    Transit module stopped working
    29 Posts 5 Posters 10.4k Views 5 Watching
      sdetweil @Elaniobro
      @Elaniobro where is self set.? and fadeSpeed?
      E 1 Reply Last reply
      • E
        Elaniobro @sdetweil
        @sdetweil They aren’t, they can be removed. Issue I am seeing is the payload is not populated indo the getDom()
        I am setting this.result = payload which on intitial load/start of the module is undefined, which is expected, since the API promise has not been fulfilled. Later on, the socketNotificationReceived() recieves a payload which is set to this.result but in the getDom() var data = this.result is never updated.
        I am unsure of where/what caused this breakdown, as last time I touched the code was Apr 30. This is leading me to believe something changed in Core, but I am unaware of what that might be.
          sdetweil @Elaniobro
          @Elaniobro are u debugging w the developers window?
          you can walk thru the code as it executes
          ctrl-shift-i and select the sources tab, use the tree on the left to find your module, and it’s source
          then click the left edge of a line of code u want to examine, and a stop will be added.
          usually a problem like this is because the ‘this.’ pointer doesn’t point where u think it does.
          sorry, I am in hospital for a few more days and cannot debug from here
          • E
            Elaniobro @sdetweil
            @sdetweil Thank you for your feedback. I am/was already debugging in the manner you mentioned. I was able to resolve the bug(s), but now I am still not seeing any data. My best guess is somewhere along the fetch of the data something changed or broke. The application is returning data, but the response is empty.
            payload = [{ downTown: [] }, { upTown: [] }]
            For some reason, just not getting any data :/
            I am still digging in.
            S 2 Replies Last reply
              sdetweil @Elaniobro
              @Elaniobro boooo. always something! let me know if I can help
                sdetweil @Elaniobro
                @Elaniobro probably another ‘this’ pointer issue
                • E
                  Elaniobro @sdetweil
                  @sdetweil Welcome to assist, you can find the repo here: https://github.com/Elaniobro/MMM-nyc-transit
                  I do have it cleaned up a bit locally, but I am thinking my API key is no longer valid and or something changed upstream that I am not aware of. The mirror is doing what it should and returning results array, but the array is empty.
                    sdetweil @Elaniobro
                    @Elaniobro using the default config, i also see the lack of info
                        client.departures(stations)
                          .then((responses) => {
                            var upTown = []
                            var downTown = []
                            console.log("api results="+JSON.stringify(responses))
                    actual data
                     api results=[{"complexId":237,"name":"Carroll St","lines":[{"name":"6th Av - Culver","departures":{"S":[],"N":[]}}]},{"complexId":177,"name":"Clinton - Washington Avs","lines":[{"name":"8th Av - Fulton St","departures":{"S":[],"N":[]}}]}]
                    config
                          apiKey: '****',   // just granted
                          displayType: 'marquee',
                          mtaType: 'train',
                          stations: [
                              stationId: 237,
                              walkingTime: 5,
                              dir: {
                                  upTown: false,
                                  downTown: true
                              stationId: 177,
                              walkingTime: 5,
                              dir: {
                                upTown: true,
                                downTown: false
                    • E
                      Elaniobro
                      We can close this issue, it was resolved on github. The module itself never broke, it was an upstream service that did. A module that I was using, was using deprecated endpoints. I spoke with the developer and the MTA and we were able to isolate and resolve it.
                      In addition, not only did the endpoints change but any API keys generated on their old site, datamine.mta.info will no longer work.
                      You will need to create a new one via api.mta.info moving forward.
                      Thank you for your assist and feed back.
                        sdetweil @Elaniobro
                        @Elaniobro glad I found the cause. sure makes for a deep dive into the stuff we use when something changes…
                        N 1 Reply Last reply
                        • N
                          Nneuland @sdetweil
                          I’m running into this exact issue today. New install has not resolved. Neither has requesting a new API key. Any suggestions?
                            sdetweil @Nneuland
                            @nneuland I would post an issue to the module github for the developer
                            • N
                              Nneuland @sdetweil
                              Hi Sam. Yes, I did. Unfortunately because I am on a Pi4 they are unable to troubleshoot…
                              I reinstalled the module fresh and retrieved a new API from api.mta.info, not clear on the error
                              socketNotificationReceived: “TRAIN_TABLE”:
                              Array(2)
                              MMM-nyc-transit.js:332 Uncaught TypeError: Cannot read property ‘fadeSpeed’ of undefined
                              at Class.socketNotificationReceived (:8080/modules/MMM-ny…-nyc-transit.js:332)
                              at module.js:245
                              at Socket. (socketclient.js:38)
                              at Socket…/node_modules/component-emitter/index.js.Emitter.emit (socket.io.js:1915)
                              at Socket.emit (socket.io.js:1544)
                              at Socket.emitEvent (socket.io.js:1161)
                              at Socket.onevent (socket.io.js:1135)
                              at Socket.MMSocket.socket.onevent (socketclient.js:32)
                              at Socket.onpacket (socket.io.js:1089)
                              at Manager…/node_modules/component-emitter/index.js.Emitter.emit (socket.io.js:1915)
