    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp said in read csv-data and put it in an array:
      ", thead ,
      again all classes in quotes, ONLY parent NOT in quotes
       var wrapper = this.createEl('table', "birthday-table", "table" , null)
      	    var tHeader = this.createEl('thead', "birthday-thead", "thead" , wrapper )
      	    var headerTR = this.createEl('tr', "birthday-tr-head", "tr-head" , tHeader)
      	    var headerTH = this.createEl('th', "birthday-th-head", "th-head" , headerTR)
      • PerlchampP
        Perlchamp
        does not work for me. complete getDom and your createEl :
            createEl(type, id, class, parent){
        	var el = document.createElement(type);
        	el.id = id;
        	if(class);
        	el.classname = class;
        	parent.addChild(el);
        	return el;
            getDom: function() {
        	var self = this;
        	Log.log(JSON.stringify(this.active_birthdays))
        	if ((moment() > this.midnight) || (!this.loaded)) {
        	    var month = moment().month();
        	    var year = moment().year();
        	    var monthName = moment().format("MMMM");
        	    var monthLength = moment().daysInMonth();
        	    // create table
        	    var wrapper = this.createEl("table", "birthday-table", "table" , null)
        	    // create header
        	    var tHeader = this.createEl('thead', "birthday-thead", "thead" , wrapper)
        	    headerTH.colSpan = "2";
        	    headerTH.scope = "col";
        	    headerTH.innerHTML = " ";
        	    // Create TFOOT section -- currently used for debugging only
        	    var tFooter = this.createEl('tfoot', "birthday-tfood", "tfoot" , wrapper)
        	    var footerTR = this.createEl('tr', "birthday-tf-foot", "tr-foot" , tFooter)
        	    var footerTD = this.createEl('td', "birthday-td-foot", "td-foot" , footerTR)
        	    footerTD.colSpan ="2";
        	    if (this.config.debugging) {
        		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
        	    else {
        		footerTD.innerHTML = "&nbsp;";
        	    // create TBODY section with day names
        	    var tBody = this.createEl('tBody', "birthday-tbody", "tbody" , wrapper)
        	    for(var birthday of Object.keys(this.active_birthdays)) {
        		for(var person of this.active_birthdays[birthday]) {
        		    var bodyTR = this.createEl('tr', "birthday-tr-body", "tr-body" , tBody)
        		    var bodyTDimage = this.createEl('td', "birthday-td-image", "td-image" , bodyTR)
        		    if (birthday.charAt(0) === "0") {
        			birthday = birthday.replace("0","");
        			birthday = birthday.substring(0,1);
        		    bodyTDimage.innerHTML = birthday.substring(0,2);
        		    var bodyTD = this.createEl('td', "birthday-td-body", "td-body" , bodyTDimage)
        		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp; < span class=\"age-span\" > " + person.age + " < /span > ";
        	    return wrapper;
        	this.loaded = true;
          sdetweil @Perlchamp
          	    // create table
          	    var table = this.createEl("table", "birthday-table", "table" , wrapper)
          	    // create header
          	    var tHeader = this.createEl('thead', "birthday-thead", "thead" , table)
          	    var tFooter = this.createEl('tfoot', "birthday-tfood", "tfoot" , table)
          		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!< br />Please see console log.";
          	    else {
          		footerTD.innerHTML = " ";
          	    var tBody = this.createEl('tBody', "birthday-tbody", "tbody" , table)
          		    bodyTD.innerHTML = person.name + "    < span class=\"age-span\" > " + person.age + " < /span > ";
          what the html fragments with the < and space, they don’t work if there is a space there, need it for the forum, but won’t actually work
          S 2 Replies Last reply
            @sdetweil said in read csv-data and put it in an array:
            all things are empty when created, so don’t need this
                else {
              don’t need this
                fixed createEl routine
                createEl : function (type, id, className, parent){
                	var el= document.createElement(type)
                	if(id)
                		el.id=id
                	if(className)
                		el.className=className
                	if(parent)
                		parent.appendChild(el)
                	return el
                  new getDom(), without header or footer
                  		var wrapper = this.createEl("div",null,null,null);
                  		if(Object.keys(this.active_birthdays).length>0){
                  			// create your table and header here
                  		    var tBody = this.createEl("tBody", "birthday-tbody", "tbody", wrapper );
                  			for(var birthday of Object.keys(this.active_birthdays)){
                  				for(var person of this.active_birthdays[birthday]){
                  				    var bodyTR = this.createEl("tr", "birthday-tr-body",null, tBody);
                  					    var bodyTDimage = this.createEl("td","birthday-td-image", null, bodyTR );
                  					    	bodyTDimage.appendChild(document.createTextNode(birthday));
                  					    var bodyTD = this.createEl("td", "birthday-td-body", null, bodyTR );
                  							bodyTD.appendChild(document.createTextNode(person.name));
                  						var ageTD = this.createEl("td","birthday-td-age", null, bodyTR  );
                  					    	ageTD.appendChild(document.createTextNode(person.age));
                  // create your table footer here
                  		// pass the created content back to MM to add to DOM.
                  		return wrapper;
                  • PerlchampP
                    Perlchamp
                    the classes are not addressed :
                    … without header and footer.
                    why the classes are null ?
                      sdetweil @Perlchamp
                      @Perlchamp sorry, typo
                      className with upper case
                      	createEl : function (type, id, className, parent, value){
                      		if(id)
                      			el.id=id
                      		if(className)
                      		if(parent)
                      		if(value)
                      			el.appendChild(document.createTextNode(value))
                      		return el
                      • PerlchampP
                        Perlchamp
                        i set the classes in uppercase, allthough in the css-file. but the classes are not adressed.
