Hide a module by default
Hi all,
I try to modify an existing module to put the fonctionnality for hidden it by default when the mirror start
explanation : i have the MMM-WiFiPassword configured on the first page, and i want it to not show when the Mirror started, and after that i can ask my assistant to show the wifi for a period.
I know i can hide it manually with RemoteControl, but i really want it to be Hidden at the start of the mirror.
have you an idea to help me ?
Thanks in advance!
@Burnallover in whatever function in the modulename.js
this.hide()will hide the module
and then check in the getDom() and only return an empty div (return the wrapper with nothing in it) -
@sdetweil thank for your response ! :)
I already tried to put something like that on function :
if (this.config.hide) { this.hide() }but i need some help for the getDom() part, i’m sorry i’m not a developper, can you give me an example of what it should be? sorry for my english, i’m french…
@Burnallover getDom() needs to return something, but u don’t want your content displayed. so
hidden: false, suspend: function(){ this.hidden=true }, restore: function(){ this.hidden=false }, notificationReceived: function(notification, payload, source){ // this comes before the first call to getDom() if(notification === "ALL_MODULES_STARTED") this.hidden=true; }. getDom: function (){ var wrapper=document.createElement('div') if(this.hidden==false){ //create normal content } return wrapper; },
