    Having a blackscreen with no modules.
    5 Posts 2 Posters 794 Views 2 Watching
    • Y Offline
      yaboi
      So I just freshly installed MM on Windows, (no installation error) now I want to it on windows/in browser to costumize/change things easier.
      This had worked before the “BIG 1.11 Update” but doesnt now.
      The weird things is, when I do “npm run server” the server starts (localhost:8080), the LOG says the modules are loaded, but I dont see them in my browser.
      I tried to fix it, but I dont really know what to do.
      I’d really appreciate the help and have anice day (:
        sdetweil @yaboi
        @yaboi u had it on windows, now did an update to 2.11?
        did
        git pull
        npm install
        AND in EVERY module folder that has a package,json file do
        npm install
        then on browser, ctrl-shift-i or f12 to open developers window, and find the console tab
        • Y Offline
          yaboi @sdetweil
          @sdetweil Well, it installed it fresh, so did do any update? I mean “git pull” is unnecessary if I freshly installed?
          And for which reason should I open the console?
          And since I only have the defualt modules, none has a “package.json” file.
          Thanks for your reply.
            sdetweil @yaboi
            @yaboi oh, fresh install on windows, black screen
            the developers window will give you errors that caused the black screen
            but on windows do this
            cd MagicMirror
            cd vendor
            npm install
            cd ..\fonts
            npm install
            cd ..\MagicMirror
            edit package.json
            change the start line from
            to this
                "start": "node_modules/.bin/electron js/electron.js",
            • Y Offline
              yaboi @sdetweil
              @sdetweil Wow, you are a true legend, I had this issue with “DISPLAY” before, but since in the error message it only said something is wrong in the “electron js”, I never found it.