                        by the way. maybe there is a problem with TWO cells in a row, because the daynumbers are OVER the names. if you look at the picture i send before (not the last post), than you can see, that the daynumbers are in ONE row with the names …
                          sdetweil @Perlchamp
                          @Perlchamp well, part of the problem is the ID of the cells is the same for each row… removing id and class (which I don’t have)
                          works
                          cells don’t NEED ids… but if u wanted, you would have to create a counter to append each loop to make the ids unique
                          new createEl which does text value too
                          		if(id)
                          			el.id=id
                          		if(className)
                          		if(parent)
                          		if(value)
                          		return el
                          and table header
                          	createTableHeader: function(parent, className, columnlabels){
                          		var header = document.createElement("tr")
                          		for(columnName of columnlabels){
                          			this.createEl("th",null,className, header,columnName)
                          		parent.appendChild(header)
                          		return header
                          getdom()
                          	// this is the major worker of the module, it provides the displayable content for this module
                          			// create your table  here
                          			var table = this.createEl("table", "birthday-table", null, wrapper );
                          			// table header here, array of column names
                          			var table_header=this.createTableHeader(table, null, ["date","Name","age"])
                          		    var tBody = this.createEl("tBody", "birthday-tbody", null, table );
                          				    var bodyTR = this.createEl("tr", null,null, tBody);
                          					    var bodyTDimage = this.createEl("td",null, null, bodyTR , birthday );
                          					    var bodyTD = this.createEl("td", null, null, bodyTR , person.name);
                          						var ageTD = this.createEl("td",null, null, bodyTR  ,person.age );
                          		return wrapper;
                          • PerlchampP
                            Perlchamp
                            ok, i’ve seen, the header function … uff, all is placed right (code).
                            i don’t see the day of birth. the first cell is still the problem :-(
                              sdetweil @Perlchamp
                              @Perlchamp with my code I see
                              I removed class
                              date Name age
                              12.05 Sam 69
                              02.05 Frank 81
                              02.05 Sue 81
                              05.05 mary 65
                              10.05 eee EEEEE 51
                              16.05 fff FFFFF 8
                              16.05 ggg GGGGG 32
                              27.05 hhh HHHHH 18
                              • PerlchampP
                                Perlchamp
                                i have a calendar OVER the birthdaylist, so i DON#T need the month in the first cell. the FIRST cell has a calendar sheet as background-image, THOUGH i DON’T need the leading null of the day of birth. should be:
                                5 Sam 69
                                Mary 12
                                8 Frank 81
                                15 Sue 81
                                did you seen the images i did send ?
                                and, of course, people with the same day of birth without day of birth
                                  sdetweil @Perlchamp
                                  @Perlchamp no images email or text
                                  (cannot do fixed font here)
                                  date	Name	age
                                  12	Sam	69
                                  2	Frank	81
                                          Sue	81
                                  5	mary	65
                                  10	eee EEEEE	51
                                  16	fff FFFFF	8
                                          ggg GGGGG	32
                                  27	hhh HHHHH	18
                                  code
                                  			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                                  		    var birthdays_seen= {}
                                  				    		var bd =""
                                  					    	if(birthdays_seen[birthday] == undefined){
                                  					    		bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0]
                                               				 	        birthdays_seen[birthday] = true
                                  					 	   var bodyTDimage = this.createEl("td",null, null, bodyTR , bd );
                                  		return wrapper;
                                  • PerlchampP
                                    Perlchamp
                                    my code:
                                       createEl : function (type, id, className, parent, value) {
                                    	var el= document.createElement(type);
                                    	if(id)
                                    	    el.id = id;
                                    	if(className)
                                    	    el.className = className;
                                    	if(parent)
                                    	    parent.appendChild(el);
                                    	if(value)
                                    	    el.appendChild(document.createTextNode(value));
                                    	return el;
                                        createTableHeader: function(parent, className, columnlabels) {
                                    	var header = document.createElement("tr");
                                    	for(columnName of columnlabels) {
                                    	    this.createEl("th", null, className, header, columnName);
                                    	parent.appendChild(header);
                                    	return header;
                                    	    if(Object.keys(this.active_birthdays).length>0) {
                                    		// create table
                                    		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper)
                                    		// create tableheader
                                    		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table);
                                    			var bodyTR = this.createEl('tr', "birthday-tr-body", "tr-body" , tBody);
                                    			var bodyTDimage = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, birthday.substring(0,2));
                                    			var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
                                    			var ageTD = this.createEl("td", "birthday-td-age", "TD-AGE", bodyTR  ,person.age );
                                    	    return wrapper;
                                    	this.loaded = true;
                                      sdetweil @Perlchamp
                                      @Perlchamp the short birthday
                                      bd =(birthday.startsWith(“0”)? birthday.substring(1): birthday).split(‘.’)[0]
                                      if the birthday starts with ‘0’ then get the rest skipping the 0
                                      01.05 -> 1.05
                                      then split the result on ‘.’
                                      yields array of [ 1, 05]
                                      and take the first element in the array [0] = 1
                                      if it doesn’t start with 0,use the whole string, split and take the 1st element of array
                                      10.05 = [10,05] = 10
                                      • PerlchampP
                                        Perlchamp
                                        sorry, i’m still sorting my code …uff
                                        • PerlchampP
                                          Perlchamp
                                          back again. WITHOUT a class reference (third element = null) i see the days.
                                          WITH class-reference (“TD-IMAGE”) i see NO days.
                                          the rest is working very good, thank you for that :-)
                                            sdetweil @Perlchamp
                                            @Perlchamp what does TD-IMAGE class def look like?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
