    Reloading config defaults or module
    10 Posts 2 Posters 1.4k Views 1 Watching
      sdetweil @Guest
      @hango because u coded the value in the array, it is calculated at the time the array is built, NOT at the time it is USED
      so, start the mirror at 2pm, and the value will be calculated as of 2pm.
      what u will want is a function that returns a value , calculated by the function.
      I don’t think the default compliments module can do that, but havent read the code much beyond fixing the embedded \n problem last year sometime.
        A Former User
          sdetweil @Guest
          @hango you will have to write code to allow a function instead of a string, then detect to function and call it to get the string to display
            A Former User @sdetweil
              sdetweil @Guest
              @hango the code was less than i thought
              replace this (last line of randomCompliment)
                      return   compliments[index] || '';
              with this
              		var f = compliments[index];
              		if ( typeof f == 'function') f= f()
              		return f || "";
              a compliment config entry would look like this
                module: "compliments",
                    compliments : {
                         'anytime': [ function(){return "this is a  test "+ moment().format('MM DD HH:MM:SS')}
              all of the things can be functions, or any combo down to just 1 entry as a function.
              the function must return a string
