    Transit module stopped working
    29 Posts 5 Posters 7.9k Views 5 Watching
      sdetweil @nipper2000h
      @nipper2000h yes, probably. I would post an issue to the module GitHub page to inform them
      • N Offline
        nipper2000h @sdetweil
        @sdetweil Thanks again.
        • E Offline
          Elaniobro
          @sdetweil what makes you think the API changed? ( I am the author, and am looking into it now)
            sdetweil @Elaniobro
            @Elaniobro I posted a couple messages back the error info. node_helper line 106 called something which threw an error
            2020-06-30 09:41:59.974] [ERROR]  (node:882) UnhandledPromiseRejectionWarning: Error: Error: Illegal group end indicator for Message .transit_realtime.FeedMessage: 7 (not a group)
            0|mm       |     at /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:106:15
            • E Offline
              elliob @sdetweil
              @sdetweil how did you get to error message? What’s the CLI?
              S N 2 Replies Last reply Reply Quote 0
                sdetweil @elliob
                @elliob it was in the pm2 log in the 1st post of this topic
                • N Offline
                  nipper2000h @elliob
                  @elliob I’m using pm2 to start MM so from the root directory:
                  pm2 logs mm
                    @nipper2000h the logs are stored in the users .pm2 folder. doesn’t matter where I issue the pm2 commands
                    • E Offline
                      Elaniobro
                      The module is getting the data, but its not updating with the this.updateDom method. I am not sure if this was deprecated or not. Looking into it.
                        sdetweil @Elaniobro
                        @Elaniobro how does it use this.updateDom()
