    Problem with instalation on raspbian
    9 Posts 2 Posters 1.4k Views 2 Watching
    • E Offline
      Ety60
      Hello everyone,
      I used the Magic Mirror website installation guide, but I got the error that my node.js version is not supported by Magic Mirror (it was the node.js version that was on the website: version 10. I don’t now). So I installed the latest version of node.js (version 12.18.2) with this command:
      curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
      But then I got this error:
      > magicmirror@2.12.0 start /home/pi/MagicMirror
      sh: 1: ./node_modules/.bin/electron: not found
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.12.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2020-07-06T17_40_44_705Z-debug.log
      Can anyone help me?
        sdetweil @Ety60
        @Ety60 use the install script command from here
        if this is a pi0, electron is no longer available, but I set the system up in split mode the run chromium instead
        • E Offline
          Ety60
          I did it and it was successful. But what do I do now to restart the MagicMirror software? It still doesn’t work with this:
          cd MagicMirror
          npm run start
          I’m using an rpi 4 for this project.
            sdetweil @Ety60
            @Ety60 when u did the install, did u say yes to pm2?
            if so, then pm2 start 0 should work, also npm start should work
            if you did use pm2, then it will start at boot, so npm start would try to start a second copy.
            pm2 status will show u what is running
            • E Offline
              Ety60
              The program did not ask me to install pm2.
                sdetweil @Ety60
                @Ety60 then u did not use my script.
                does ~/install.log exist?
                • E Offline
                  Ety60
                  yes ~·install.log exist. So I think I used your script.
                    sdetweil @Ety60
                    @Ety60 and it should have prompted you, “Do you want to use pm2 to autostart your MagicMirror”
                    if u said n, and want to fix it, you can use the fixuppm2.sh script
                    • E Offline
                      Ety60
                      @sdetweil I tried to run the entire script again and this time asked me for pm2. It worked and MagicMirror now works. Thank you very much for your help!
