_birthdays))
                      	if ((moment() > this.midnight) || (!this.loaded)) {
                      	    var month = moment().month();
                      	    var year = moment().year();
                      	    var monthName = moment().format("MMMM");
                      	    var monthLength = moment().daysInMonth();
                      	    if(Object.keys(this.active_birthdays).length>0) {
                      		// create table
                      		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper)
                      		// create tableheader
                      		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table);
                      		for(var birthday of Object.keys(this.active_birthdays)) {
                      		    for(var person of this.active_birthdays[birthday]) {
                      			var bodyTR = this.createEl('tr', "birthday-tr-body", "tr-body" , tBody);
                      			if (birthday.charAt(0) === "0") {
                      			    birthday = birthday.replace("0","");
                      			    birthday = birthday.substring(0,1);
                      			var bodyTDimage = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, birthday.substring(0,2));
                      			var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
                      			var ageTD = this.createEl("td", "birthday-td-age", "TD-AGE", bodyTR  ,person.age );
                      	    // Create TFOOT section -- currently used for debugging only
                      	    return wrapper;
                      	this.loaded = true;
                        sdetweil @Perlchamp
                        @Perlchamp the short birthday
                        bd =(birthday.startsWith(“0”)? birthday.substring(1): birthday).split(‘.’)[0]
                        if the birthday starts with ‘0’ then get the rest skipping the 0
                        01.05 -> 1.05
                        then split the result on ‘.’
                        yields array of [ 1, 05]
                        and take the first element in the array [0] = 1
                        if it doesn’t start with 0,use the whole string, split and take the 1st element of array
                        10.05 = [10,05] = 10
                        • PerlchampP
                          Perlchamp
                          sorry, i’m still sorting my code …uff
                          • PerlchampP
                            Perlchamp
                            back again. WITHOUT a class reference (third element = null) i see the days.
                            WITH class-reference (“TD-IMAGE”) i see NO days.
                            the rest is working very good, thank you for that :-)
                              sdetweil @Perlchamp
                              @Perlchamp what does TD-IMAGE class def look like?
                              • PerlchampP
                                Perlchamp
                                .birthdaylist .TD-IMAGE {
                                  width: 27px;
                                  font-size: 20px;
                                  color: #000000;
                                  background-repeat: no-repeat;
                                  background-position: top left;
                                  background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                                  font-weight: 400;
                                  line-height: 26px;
                                  vertical-align: top;
                                  text-align: center;
                                  margin: 0px;
                                  padding: 10px 0px 0px 0px;
                                  sdetweil @Perlchamp
                                  @Perlchamp said in read csv-data and put it in an array:
                                  .birthdaylist
                                  there is no birthdaylist class being used (unless u changed the modulename again)
                                  maybe
                                  .TD-IMAGE {
                                  • PerlchampP
                                    Perlchamp
                                    IT WORKS !!, Sam, it WORKS !
                                    had a wrong image-name. that is UNPARDONABLE !!
                                    now, this background-image will shown, if two people tzhe same day… problems, problems, problems …
                                    SOLUTION: these people (same day) should be in ONE cell, separated by < /br > therefor i don’t need a third cell ;-)
                                    @Perlchamp no images email or text => i would like sending emails (with attached images, too)
                                    this is the homerun, touchdown and goal !
                                      sdetweil @Perlchamp
                                      @Perlchamp oh by the way TD-IMAGE color is black, on black background!
                                      my email was in the chat message
                                      • PerlchampP
                                        Perlchamp
                                        yes black on black, why not ? because of the mirrors lucidity … better safe than sorry ;-)
                                          great progress. smaller more manageable code…
                                          off to sleep
                                          • PerlchampP
                                            Perlchamp
                                            bloody nice dreams, sam
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
