Solved pm2 Autostart invert issue
@sdetweil this time even when I give ^q, the screen is not inverted as opposed to last time.
@Ethyx so the /boot/config.txt didn’t work. read more
@sdetweil yep
@Ethyx you added
display_rotate=2to config.txt, right, and saved it
@sdetweil yeah and the issue still somehow persists
@Ethyx you had to use
sudo nano /boot/config.txt
to edit that file, right? -
@sdetweil yes. i followed everything that was on this website.
@Ethyx r u running buster?
@sdetweil that was the aritcle i referred to before i posted it here and yes i am using buster.
@sdetweil said in pm2 Autostart invert issue:
Did you try this?
display_hdmi_rotate=2
Make sure you only have one of the options active; not that you rotate a rotated screen. :-)
