    Transit module stopped working
    29 Posts 5 Posters 10.4k Views 5 Watching
    • N
      nipper2000h
      I have been successfully using the MMM-nyc-transit module the past few weeks without issue but it stopped working yesterday morning. This is the only module in my mirror that is having an issue and it seemed to start randomly. I’ve tried reinstalling the module on a fresh image of MM but the module still did not work. While config check has returned no errors, npm logs reveal this issue. Could someone please help me to decipher the error and work towards a resolution? ```
      pi@raspberrypi:~ $ pm2 logs mm
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      0|mm       | [2020-06-30 09:41:59.974] [ERROR]  (node:882) UnhandledPromiseRejectionWarning: Error: Error: Illegal group end indicator for Message .transit_realtime.FeedMessage: 7 (not a group)
      0|mm       |     at /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:106:15
      0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:89:5)
      0|mm       | [2020-06-30 09:41:59.976] [ERROR]  (node:882) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 6)
      0|mm       | [2020-06-30 09:41:59.977] [ERROR]  (node:882) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 6)
      0|mm       | [2020-06-30 19:35:25.557] [ERROR]  (node:1466) UnhandledPromiseRejectionWarning: Error: Error: Illegal wire type for unknown field 13 in Message .transit_realtime.FeedMessage#decode: 6
      0|mm       | [2020-06-30 19:35:25.567] [ERROR]  (node:1466) UnhandledPromiseRejectionWarning: Error: Error: Illegal wire type for unknown field 13 in Message .transit_realtime.FeedMessage#decode: 6
      0|mm       | [2020-06-30 19:35:25.573] [ERROR]  (node:1466) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
      0|mm       | [2020-06-30 19:35:25.581] [ERROR]  (node:1466) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
      0|mm       | [2020-06-30 19:35:25.584] [ERROR]  (node:1466) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      0|mm       | [2020-06-30 19:35:25.586] [ERROR]  (node:1466) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      Thank you.
      • E
        elliob
        It also doesn’t work for me either, but my logs are empty :(
        You can see the “Next Train” at the top but no trains.
        N 1 Reply Last reply
        • N
          nipper2000h @elliob
          @elliob
          Thanks for the reply. I guess it’s nice knowing I’m not the only one having trouble. Did you just install it or were you using it beforehand?
          Here’s this project’s config for whatever it’s worth.
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 12,
          	units: "imperial",
          			     // false, default for all  NON-armv6l devices
          			module: "alert",
          			module: "clock",
          			position: "top_left"
          			module: "calendar_monthly",
          				// The config property is optional
          				// Without a config, a default month view is shown
          				// Please see the 'Configuration Options' section for more information
          			module: "MMM-TimeTreeEvent",//Positions of *_bar and *_third are not support.
          				appid: "calendarapi",//You need to get the target calender id with Get calender id api[1]
          				calenderid: "calendarid",
          			module: "MMM-Events",
          				city: "New York",// Your City
          				eventType: "performing_arts,conference_convention,festivals_parades,movies_film,food,fundraisers,support,book,music_alternative,music_dance,music_jazz,music_reggae,music_vocal,music_rap_hiphop,music_rock,music_pop,music_country,",
          				when: "This Week",// "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
          				mode: "noFrame",// "Frame" or "noFrame" (around picture)
          				apikey: "eventsapi",
          				rotateInterval: 1 * 11 * 1000,// New Event Appears every 5 minutes
          				useHeader: false,// Set to true if you want a header
          				header: "",
          				animationSpeed: 3000,// Event fades in and out
          				picture: true,// true, false = no image
          			module: "MMM-TwitterTrendsByPlace",
          			position: "bottom_right",
          			// visit the url below for the twitter keys/tokens
          			// https://dev.twitter.com/oauth/overview/application-owner-access-tokens
          				consumer_key: "twitterapi",
          				consumer_secret: "twitterapi",
          				access_token_key: "twitterapi",
          				access_token_secret: "twitterapi",//set the display name/title for the place
          				placeName: "New York, NY",// set the woeid for the place, see documentation for more// http://woeid.rosselliot.co.nz/lookup/
          				placeWoeid: "2459115",
          			module: "MMM-nyc-transit",
          			position: "bottom_left",
          			header: "Next Train",
          				apiKey: "mytransitapi",
          				displayType: "list",
          				mtaType: "train",
          				stations: [
          						stationId: 476,
          						walkingTime: 0,
          						dir: {
          							upTown:true,
          							downTown: false
          				updateInterval: 300000
          			module: "MMM-MTA",
          			header: "MTA",
          				lines: ["123", "BDFM", "456", "NQR", "ACE"],
          				showDelaysOnly: false,
          				delayAlertFlash: true,
          				fetchInterval: 60000
          			module: "currentweather",
          				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "myweatherapi"
