    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp sorry, typo
      className with upper case
      	createEl : function (type, id, className, parent, value){
      		var el= document.createElement(type)
      		if(id)
      			el.id=id
      		if(className)
      			el.className=className
      		if(parent)
      			parent.appendChild(el)
      		if(value)
      			el.appendChild(document.createTextNode(value))
      		return el
      • PerlchampP
        Perlchamp
        i set the classes in uppercase, allthough in the css-file. but the classes are not adressed.
        by the way. maybe there is a problem with TWO cells in a row, because the daynumbers are OVER the names. if you look at the picture i send before (not the last post), than you can see, that the daynumbers are in ONE row with the names …
          sdetweil @Perlchamp
          @Perlchamp well, part of the problem is the ID of the cells is the same for each row… removing id and class (which I don’t have)
          works
          cells don’t NEED ids… but if u wanted, you would have to create a counter to append each loop to make the ids unique
          new createEl which does text value too
          		if(id)
          			el.id=id
          		if(className)
          		if(parent)
          		if(value)
          		return el
          and table header
          	createTableHeader: function(parent, className, columnlabels){
          		var header = document.createElement("tr")
          		for(columnName of columnlabels){
          			this.createEl("th",null,className, header,columnName)
          		parent.appendChild(header)
          		return header
          getdom()
          	// this is the major worker of the module, it provides the displayable content for this module
          	getDom: function() {
          		var wrapper = this.createEl("div",null,null,null);
          		if(Object.keys(this.active_birthdays).length>0){
          			// create your table  here
          			var table = this.createEl("table", "birthday-table", null, wrapper );
          			// table header here, array of column names
          			var table_header=this.createTableHeader(table, null, ["date","Name","age"])
          		    // create TBODY section with day names
          		    var tBody = this.createEl("tBody", "birthday-tbody", null, table );
          			for(var birthday of Object.keys(this.active_birthdays)){
          				for(var person of this.active_birthdays[birthday]){
          				    var bodyTR = this.createEl("tr", null,null, tBody);
          					    var bodyTDimage = this.createEl("td",null, null, bodyTR , birthday );
          					    var bodyTD = this.createEl("td", null, null, bodyTR , person.name);
          						var ageTD = this.createEl("td",null, null, bodyTR  ,person.age );
          // create your table footer here
          		// pass the created content back to MM to add to DOM.
          		return wrapper;
          • PerlchampP
            Perlchamp
            ok, i’ve seen, the header function … uff, all is placed right (code).
            i don’t see the day of birth. the first cell is still the problem :-(
              sdetweil @Perlchamp
              @Perlchamp with my code I see
              I removed class
              date Name age
              12.05 Sam 69
              02.05 Frank 81
              02.05 Sue 81
              05.05 mary 65
              10.05 eee EEEEE 51
              16.05 fff FFFFF 8
              16.05 ggg GGGGG 32
              27.05 hhh HHHHH 18
              • PerlchampP
                Perlchamp
                i have a calendar OVER the birthdaylist, so i DON#T need the month in the first cell. the FIRST cell has a calendar sheet as background-image, THOUGH i DON’T need the leading null of the day of birth. should be:
                5 Sam 69
                Mary 12
                8 Frank 81
                15 Sue 81
                did you seen the images i did send ?
                and, of course, people with the same day of birth without day of birth
                  sdetweil @Perlchamp
                  @Perlchamp no images email or text
                  (cannot do fixed font here)
                  date	Name	age
                  12	Sam	69
                  2	Frank	81
                          Sue	81
                  5	mary	65
                  10	eee EEEEE	51
                  16	fff FFFFF	8
                          ggg GGGGG	32
                  27	hhh HHHHH	18
                  code
                  			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                  		    var birthdays_seen= {}
                  				    		var bd =""
                  					    	if(birthdays_seen[birthday] == undefined){
                  					    		bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0]
                               				 	        birthdays_seen[birthday] = true
                  					 	   var bodyTDimage = this.createEl("td",null, null, bodyTR , bd );
                  		return wrapper;
                  • PerlchampP
                    Perlchamp
                    my code:
                       createEl : function (type, id, className, parent, value) {
                    	var el= document.createElement(type);
                    	if(id)
                    	    el.id = id;
                    	if(className)
                    	    el.className = className;
                    	if(parent)
                    	    parent.appendChild(el);
                    	if(value)
                    	    el.appendChild(document.createTextNode(value));
                    	return el;
                        createTableHeader: function(parent, className, columnlabels) {
                    	var header = document.createElement("tr");
                    	for(columnName of columnlabels) {
                    	    this.createEl("th", null, className, header, columnName);
                    	parent.appendChild(header);
                    	return header;
                    	Log.log(JSON.stringify(this.active_birthdays))
                    	if ((moment() > this.midnight) || (!this.loaded)) {
                    	    var month = moment().month();
                    	    var year = moment().year();
                    	    var monthName = moment().format("MMMM");
                    	    var monthLength = moment().daysInMonth();
                    	    if(Object.keys(this.active_birthdays).length>0) {
                    		// create table
                    		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper)
                    		// create tableheader
                    		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table);
                    		for(var birthday of Object.keys(this.active_birthdays)) {
                    		    for(var person of this.active_birthdays[birthday]) {
                    			var bodyTR = this.createEl('tr', "birthday-tr-body", "tr-body" , tBody);
                    			if (birthday.charAt(0) === "0") {
                    			    birthday = birthday.replace("0","");
                    			    birthday = birthday.substring(0,1);
                    			var bodyTDimage = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, birthday.substring(0,2));
                    			var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
                    			var ageTD = this.createEl("td", "birthday-td-age", "TD-AGE", bodyTR  ,person.age );
                    	    // Create TFOOT section -- currently used for debugging only
                    	    return wrapper;
                    	this.loaded = true;
                      sdetweil @Perlchamp
                      @Perlchamp the short birthday
                      bd =(birthday.startsWith(“0”)? birthday.substring(1): birthday).split(‘.’)[0]
                      if the birthday starts with ‘0’ then get the rest skipping the 0
                      01.05 -> 1.05
                      then split the result on ‘.’
