    MMM-RemoteCompliments does not appear
    18 Posts 5 Posters 3.9k Views 5 Watching
      justtrying
      Hi everyone I hope someone can help me out with this.
      I’m a newbie on the raspberri pi, and I tried to install MMM-RemoteCompliments as my first module.
      I followed the instructions, setup was a success, put the module code in my config.js, but when I start my MagicMirror the module does not show up, not even the header. I’ve tried moving it around, but it’s nowhere to be seen.
      I’ve checked my code, I even copy pasted it directly from the instructions to make sure I didn’t make a typo.
      The only thing I can think of is that I accidentally first installed the module in the wrong folder, and it might be an interference? I can’t get it removed though for some reason, so I can’t check if that’s the problem.
      Any help would be great!
      • bheplerB Offline
        bhepler Module Developer
        @justtrying - Are any of the other modules appearing? The clock, for example?
        The easiest way to check for errors is to check the logs. If you’re using PM2 to auto-start your mirror, then you can just enter pm2 log 0 and look for messages that contain “error”.
        If you don’t see anything there, you can check the front-end logs by stopping your mirror (pm2 stop 0, changing to the install directory (cd /home/pi/MagicMirror) and displaying the developer console: npm start dev. That will show you any errors that may be preventing your module from displaying.
        Let’s check on where you did install it. Get a terminal connection to your Pi (SSH into it, open a terminal on the pi itself, whatever). Once there, type ls /home/pi/MagicMirror/modules and see if the module is among the results. If it is not present, then you’ll have to clone it into the proper location.
        To do so, it’s just a handful of commands. Do this as the pi user, do not do this as root. One at a time:
        • change to the proper directory: cd /home/pi/MagicMirror/modules
        • clone the module from GitHub: git clone https://github.com/mitchelltmarino/MMM-RemoteCompliments.git
        • restart your mirror process: pm2 restart all
        Give these a try and report back. Remember to use the markdown features of the forum!
        S J 2 Replies Last reply Reply Quote 0
          sdetweil @bhepler
          @bhepler this module may/should fail as it depends on the googleapis library but unlikely it is installed…
          the module does not provide a package.json file (as it should) , but does document it
          Download dependencies
              Open the console and enter npm install googleapis
                    This will install the Google APIs service. (Working as of googleapis@33.0.0)
          • bheplerB Offline
            bhepler Module Developer @sdetweil
            @sdetweil Good point. It really should specify the google API as a dependency and tell you to install the module with npm.
              sdetweil @bhepler
              @bhepler it does, that is the text of the instructions
              really it should have a package.json, which documents all these and makes it so the user doesn’t have to read and type
                justtrying @bhepler
                @bhepler said in MMM-RemoteCompliments does not appear:
                ok so when I put in npm install googleapis
                I get the following error message:
                npm WARN checkPermissions Missing write access to /home/pi/node_modules/pm2
                npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                npm WARN pi No description
                npm WARN pi No repository field.
                npm WARN pi No README data
                npm WARN pi No license field.
                npm ERR! code EACCES
                npm ERR! syscall access
                npm ERR! path /home/pi/node_modules/pm2
                npm ERR! errno -13
                npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/pm2'
                npm ERR! { [Error: EACCES: permission denied, access '/home/pi/node_modules/pm2']
                npm ERR! stack:
                npm ERR! 'Error: EACCES: permission denied, access \'/home/pi/node_modules/pm2\'',
                npm ERR! errno: -13,
                npm ERR! code: 'EACCES',
                npm ERR! syscall: 'access',
                npm ERR! path: '/home/pi/node_modules/pm2' }
                npm ERR!
                npm ERR! The operation was rejected by your operating system.
                npm ERR! It is likely you do not have the permissions to access this file as the current user
                npm ERR!
                npm ERR! If you believe this might be a permissions issue, please double-check the
                npm ERR! permissions of the file and its containing directories, or try running
                npm ERR! the command again as root/Administrator.
                npm ERR! /home/pi/.npm/_logs/2020-06-12T08_24_18_697Z-debug.log
                I checked the location as instructed, and it showed that the installed modules were default en MMM-RemoteCompliments, so it is in the correct spot.
