Can't install MM on brand new Pi4
Hi all, brand new to MM and fairly new to Pi here. I tried a manual install of MM as well as the auto installer from @sdetweil and both failed. I completely reformatted my brand new SD card and did a fresh install of Raspbian and tried the auto installer again, and am getting the same errors.
I’ve noticed a few errors during the install process that may help troubleshoot, but I’m not sure how to fix them. Any help would be very much appreciated!
During the install dependencies:
Error: Generated checksum for "electron-v6.1.12-linux-armv7l.zip" did not match expected checksum. at Hash.hasher.on (/home/pi/MagicMirror/node_modules/sumchecker/index.js:151:20) at Hash.emit (events.js:198:13) at emitReadable_ (_stream_readable.js:555:12) at process._tickCallback (internal/process/next_tick.js:63:19) npm notice created a lockfile as package-lock.json. You should commit this file. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@6.1.12 (node_modules/electron): npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@6.1.12 postinstall: `node install.js` npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1Then once I get the “We’re ready! Run pm2 start MagicMirror” message and it shows “status” as online, but then nothing happens. If I try “npm start” from the MM directory, I get this error:
> magicmirror@2.12.0 start /home/pi/MagicMirror > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js sh: 1: ./node_modules/.bin/electron: not found npm ERR! code ELIFECYCLE npm ERR! syscall spawn npm ERR! file sh npm ERR! errno ENOENT npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js` npm ERR! spawn ENOENT npm ERR! npm ERR! Failed at the magicmirror@2.12.0 start script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-07-16T09_15_05_903Z-debug.log -
@Diminished7th can u show me more of the log (~/install.log) above the checksum error…
only time I have seen this is a network error…
@sdetweil thanks for your reply! Sure, here you go (from the log):
install starting - Thu Jul 16 10:35:02 CDT 2020 installing on armv7l processor system the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster [96mUpdating packages ...[90m Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Reading package lists... apt-get update completed ok apt-get upgrade started apt upgrade result =rc=0 Reading package lists... Building dependency tree... Reading state information... Calculating upgrade... The following package was automatically installed and is no longer required: rpi-eeprom-images Use 'sudo apt autoremove' to remove it. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. [96mInstalling helper tools ...[90m Reading package lists... Building dependency tree... Reading state information... build-essential is already the newest version (12.6). curl is already the newest version (7.64.0-4+deb10u1). git is already the newest version (1:2.20.1-2+deb10u3). unzip is already the newest version (6.0-23+deb10u1). wget is already the newest version (1.20.1-1.1). wget set to manually installed. The following package was automatically installed and is no longer required: rpi-eeprom-images Use 'sudo apt autoremove' to remove it. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv10.1.0[0m [0mInstalled Node version: [1mv10.21.0[0m [92mNo Node.js upgrade necessary.[0m [96mCheck current NPM installation ...[0m [0mNPM currently installed. Checking version number. [0mMinimum npm version: [1mV6.0.0[0m [0mInstalled npm version: [1mV5.8.0[0m [96mnpm should be upgraded.[0m [96mInstalling npm ...[90m Reading package lists... Building dependency tree... Reading state information... npm is already the newest version (5.8.0+ds6-4+deb10u1). npm set to manually installed. The following package was automatically installed and is no longer required: rpi-eeprom-images Use 'sudo apt autoremove' to remove it. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. upgrading npm to latest /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js + npm@6.14.6 added 435 packages from 877 contributors in 28.859s [92mnpm installation Done! version=V6.14.6[0m [96mCloning MagicMirror ...[90m [92mCloning MagicMirror Done![90m [96mInstalling dependencies ...[90m [92mDependencies installation Done![90m setting up initial config.js [96mCheck plymouth installation ...[0m [90mSplashscreen: Checking themes directory.[0m [90mSplashscreen: Create theme directory if not exists.[0m [92mSplashscreen: Changed theme to MagicMirror successfully.[0m install and setup pm2 pm2 not installed, installing pm2 install result /usr/local/bin/pm2 -> /usr/local/lib/node_modules/pm2/bin/pm2 /usr/local/bin/pm2-dev -> /usr/local/lib/node_modules/pm2/bin/pm2-dev /usr/local/bin/pm2-docker -> /usr/local/lib/node_modules/pm2/bin/pm2-docker /usr/local/bin/pm2-runtime -> /usr/local/lib/node_modules/pm2/bin/pm2-runtime npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/pm2/node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) + pm2@4.4.0 added 185 packages from 191 contributors in 28.8s get the pm2 platform specific startup command startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi ------------- __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____ _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___ _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__ _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___ _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____ _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________ _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________ _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_ _\///______________\///______________\///__\///////////////__ Runtime Edition PM2 is a Production Process Manager for Node.js applications with a built-in Load Balancer. Start and Daemonize any application: $ pm2 start app.js Load Balance 4 instances of api.js: $ pm2 start api.js -i 4 Monitor in production: $ pm2 monitor Make pm2 auto-boot at server restart: $ pm2 startup To go further checkout: http://pm2.io/ ------------- [PM2] Init System found: systemd Platform systemd Template [Unit] Description=PM2 process manager Documentation=https://pm2.keymetrics.io/ After=network.target [Service] Type=forking User=pi LimitNOFILE=infinity LimitNPROC=infinity LimitCORE=infinity Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin Environment=PM2_HOME=/home/pi/.pm2 PIDFile=/home/pi/.pm2/pm2.pid Restart=on-failure ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill [Install] WantedBy=multi-user.target Target path /etc/systemd/system/pm2-pi.service Command list [ 'systemctl enable pm2-pi' ] [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service [PM2] Making script booting at startup... [PM2] [-] Executing: systemctl enable pm2-pi... [PM2] [v] Command successfully executed. +---------------------------------------+ [PM2] Freeze a process list on reboot via: $ pm2 save [PM2] Remove init script via: $ pm2 unstartup systemd pm2 startup command done configure the pm2 config file for MagicMirror start MagicMirror via pm2 now save MagicMirror pm2 config now stop MagicMirror via pm2 now disable screensaver via gsettings was true and uint32 300 disable screensaver via lightdm.conf disable screensaver via lxsession [92mWe're ready! Run [1m[97mpm2 start MagicMirror[0m[92m from the ~/MagicMirror directory to start your MagicMirror.[0m install completed - Thu Jul 16 10:39:17 CDT 2020 -
@sdetweil and this is from the terminal above the checksum error, after it finishes cloning MM:
Installing dependencies ... npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated rrule-alt@2.2.8: Please use rrule instead npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart() npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next npm WARN deprecated core-js@2.6.11: core-js@3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3. npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.) npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated /home/pi/MagicMirror/node_modules/electron/install.js:53 throw err ^ -
@Diminished7th fun, try this
cd ~/MagicMirror npm remove electron npm install electron@6.1.12 -
@sdetweil no joy. Still getting what appears to be the same error:
pi@raspberrypi:~/MagicMirror $ npm install electron@6.1.12 > electron@6.1.12 postinstall /home/pi/MagicMirror/node_modules/electron > node install.js Downloading tmp-18488-0-electron-v6.1.12-linux-armv7l.zip [============================================>] 100.0% of 54.85 MB (660.36 kB/s) /home/pi/MagicMirror/node_modules/electron/install.js:53 throw err ^ Error: Generated checksum for "electron-v6.1.12-linux-armv7l.zip" did not match expected checksum. at Hash.hasher.on (/home/pi/MagicMirror/node_modules/sumchecker/index.js:151:20) at Hash.emit (events.js:198:13) at emitReadable_ (_stream_readable.js:555:12) at process._tickCallback (internal/process/next_tick.js:63:19) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! electron@6.1.12 postinstall: `node install.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the electron@6.1.12 postinstall script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-07-16T16_06_11_241Z-debug.logIt does look like when it’s trying to download the .zip file it’s getting hung up somewhere. I tried the install 5 or 6 times and each time the download progress will “pause” at a different point, sometimes around 13%, sometimes 20% or 30%, it’ll hang there and then jump to 100%. Not sure if this means something.
Is there a way to download the file locally and install that way to ensure it’s being downloaded completely? Should I try a different version of electron?
@Diminished7th how is the pi connected to the internet?, wired, wifi?
have u rebooted your router -
@sdetweil it’s on wifi. I rebooted the modem and router last night during troubleshooting. I can browse the internet while it’s downloading so the internet appears to be functioning properly. I can unhook everything and wire it up to the router if you think that will help?
@sdetweil your first response seems to have been correct! It appears it is some issue with the network. For some reason, it will begin to download the .zip file, but not complete it each time. It’s not that the network is going down because it doesn’t lose connection. Maybe something with the router’s firewall?
Anyways, I connected the Pi to my phone hotspot and ran the electron install, and it completed just fine and I am up and running.
If anyone else is having this issue, the telltale sign is the progress bar getting hung up before 100% and then quickly jumping to 100% and then immediately throwing the checksum error.
Thanks to @sdetweil for the troubleshooting tips! I will be marking as solved!!
EDIT: Guess I can’t mark as solved. I’ll just let the thread die. :)