                      yields array of [ 1, 05]
                      and take the first element in the array [0] = 1
                      if it doesn’t start with 0,use the whole string, split and take the 1st element of array
                      10.05 = [10,05] = 10
                      • PerlchampP
                        Perlchamp
                        sorry, i’m still sorting my code …uff
                        • PerlchampP
                          Perlchamp
                          back again. WITHOUT a class reference (third element = null) i see the days.
                          WITH class-reference (“TD-IMAGE”) i see NO days.
                          the rest is working very good, thank you for that :-)
                            sdetweil @Perlchamp
                            @Perlchamp what does TD-IMAGE class def look like?
                            • PerlchampP
                              Perlchamp
                              .birthdaylist .TD-IMAGE {
                                width: 27px;
                                font-size: 20px;
                                color: #000000;
                                background-repeat: no-repeat;
                                background-position: top left;
                                background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                                font-weight: 400;
                                line-height: 26px;
                                vertical-align: top;
                                text-align: center;
                                margin: 0px;
                                padding: 10px 0px 0px 0px;
                                sdetweil @Perlchamp
                                @Perlchamp said in read csv-data and put it in an array:
                                .birthdaylist
                                there is no birthdaylist class being used (unless u changed the modulename again)
                                maybe
                                .TD-IMAGE {
                                • PerlchampP
                                  Perlchamp
                                  IT WORKS !!, Sam, it WORKS !
                                  had a wrong image-name. that is UNPARDONABLE !!
                                  now, this background-image will shown, if two people tzhe same day… problems, problems, problems …
                                  SOLUTION: these people (same day) should be in ONE cell, separated by < /br > therefor i don’t need a third cell ;-)
                                  @Perlchamp no images email or text => i would like sending emails (with attached images, too)
                                  this is the homerun, touchdown and goal !
                                    sdetweil @Perlchamp
                                    @Perlchamp oh by the way TD-IMAGE color is black, on black background!
                                    my email was in the chat message
                                    • PerlchampP
                                      Perlchamp
                                      yes black on black, why not ? because of the mirrors lucidity … better safe than sorry ;-)
                                        great progress. smaller more manageable code…
                                        off to sleep
                                        • PerlchampP
                                          Perlchamp
                                          bloody nice dreams, sam
                                          • PerlchampP
                                            Perlchamp
                                            hi sam, for me it’s a milestone :
                                                // type: td, id: id of element, className: classname of element
                                                // parent: parent of element, value: value
                                            	if(id)
                                            	    el.id = id;
                                            	if(className)
                                            	if(parent)
                                            	if(value)
                                            	return el;
                                                // creates a tableheader with columnnaes
                                            	return header;
                                                // creates a tablefooter with columns
                                                createTableFooter: function(parent, className, column) {
                                            	var footer = document.createElement("tr");
                                            	for(colContent of column) {
                                            	    this.createEl("td", null, className, footer, colContent);
                                            	parent.appendChild(footer);
                                            	return footer;
                                                // 	   displayable content for this module
                                            	var wrapper = this.createEl("div",null,null,null,null);
                                            	// tell MM to call and get our content
                                            	Log.log(JSON.stringify(this.active_birthdays));
                                            	    var now_day_month = moment().format("DD.MM");
                                            	    if(Object.keys(this.active_birthdays).length > 0) {
                                            		// create table
                                            		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
                                            		// create tableheader here
                                            		var table_header = this.createTableHeader(table, null, [" "," "]);
                                            		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
                                            		var day_month_now = moment().format("DD.MM");
                                            		var spacer = " ";
                                            			// create looped row section
                                            			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
                                            			// delete leading 0 and month
                                            			var bd = "";
                                            			if(birthdays_seen[birthday] == undefined) {
                                            			    bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                                                         		    birthdays_seen[birthday] = true;
                                            			let date1 = moment(birthday,'DD.MM').valueOf();
                                            			let date2 = moment(now_day_month,'DD.MM').valueOf();
                                            			if (date1 < date2) {
                                            			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE_DIMMED" , bodyTR, bd);
                                            			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY_DIMMED" , bodyTR, person.name);
                                            			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE_DIMMED", nameTD, person.age);
                                            			else {
                                            			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, bd);
                                            			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE", nameTD, person.age);
                                            			var spacerTR = this.createEl('tr', null, null , tBody, null);
                                            			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, spacer);
                                            			spacerTD.colSpan = "2";
                                            		if (this.config.debugging) {
                                            		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
                                            		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                                            		else {
                                            	    return wrapper;
                                            	// Dom is loaded
                                            	this.loaded = true;
                                            css-file via email
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