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				locationID: "5095281", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          			module: "newsfeed",
          			position: "lower_third",
          				feeds: [
          						title: "New York Times",
          						title: "CNN",
          						url: "http://rss.cnn.com/rss/cnn_topstories.rss"
          						title: "BBC",
          						url: "http://feeds.bbci.co.uk/news/world/us_and_canada/rss.xml"
          						title: "NBC",
          						url: "http://feeds.nbcnews.com/nbcnews/public/news"
          						title: "Time News",
          						url: "https://time.com/newsfeed/feed/"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
            sdetweil @nipper2000h
            @nipper2000h looks like a data change from the provider API
            • N
              nipper2000h @sdetweil
              @sdetweil Thank you for the info. You helped me out the first time I had an issue too, I’m very appreciative of your help once again. Does that mean the next step is too hope the contributor releases an update?
                @nipper2000h yes, probably. I would post an issue to the module GitHub page to inform them
                • N
                  @sdetweil Thanks again.
                  • E
                    Elaniobro
                    @sdetweil what makes you think the API changed? ( I am the author, and am looking into it now)
                      sdetweil @Elaniobro
                      @Elaniobro I posted a couple messages back the error info. node_helper line 106 called something which threw an error
                      E 1 Reply Last reply
                      • E
                        elliob @sdetweil
                        @sdetweil how did you get to error message? What’s the CLI?
                        S N 2 Replies Last reply
                          sdetweil @elliob
                          @elliob it was in the pm2 log in the 1st post of this topic
                          • N
                            nipper2000h @elliob
                            @elliob I’m using pm2 to start MM so from the root directory:
                            pm2 logs mm
                              @nipper2000h the logs are stored in the users .pm2 folder. doesn’t matter where I issue the pm2 commands
                              • E
                                Elaniobro
                                The module is getting the data, but its not updating with the this.updateDom method. I am not sure if this was deprecated or not. Looking into it.
                                  sdetweil @Elaniobro
                                  @Elaniobro how does it use this.updateDom()
                                  • E
                                    Elaniobro @sdetweil
                                    @sdetweil Its called in the socketNotificationReceived() here:
                                    https://github.com/Elaniobro/MMM-nyc-transit/blob/master/MMM-nyc-transit.js#L358-L360
                                      sdetweil @Elaniobro
                                      @Elaniobro where is self set.? and fadeSpeed?
                                      • E
                                        Elaniobro @sdetweil
                                        @sdetweil They aren’t, they can be removed. Issue I am seeing is the payload is not populated indo the getDom()
                                        I am setting this.result = payload which on intitial load/start of the module is undefined, which is expected, since the API promise has not been fulfilled. Later on, the socketNotificationReceived() recieves a payload which is set to this.result but in the getDom() var data = this.result is never updated.
                                        I am unsure of where/what caused this breakdown, as last time I touched the code was Apr 30. This is leading me to believe something changed in Core, but I am unaware of what that might be.
                                          sdetweil @Elaniobro
                                          @Elaniobro are u debugging w the developers window?
                                          you can walk thru the code as it executes
                                          ctrl-shift-i and select the sources tab, use the tree on the left to find your module, and it’s source
                                          then click the left edge of a line of code u want to examine, and a stop will be added.
                                          usually a problem like this is because the ‘this.’ pointer doesn’t point where u think it does.
                                          sorry, I am in hospital for a few more days and cannot debug from here
                                          • E
                                            Elaniobro @sdetweil
                                            @sdetweil Thank you for your feedback. I am/was already debugging in the manner you mentioned. I was able to resolve the bug(s), but now I am still not seeing any data. My best guess is somewhere along the fetch of the data something changed or broke. The application is returning data, but the response is empty.
                                            payload = [{ downTown: [] }, { upTown: [] }]
                                            For some reason, just not getting any data :/
                                            I am still digging in.
                                            S 2 Replies Last reply
