    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 57.7k Views 5 Watching
      sdetweil @dave_
      @dave_ so, something doesn’t make sense… please show me your config.js
        dave_ @sdetweil
          sdetweil @dave_
          @dave_ weird… ok, re-enable AlexaControl (change to disabled: false, ) then restart MM and show me the messages again
            dave_ @sdetweil
            @sdetweil https://photos.app.goo.gl/Eqxwv27mVDBbowBH8
              sdetweil @dave_
              @dave_ and the MM messages? yes, electron should be using 1900 now for alexacontrol
                dave_ @sdetweil
                @sdetweil https://photos.app.goo.gl/SuvM64zPpyQCZjQT8
                  sdetweil @dave_
                  @dave_ ok, as expected… the extra image u posted this morning was from some other time
                  now, if you do alexa discover devices (phone app is more (bottom right), other, discover devices)
                    dave_ @sdetweil
                    @sdetweil tried that still no luck
                      sdetweil @dave_
                      @dave_ ok, need to edit a file to turn on some debugging
                      nano ~/MagicMirror/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js
                      change lines 92-94, the console.log lines below
                      change from
                      	udpServer.on('message', (msg, rinfo) => {
                      		//debug(`<< server got: ${msg} from ${rinfo.address}:${rinfo.port}`);
                      		//console.log('Search request from ' + util.inspect(rinfo));
                      		//console.log(getMask(rinfo.address, '255.255.255.0'));
                      to
                      		console.log(`<< server got: ${msg} from ${rinfo.address}:${rinfo.port}`);
                        dave_ @sdetweil
                        @sdetweil my internet went of for a bit I’ll do this asap and let you know!
                        • 10
                        • 7 / 10
