    Trying to install Manual and Automated
    5 Posts 2 Posters 374 Views 2 Watching
    • O Offline
      OptimisticShaggy
      When following the Magic Mirror manual install, I could across this issue:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.14.4
      3 info using node@v10.21.0
      5 info lifecycle magicmirror@2.11.0~prestart: magicmirror@2.11.0
      6 info lifecycle magicmirror@2.11.0~start: magicmirror@2.11.0
      7 verbose lifecycle magicmirror@2.11.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.11.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.11.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.11.0~start: Args: [ '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
      11 info lifecycle magicmirror@2.11.0~start: Failed to exec start script
      12 verbose stack Error: magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      12 verbose stack spawn ENOENT
      12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
      12 verbose stack     at ChildProcess.emit (events.js:198:13)
      12 verbose stack     at maybeClose (internal/child_process.js:982:16)
      12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      13 verbose pkgid magicmirror@2.11.0
      14 verbose cwd /home/pi/MagicMirror
      15 verbose Linux 4.19.118-v7+
      16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      17 verbose node v10.21.0
      18 verbose npm  v6.14.4
      19 error code ELIFECYCLE
      20 error syscall spawn
      21 error file sh
      22 error errno ENOENT
      23 error magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      23 error spawn ENOENT
      24 error Failed at the magicmirror@2.11.0 start script.
      24 error This is probably not a problem with npm. There is likely additional logging output above.
      25 verbose exit [ 1, true ]
      When following the Magic Mirror manual install by Sam, I have this log:
      install starting  - Thu Jun 25 14:09:52 EDT 2020
      installing on armv7l processor system
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      Updating packages ...
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://deb.nodesource.com/node_10.x buster InRelease Reading package lists...
      apt-get update  completed ok
      apt-get upgrade  started
      apt upgrade result =rc=0 Reading package lists...
      Building dependency tree...
      Reading state information...
      Calculating upgrade...
      The following package was automatically installed and is no longer required:
        rpi-eeprom-images
      Use 'sudo apt autoremove' to remove it.
      Installing helper tools ...
      build-essential is already the newest version (12.6).
      curl is already the newest version (7.64.0-4+deb10u1).
      git is already the newest version (1:2.20.1-2+deb10u3).
      unzip is already the newest version (6.0-23+deb10u1).
      wget is already the newest version (1.20.1-1.1).
      wget set to manually installed.
        rpi-eeprom-images
      Minimum Node version: v10.1.0
      Installed Node version: v10.21.0
      No Node.js upgrade necessary.
      Minimum npm version: V6.0.0
      Installed npm version: V6.14.4
      No npm upgrade necessary.
      Cloning MagicMirror ...
      Cloning MagicMirror Done!
      Installing dependencies ...
      > electron-chromedriver@6.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      > core-js@2.6.11 postinstall /home/pi/MagicMirror/node_modules/core-js
      > node -e "try{require('./postinstall')}catch(e){}"
      Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
      The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
      > https://opencollective.com/core-js
      > https://www.patreon.com/zloirock
      Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
      + eslint@7.3.1
      added 481 packages from 769 contributors and audited 775 packages in 63.015s
      25 packages are looking for funding
        run `npm fund` for details
      found 3 low severity vulnerabilities
        run `npm audit fix` to fix them, or `npm audit` for details
      Dependencies installation Done!
      fixing sandbox permissions
      setting up initial config.js
      Check plymouth installation ...
      plymouth is not installed.
      install and setup pm2
      pm2 not installed, installing
      pm2 install result /usr/bin/pm2 -> /usr/lib/node_modules/pm2/bin/pm2 /usr/bin/pm2-dev -> /usr/lib/node_modules/pm2/bin/pm2-dev /usr/bin/pm2-docker -> /usr/lib/node_modules/pm2/bin/pm2-docker /usr/bin/pm2-runtime -> /usr/lib/node_modules/pm2/bin/pm2-runtime npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/pm2/node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) + pm2@4.4.0 added 185 packages from 191 contributors in 32.831s
      get the pm2 platform specific startup command
      startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
      __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
       _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
        _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
         _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
          _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
           _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
            _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
             _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
              _\///______________\///______________\///__\///////////////__
                                Runtime Edition
              PM2 is a Production Process Manager for Node.js applications
                           with a built-in Load Balancer.
                      Start and Daemonize any application:
                      $ pm2 start app.js
                      Load Balance 4 instances of api.js:
                      $ pm2 start api.js -i 4
                      Monitor in production:
                      $ pm2 monitor
                      Make pm2 auto-boot at server restart:
                      $ pm2 startup
                      To go further checkout:
                      http://pm2.io/
      [PM2] Init System found: systemd
      Platform systemd
      Template
      [Unit]
      Description=PM2 process manager
      Documentation=https://pm2.keymetrics.io/
      After=network.target
      [Service]
      Type=forking
      User=pi
      LimitNOFILE=infinity
      LimitNPROC=infinity
      LimitCORE=infinity
      Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
      Environment=PM2_HOME=/home/pi/.pm2
      PIDFile=/home/pi/.pm2/pm2.pid
      Restart=on-failure
      ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
      ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
      ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
      [Install]
      WantedBy=multi-user.target
      Target path
      /etc/systemd/system/pm2-pi.service
      Command list
      [ 'systemctl enable pm2-pi' ]
      [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
      [PM2] Making script booting at startup...
      [PM2] [-] Executing: systemctl enable pm2-pi...
      [PM2] [v] Command successfully executed.
      [PM2] Freeze a process list on reboot via:
      $ pm2 save
      [PM2] Remove init script via:
      $ pm2 unstartup systemd
      pm2 startup command done
      configure the pm2 config file for MagicMirror
      start MagicMirror via pm2 now
      save MagicMirror pm2 config now
      stop MagicMirror via pm2 now
      We're ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
      install completed - Thu Jun 25 14:15:09 EDT 2020
      Could someone mention what I am doing wrong?
        sdetweil @OptimisticShaggy
        @OptimisticShaggy I don’t see a problem on my automated install
        so, then you can
        or
        npm start
        log is just for history in case there are problems…
          @OptimisticShaggy u are running the full buster, right, not the cli version… you MUST run the desktop version to support graphics, which allows electron to run
          • O Offline
            OptimisticShaggy
            No… I’m running the CLI version… Gonna be annoying if that is the reason.
            EDIT: With looking more into this, I was able to get it after a reinstall. After some research, I noticed that there a OS that Guysoft packaged together containing Raspbian lite in there. Is there anything we can do or any work currently to make MM work out of the box with Raspbian Lite and CLI?
              @OptimisticShaggy it will run in server mode.
              you have to have the desktop for a browser to work.
