    Transit module stopped working
    29 Posts 5 Posters 7.9k Views 5 Watching
    • N Offline
      nipper2000h @elliob
      @elliob
      Thanks for the reply. I guess it’s nice knowing I’m not the only one having trouble. Did you just install it or were you using it beforehand?
      Here’s this project’s config for whatever it’s worth.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			module: "clock",
      			position: "top_left"
      			module: "calendar_monthly",
      				// The config property is optional
      				// Without a config, a default month view is shown
      				// Please see the 'Configuration Options' section for more information
      			module: "MMM-TimeTreeEvent",//Positions of *_bar and *_third are not support.
      				appid: "calendarapi",//You need to get the target calender id with Get calender id api[1]
      				calenderid: "calendarid",
      			module: "MMM-Events",
      				city: "New York",// Your City
      				eventType: "performing_arts,conference_convention,festivals_parades,movies_film,food,fundraisers,support,book,music_alternative,music_dance,music_jazz,music_reggae,music_vocal,music_rap_hiphop,music_rock,music_pop,music_country,",
      				when: "This Week",// "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
      				mode: "noFrame",// "Frame" or "noFrame" (around picture)
      				apikey: "eventsapi",
      				rotateInterval: 1 * 11 * 1000,// New Event Appears every 5 minutes
      				useHeader: false,// Set to true if you want a header
      				header: "",
      				animationSpeed: 3000,// Event fades in and out
      				picture: true,// true, false = no image
      			module: "MMM-TwitterTrendsByPlace",
      			position: "bottom_right",
      			// visit the url below for the twitter keys/tokens
      			// https://dev.twitter.com/oauth/overview/application-owner-access-tokens
      				consumer_key: "twitterapi",
      				consumer_secret: "twitterapi",
      				access_token_key: "twitterapi",
      				access_token_secret: "twitterapi",//set the display name/title for the place
      				placeName: "New York, NY",// set the woeid for the place, see documentation for more// http://woeid.rosselliot.co.nz/lookup/
      				placeWoeid: "2459115",
      			module: "MMM-nyc-transit",
      			position: "bottom_left",
      			header: "Next Train",
      				apiKey: "mytransitapi",
      				displayType: "list",
      				mtaType: "train",
      				stations: [
      						stationId: 476,
      						walkingTime: 0,
      						dir: {
      							upTown:true,
      							downTown: false
      				updateInterval: 300000
      			module: "MMM-MTA",
      			header: "MTA",
      				lines: ["123", "BDFM", "456", "NQR", "ACE"],
      				showDelaysOnly: false,
      				delayAlertFlash: true,
      				fetchInterval: 60000
      			module: "currentweather",
      				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "myweatherapi"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				locationID: "5095281", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			module: "newsfeed",
      			position: "lower_third",
      				feeds: [
      						title: "New York Times",
      						title: "CNN",
      						url: "http://rss.cnn.com/rss/cnn_topstories.rss"
      						title: "BBC",
      						url: "http://feeds.bbci.co.uk/news/world/us_and_canada/rss.xml"
      						title: "NBC",
      						url: "http://feeds.nbcnews.com/nbcnews/public/news"
      						title: "Time News",
      						url: "https://time.com/newsfeed/feed/"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
        sdetweil @nipper2000h
        @nipper2000h looks like a data change from the provider API
        2020-06-30 09:41:59.974] [ERROR]  (node:882) UnhandledPromiseRejectionWarning: Error: Error: Illegal group end indicator for Message .transit_realtime.FeedMessage: 7 (not a group)
        0|mm       |     at /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:106:15
        • N Offline
          nipper2000h @sdetweil
          @sdetweil Thank you for the info. You helped me out the first time I had an issue too, I’m very appreciative of your help once again. Does that mean the next step is too hope the contributor releases an update?
            @nipper2000h yes, probably. I would post an issue to the module GitHub page to inform them
            • N Offline
              @sdetweil Thanks again.
              • E Offline
                Elaniobro
                @sdetweil what makes you think the API changed? ( I am the author, and am looking into it now)
                  sdetweil @Elaniobro
                  @Elaniobro I posted a couple messages back the error info. node_helper line 106 called something which threw an error
                  • E Offline
                    elliob @sdetweil
                    @sdetweil how did you get to error message? What’s the CLI?
                    S N 2 Replies Last reply Reply Quote 0
                      sdetweil @elliob
                      @elliob it was in the pm2 log in the 1st post of this topic
                      • N Offline
                        nipper2000h @elliob
                        @elliob I’m using pm2 to start MM so from the root directory:
                        pm2 logs mm
