    read csv-data and put it in an array
    313 Posts 3 Posters 579.0k Views 4 Watching
      @sdetweil said in read csv-data and put it in an array:
        headerTH.innerHTML = " ";
      all things are empty when created, so don’t need this
          else {
          footerTD.innerHTML = " ";
        don’t need this
          fixed createEl routine
          createEl : function (type, id, className, parent){
          	var el= document.createElement(type)
          	if(id)
          		el.id=id
          	if(className)
          		el.className=className
          	if(parent)
          		parent.appendChild(el)
          	return el
            new getDom(), without header or footer
            	getDom: function() {
            		var wrapper = this.createEl("div",null,null,null);
            		if(Object.keys(this.active_birthdays).length>0){
            			// create your table and header here
            		    // create TBODY section with day names
            		    var tBody = this.createEl("tBody", "birthday-tbody", "tbody", wrapper );
            			for(var birthday of Object.keys(this.active_birthdays)){
            				for(var person of this.active_birthdays[birthday]){
            				    var bodyTR = this.createEl("tr", "birthday-tr-body",null, tBody);
            					    var bodyTDimage = this.createEl("td","birthday-td-image", null, bodyTR );
            					    	bodyTDimage.appendChild(document.createTextNode(birthday));
            					    var bodyTD = this.createEl("td", "birthday-td-body", null, bodyTR );
            							bodyTD.appendChild(document.createTextNode(person.name));
            						var ageTD = this.createEl("td","birthday-td-age", null, bodyTR  );
            					    	ageTD.appendChild(document.createTextNode(person.age));
            // create your table footer here
            		// pass the created content back to MM to add to DOM.
            		return wrapper;
            • PerlchampP
              Perlchamp
              the classes are not addressed :
              … without header and footer.
              why the classes are null ?
                sdetweil @Perlchamp
                @Perlchamp sorry, typo
                className with upper case
                	createEl : function (type, id, className, parent, value){
                		if(id)
                			el.id=id
                		if(className)
                		if(parent)
                		if(value)
                			el.appendChild(document.createTextNode(value))
                		return el
                • PerlchampP
                  Perlchamp
                  i set the classes in uppercase, allthough in the css-file. but the classes are not adressed.
                  by the way. maybe there is a problem with TWO cells in a row, because the daynumbers are OVER the names. if you look at the picture i send before (not the last post), than you can see, that the daynumbers are in ONE row with the names …
                    sdetweil @Perlchamp
                    @Perlchamp well, part of the problem is the ID of the cells is the same for each row… removing id and class (which I don’t have)
                    works
                    cells don’t NEED ids… but if u wanted, you would have to create a counter to append each loop to make the ids unique
                    new createEl which does text value too
                    		if(id)
                    			el.id=id
                    		if(className)
                    		if(parent)
                    		if(value)
                    		return el
                    and table header
                    	createTableHeader: function(parent, className, columnlabels){
                    		var header = document.createElement("tr")
                    		for(columnName of columnlabels){
                    			this.createEl("th",null,className, header,columnName)
                    		parent.appendChild(header)
                    		return header
                    getdom()
                    	// this is the major worker of the module, it provides the displayable content for this module
                    			// create your table  here
                    			var table = this.createEl("table", "birthday-table", null, wrapper );
                    			// table header here, array of column names
                    			var table_header=this.createTableHeader(table, null, ["date","Name","age"])
                    		    var tBody = this.createEl("tBody", "birthday-tbody", null, table );
                    				    var bodyTR = this.createEl("tr", null,null, tBody);
                    					    var bodyTDimage = this.createEl("td",null, null, bodyTR , birthday );
                    					    var bodyTD = this.createEl("td", null, null, bodyTR , person.name);
                    						var ageTD = this.createEl("td",null, null, bodyTR  ,person.age );
                    		return wrapper;
                    • PerlchampP
                      Perlchamp
                      ok, i’ve seen, the header function … uff, all is placed right (code).
                      i don’t see the day of birth. the first cell is still the problem :-(
                        sdetweil @Perlchamp
                        @Perlchamp with my code I see
                        I removed class
                        date Name age
                        12.05 Sam 69
                        02.05 Frank 81
                        02.05 Sue 81
                        05.05 mary 65
                        10.05 eee EEEEE 51
                        16.05 fff FFFFF 8
                        16.05 ggg GGGGG 32
                        27.05 hhh HHHHH 18
                        • PerlchampP
                          Perlchamp
                          i have a calendar OVER the birthdaylist, so i DON#T need the month in the first cell. the FIRST cell has a calendar sheet as background-image, THOUGH i DON’T need the leading null of the day of birth. should be:
                          5 Sam 69
                          Mary 12
                          8 Frank 81
                          15 Sue 81
                          did you seen the images i did send ?
