    Error on loading script (new module not working)
    3 Posts 2 Posters 304 Views 2 Watching
      Bobae
      I developed a new module. It seems okay,
      but if i try to load it, its aborted and not able to load
      [GET http://localhost:8080/modules/{mymodule} net::ERR_ABORTED 404 (Not Found)]
      [loader.js:187 Error on loading script: modules/{mymodule}]
      what could be the reason for this? Well probably my module has problems, so i attached it also.
      Thank you
      Module.register("mymodule",{
      	defaults: {
      		locationID: false,
      		apiKey: "",
      		apiBase: "https://api.openweathermap.org/data/2.5/weather",
      		animationSpeed: 1000,
      		updateInterval: 10 * 60 * 1000, // every 10 minutes
      	// Define required scripts.
      	getScripts: function() {
      		return ["moment.js"];
      	getStyles: function() {
      		return ["mymodule.css"];
      	// No translations
      	getTranslations: function() {
      		return false;
      	// Define start sequence.
      	  start: function() {
      	    // Set locale.
      	    moment.locale(config.language);
      	    this.type = null;
      		this.temperature = null;
      		this.loaded = false;
      		this.initialDelay = 0;
      		this.retryDelay = 2500;
      		this.scheduleUpdate(this.initialDelay);
      	getDom: function(){
      	    if (this.config.apikey === "") {
      	      wrapper.innerHTML = "Please set the valid APIKEY: " + this.name + ".";
      	      wrapper.className = "dimmed light small";
      	      return wrapper;
      	    if (!this.loaded) {
      	      wrapper.innerHTML = "LOADING";
      	      return wrapper;
      	    switch(this.type){
      			case "Rain":
      				wrapper.classList.add("rain");
      				break;
      			case "Drizzle": //이슬비
      				wrapper.classList.add("drizzle");
      				break;
      			case "Snow":
      				wrapper.classList.add("snow")
      				break;
      			case "Thunderstorm":
      				wrapper.classList.add("thunderstorm")
      				break;
      			case "default":
      				break;
      		if(this.temperature > 27){
      			var hot = document.createElement("span");
      			hot.classList.add("hot");
      			wrapper.appendChild(hot);
      		return wrapper;
      	updateWeather: function(){
      		if (this.config.apiKey === "") {
      			Log.error("RainAndSnow: Please set APIKEY");
      			return;
      		var url = this.config.apiBase + this.getParams();
      		var self = this;
      		var retry = true;
      		var request = new XMLHttpRequest();
      		request.open("GET", url, true);
      		request.onreadystatechange = function() {
      			if (this.readyState === 4) {
      				if (this.status === 200) {
      					self.processWeather(JSON.parse(this.response));
      				} else if (this.status === 401) {
      					self.updateDom(self.config.animationSpeed);
      					Log.error(self.name + ": Incorrect APIKEY.");
      					retry = true;
      				} else {
      					Log.error(self.name + ": Could not load weather.");
      				if (retry) {
      					self.scheduleUpdate((self.loaded) ? -1 : self.retryDelay);
      		request.send();
      	scheduleUpdate: function(delay){
      		var nextLoad = this.config.updateInterval;
      		if (typeof delay !== "undefined" && delay >= 0) {
      			nextLoad = delay;
      		var self = this;
      		setTimeout(function() {
      			self.updateWeather();
      		}, nextLoad);
      	processWeather: function(data){
      		if(!data) return;
      		this.type = data.weather[0].main;
      		this.temperature = data.main.temp - 273.15;
      		this.loaded = true;
      		this.updateDom(this.config.animationSpeed);
      	getParams: function(){
      		var params = "?";
      		if(this.config.locationID){
      			params += "id="+this.config.locationID;
      		else if(this.config.location){
      			params += "q="+this.config.location;
      		params += "&appid="+this.config.apiKey;
      		return params;
        sdetweil @Bobae
        @Bobae the name of the file you showed, we call it the modulename.js as the name MUST match the name of the module. which also must match the name of the folder the module is in
        and in config.js the name is the name of the folder
          module: 'name_of_module_folder',
          position: 'some screen position',
        i hope this is edited for the forum
        it just says that the name of the module in config.js doesn’t match the name of the folder
          Bobae @sdetweil
          @sdetweil Thank you! That one is edited for the forum actually, but anyway, you solved my problem ;)
