MagicMirror keeps crashing within a minute of restart
@salbee how did u get to 2.11? install or upgrade?
how did u install or upgrade
@sdetweil it was an upgrade
@salbee how did u upgrade? pull, & npm install?
also need to do npm install in every module folder that has a package.json file
for future upgrades use the new upgrade script
see https://github.com/sdetweil/MagicMirror_scriptsalso, how did you do that start after uograde? npm start or use pm2?
if pm2, there might be something in the logs
pm2 logs --lines=100 -
@sdetweil After much troubleshooting, I’ve narrowed the problem down to only occur when I have screen rotation turned on (in the /boot/config.txt file). Changing the rotation approach to use the custom.css file instead, the problem has gone away.
@salbee glad u found it…
