    MMM-Pages - Turn scripts on/off when enter page
    3 Posts 2 Posters 905 Views 2 Watching
    • thgmirrorT Offline
      thgmirror
      Hi all,
      Is it possible to start a script (Python or bash) when a specific page is entered? I use MM-Pages with a webradio on the third page. The idea is to start the webradio (mpc) combined with a script to get the lyrics of the currently played song (already developed) in case, page 3 is called. I don’t want to stress the lyrics-search if the affected page is not shown. So it would be nice have a trigger and to be able to start something on the PI.
      Thank you in advance
      Thomas
      • rubenixR Offline
        rubenix
        Take a look at MMM-NotificationTrigger module; Im using it for a lot of things; you can trigger any shell command when something happens (ie. When entering to page x)
        here just an example:
                    module: 'MMM-NotificationTrigger',
                        useWebhook: false,
                        triggers: [
                                trigger: "NEW_PAGE",
                                triggerPayloadFilter: (payload) => {
                                    if (payload == '0') return true		//when entering page 1
                                    return false
                                fires: [
                                    { exec: "aplay /home/pi/somefile.wav" },
                                    { fire: "MY_COMMAND", exec: "curl 'http://RaspHostname:8080/api//modules/MMM-Whatever/show'" },
                                    { fire: "MY_COMMAND", exec: "curl 'http://RaspHostname::8080/api//modules/MMM-Whatever/hide'" },
                                    { fire: "WHATEVER_NOTIFICATION },
                                   { fire: "MY_COMMAND", exec: "/home/pi/somescript.sh" },
        I consider this a MUST in any Magic Mirror setup…
        Can do anything you want with it :winking_face:
          thgmirror
          Hi @rubenix ,
          Thank you for your hint, I will give it a try.
          Greetings
          Thomas
