    MM won’t start after updating with update script
    5 Posts 3 Posters 993 Views 3 Watching
      panos
      Hello.
      I tried to update my MM using the update script:
      cd MagicMirror
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      (https://github.com/sdetweil/MagicMirror_scripts)
      When I was issued the command:
      pm2 log
      I got this error
      home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm       |     at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
      0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:551:3)
      0|mm       | A JavaScript error occurred in the main process
      0|mm       | Uncaught Exception:
      0|mm       | TypeError: Bind must be called on a function
      0|mm       |     at bind (<anonymous>)
      0|mm       |     at /home/pi/MagicMirror/js/logger.js:32:38
      0|mm       |     at /home/pi/MagicMirror/js/logger.js:16:20
      0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:21:3)
      0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:46:3)
      0|mm       |     at Module._compile (internal/modules/cjs/loader.js:711:30)
      0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
      0|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32)
      any suggestions?
        panos
        I was able to resolve the issue with the command:
        git pull && sudo npm install
        everything works now expect for weatherforecast module that displays only the next 2 instead of next 5 days of forecast.
        Not sure if this is a API limitation or somethings with new 2.12 MM version
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          uok825 @panos
          @panos Same forecast issue.
            panos
            Also, MM auto stops after some minutes with no reason.
            here is the logs:
            [2020-07-14 16:12:13.669] [LOG]    Sockets connected & modules started ...
            [2020-07-14 16:12:13.960] [LOG]    Launching application.
            [2020-07-14 16:12:14.620] [LOG]    Shutting down server...
            [2020-07-14 16:12:14.624] [LOG]    Stopping module helper: updatenotification
            [2020-07-14 16:12:14.625] [LOG]    Stopping module helper: calendar
            [2020-07-14 16:12:14.627] [LOG]    Stopping module helper: MMM-MoonPhase
            [2020-07-14 16:12:14.628] [LOG]    Stopping module helper: MMM-NowPlayingOnSpotify
            [2020-07-14 16:12:14.629] [LOG]    Stopping module helper: MMM-MyCommute
            [2020-07-14 16:12:14.631] [LOG]    Stopping module helper: MMM-MQTT
            [2020-07-14 16:12:14.632] [LOG]    Stopping module helper: MMM-GooglePhotos
            [2020-07-14 16:12:14.633] [LOG]    Stopping module helper: newsfeed
              sdetweil @panos
              @panos show more log info
              pm2 logs --lines=100