                          and, of course, people with the same day of birth without day of birth
                            sdetweil @Perlchamp
                            @Perlchamp no images email or text
                            (cannot do fixed font here)
                            date	Name	age
                            12	Sam	69
                            2	Frank	81
                                    Sue	81
                            5	mary	65
                            10	eee EEEEE	51
                            16	fff FFFFF	8
                                    ggg GGGGG	32
                            27	hhh HHHHH	18
                            code
                            			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                            		    var birthdays_seen= {}
                            				    		var bd =""
                            					    	if(birthdays_seen[birthday] == undefined){
                            					    		bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0]
                                         				 	        birthdays_seen[birthday] = true
                            					 	   var bodyTDimage = this.createEl("td",null, null, bodyTR , bd );
                            		return wrapper;
                            • PerlchampP
                              Perlchamp
                              my code:
                                 createEl : function (type, id, className, parent, value) {
                              	var el= document.createElement(type);
                              	if(id)
                              	    el.id = id;
                              	if(className)
                              	    el.className = className;
                              	if(parent)
                              	    parent.appendChild(el);
                              	if(value)
                              	    el.appendChild(document.createTextNode(value));
                              	return el;
                                  createTableHeader: function(parent, className, columnlabels) {
                              	var header = document.createElement("tr");
                              	for(columnName of columnlabels) {
                              	    this.createEl("th", null, className, header, columnName);
                              	parent.appendChild(header);
                              	return header;
                              	Log.log(JSON.stringify(this.active_birthdays))
                              	if ((moment() > this.midnight) || (!this.loaded)) {
                              	    var month = moment().month();
                              	    var year = moment().year();
                              	    var monthName = moment().format("MMMM");
                              	    var monthLength = moment().daysInMonth();
                              	    if(Object.keys(this.active_birthdays).length>0) {
                              		// create table
                              		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper)
                              		// create tableheader
                              		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table);
                              		for(var birthday of Object.keys(this.active_birthdays)) {
                              		    for(var person of this.active_birthdays[birthday]) {
                              			var bodyTR = this.createEl('tr', "birthday-tr-body", "tr-body" , tBody);
                              			if (birthday.charAt(0) === "0") {
                              			    birthday = birthday.replace("0","");
                              			    birthday = birthday.substring(0,1);
                              			var bodyTDimage = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, birthday.substring(0,2));
                              			var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
                              			var ageTD = this.createEl("td", "birthday-td-age", "TD-AGE", bodyTR  ,person.age );
                              	    // Create TFOOT section -- currently used for debugging only
                              	    return wrapper;
                              	this.loaded = true;
                                sdetweil @Perlchamp
                                @Perlchamp the short birthday
                                bd =(birthday.startsWith(“0”)? birthday.substring(1): birthday).split(‘.’)[0]
                                if the birthday starts with ‘0’ then get the rest skipping the 0
                                01.05 -> 1.05
                                then split the result on ‘.’
                                yields array of [ 1, 05]
                                and take the first element in the array [0] = 1
                                if it doesn’t start with 0,use the whole string, split and take the 1st element of array
                                10.05 = [10,05] = 10
                                • PerlchampP
                                  Perlchamp
                                  sorry, i’m still sorting my code …uff
                                  • PerlchampP
                                    Perlchamp
                                    back again. WITHOUT a class reference (third element = null) i see the days.
                                    WITH class-reference (“TD-IMAGE”) i see NO days.
                                    the rest is working very good, thank you for that :-)
                                      sdetweil @Perlchamp
                                      @Perlchamp what does TD-IMAGE class def look like?
                                      • PerlchampP
                                        Perlchamp
                                        .birthdaylist .TD-IMAGE {
                                          width: 27px;
                                          font-size: 20px;
                                          color: #000000;
                                          background-repeat: no-repeat;
                                          background-position: top left;
                                          background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                                          font-weight: 400;
                                          line-height: 26px;
                                          vertical-align: top;
                                          text-align: center;
                                          margin: 0px;
                                          padding: 10px 0px 0px 0px;
                                          sdetweil @Perlchamp
                                          @Perlchamp said in read csv-data and put it in an array:
                                          .birthdaylist
                                          there is no birthdaylist class being used (unless u changed the modulename again)
                                          maybe
                                          .TD-IMAGE {
                                          • PerlchampP
                                            Perlchamp
                                            IT WORKS !!, Sam, it WORKS !
                                            had a wrong image-name. that is UNPARDONABLE !!
                                            now, this background-image will shown, if two people tzhe same day… problems, problems, problems …
                                            SOLUTION: these people (same day) should be in ONE cell, separated by < /br > therefor i don’t need a third cell ;-)
                                            @Perlchamp no images email or text => i would like sending emails (with attached images, too)
                                            this is the homerun, touchdown and goal !
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