                I checked the log, and I get the following error message:
                pm2 log 0
                [TAILING] Tailing last 15 lines for [0] process (change the value with --lines option)
                /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                0|MagicMir | at loadConfig (/home/pi/MagicMirror/js/app.js:69:12)
                0|MagicMir | at App.start (/home/pi/MagicMirror/js/app.js:210:3)
                0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:115:7)
                0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:786:30)
                0|MagicMir | [2020-06-07 17:47:32.481] [ERROR] Calendar Error. Could not fetch calendar: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics Error: getaddrinfo EAI_AGAIN www.calendarlabs.com
                0|MagicMir | at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
                0|MagicMir | errno: 'EAI_AGAIN',
                0|MagicMir | code: 'EAI_AGAIN',
                0|MagicMir | syscall: 'getaddrinfo',
                0|MagicMir | hostname: 'www.calendarlabs.com'
                0|MagicMir | }
                0|MagicMir | [2020-06-07 17:47:32.704] [ERROR] fatal: unable to access 'https://github.com/mitchelltmarino/MMM-RemoteCompliments.git/': Could not resolve host: github.com
                0|MagicMir |
                0|MagicMir | [2020-06-07 17:47:32.710] [ERROR] fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/': Could not resolve host: github.com
                0|MagicMir |
                /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                0|MagicMir | at new driveFetcher (/home/pi/MagicMirror/modules/MMM-RemoteCompliments/Drive/DriveUtils.js:40:36)
                0|MagicMir | at Class.start (/home/pi/MagicMirror/modules/MMM-RemoteCompliments/node_helper.js:43:23)
                0|MagicMir | at /home/pi/MagicMirror/js/app.js:230:18
                0|MagicMir | at new Server (/home/pi/MagicMirror/js/server.js:84:3) {
                0|MagicMir | errno: -2,
                0|MagicMir | syscall: 'open',
                0|MagicMir | code: 'ENOENT',
                0|MagicMir | path: '/home/pi/MagicMirror/modules/MMM-RemoteCompliments/Drive/Token.json'
                0|MagicMir | }
                0|MagicMir | [2020-06-12 10:23:13.727] [LOG] Starting node helper for: MMM-RemoteCompliments
                0|MagicMir | [2020-06-12 10:23:13.727] [LOG] Sockets connected & modules started ...
                0|MagicMir | [2020-06-12 10:23:13.816] [LOG] [SIGINT] Received. Shutting down server...
                0|MagicMir | [2020-06-12 10:23:13.818] [LOG] Stopping module helper: updatenotification
                0|MagicMir | [2020-06-12 10:23:13.819] [LOG] Stopping module helper: calendar
                0|MagicMir | [2020-06-12 10:23:13.819] [LOG] Stopping module helper: MMM-RemoteCompliments
                npm ERR! errno -13
                npm ERR! stack:
                npm ERR!
                npm ERR!
                When I gave the same command again I got:
                pm2 log 0
                0|MagicMir | }
                0|MagicMir |
                0|MagicMir |
                0|MagicMir | }
                  @justtrying said in MMM-RemoteCompliments does not appear:
                  but it looks like you are not in the MM folder or the module folder where u need to install this
                  looks like you are in the users home folder (/home/pi)
                  for a module, you should be in
                  /home/pi/MagicMirror/modules/???modulename???
                    justtrying @sdetweil
                    I tried to do as you said, so changed it to MMM-RemoteCompliments, and got this:
                    pi@RideorDie:~/MagicMirror/modules/MMM-RemoteCompliments $ npm install googleapis
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    + googleapis@52.1.0
                    updated 1 package and audited 829 packages in 49.282s
                    29 packages are looking for funding
                      run `npm fund` for details
                    found 3 low severity vulnerabilities
                      run `npm audit fix` to fix them, or `npm audit` for details
                    Still no remote compliments showing up sadly. I’m thinking about rebooting the entire thing and reinstalling MM.
                      sdetweil @justtrying
                      @justtrying I haven’t used that. module. but maybe it has the same problem as remote control.
                      .see this topic
                      https://forum.magicmirror.builders/topic/12485/has-anyone-got-mmm-remote-control-working-on-mm-2-11/10?_=1593613231689
                      you have to restore one file back to 2.10 level. copy paste/replace file contents
                        @sdetweil Followed these instructions, still no module appearing. It really sucks, I tried reinstalling everything, followed every instruction to a T (even though the setup instructions are outdated), but it just doesn’t work.
                          @justtrying they introduced a bug in 2.11
                          fix was to. put back the 2.10 version of the file.
                          2.12 supposedly fixes it correctly. 2.12 has other problems
                            @sdetweil as I said, I followed the instructions, I changed the socketclient.js file, still nothing.
                            The MM is up to date as well.
                            • N Offline
                              Nero @justtrying
                              @justtrying Did you ever get this to show up, I have just gone through the installation and nothing shows on my mirror not even the header. Thank you
                              • T Offline
                                tf2
                                I would try starting over. I had a couple problems when I installed it, but I found every time the answers were actually in the instructions, just not quite how I would have expected to see them.
                                  sdetweil @tf2
                                  @tf2 u can also fork the repo, download it, edit the README.md file,add that change, push to your fork, and submit a pull request to the original repo to help others
                                  • T Offline
                                    tf2 @sdetweil
                                    @sdetweil I should have kept notes on what I didn’t do initially, but was in a hurry. I’ll be making a second mirror soon, and will do that.
                                      sdetweil @tf2
                                      @tf2 u don’t have to ‘install’ the repo to edit it.
                                      just git clone your fork somewhere
                                      • T Offline
                                        tf2 @sdetweil
                                        @sdetweil Sure. But if I don’t recall what problems I ran into and how I solved them, I won’t k ow what to modify in the documentation until I try following the instructions again.
