    MMM-GoogleAssistantMk2 issues
    7 Posts 2 Posters 1.2k Views 2 Watching
    • blake_northrupB Offline
      blake_northrup
      Hey All, trying to get MMM-GoogleAssistantMk2 up, and have the token, auth code, and when doing the command: node auth_and_test.js it works, but when I add the module to the config file, I get the below error when starting MagicMirror.
      SyntaxError: Unexpected token }
      at Module._compile (internal/modules/cjs/loader.js:722:23)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
      at Module.load (internal/modules/cjs/loader.js:645:32)
      at Function.Module._load (internal/modules/cjs/loader.js:560:12)
      at Module.require (internal/modules/cjs/loader.js:685:19)
      at require (internal/modules/cjs/helpers.js:16:16)
      at loadConfig (/home/pi/MagicMirror/js/app.js:67:12)
      at App.start (/home/pi/MagicMirror/js/app.js:202:3)
      at Object. (/home/pi/MagicMirror/js/electron.js:126:7)
      at Module._compile (internal/modules/cjs/loader.js:786:30)
      When I put the basic config structure in, it opens, but it doesn’t respond to commands, and when I start adding some of the other stuff to the config, I get the below error. Any ideas?
      module: “MMM-AssistantMk2”,
      position: “top_right”,
      coordinates: {
      latitude: 51.5033640,
      longitude: -0.1276250,
      record: { // put there configuration generated by auto-installer
      recorder : “arecord”,
      device: “plughw:1”
        sdetweil @blake_northrup
        @blake_northrup AssistantMk2 has been discontinued.
        use MMM-GoogleAssistant by bugsuonet
        blake_northrupB 1 Reply Last reply Reply Quote 0
          blake_northrup @sdetweil
          @sdetweil said in MMM-GoogleAssistantMk2 issues:
          MMM-GoogleAssistant
          Hey sdetweil, sorry, meant that one. I followed all steps to a T, and am getting the above error.
            @blake_northrup but you are not
            cause u posted this
            blake_northrupB 3 Replies Last reply Reply Quote 0
              @sdetweil Yeah, sorry, been one of those days.
                @sdetweil I’m going to start over, and let you know. Thanks for the fast response.
                  @sdetweil so I had both MMM-GoogleAsistant, and the Mk2 one opened, and got myself confused. I appreciate the wakeup call sdetweil. The assistant is running along great now, thanks to you.
